Old 01-27-2014, 08:46 AM   #15
Extreme86
Live Free, Drive Hard
Extreme86's Avatar
Drives: 13 BRZ, 19 WRX, 10 GMC, 20 RAV4
Originally Posted by Frost View Post
Is this still an issue on newer cars? Toybaru have done nothing to fix it?
They will fix it under warranty - don't know if there is a TSB on it yet. Probably the luck of the draw as to how well the original sealant was applied when engine was built as to whether a leak develops or not. Some leak, most don't....it seems. As long as the percentage remains low, I doubt they develop an alternate fix...a recall would cost big $$$. If this leak became as "popular" as the cricket issue they'd likely come up with an alternate seal approach. A circular blob of sealant vs. a better O-ring plate design (or a specific sized silicone rubber gasket) saved time and a small chunk of yen I guess!
Originally Posted by ronboogieon View Post
I've been getting a burning smell thinking I was burning my clutch until I stumbled on these oil leak threads. Went and took a look at my cam plate and there appears to be some oil drops on the exhaust manifold. Mine is a Jul '13 build.
Put your fingers (or a paper towel) behind the lower part of the plate when the engine is cool and it'll show you a bit more evidence of whats been dripping! Mine is a Jun '12 build. Leak became apparent with smell almost a year and a half after manufacture date. Could be a lot of newer car folks have a small leak but just don't know it yet cause there is no obvious smell.
Originally Posted by 2_slo View Post
Sorry guys, I can't help but wonder if I'm missing something...is there some reason I can't just buy a sheet of rubberized gasket material and cut out a gasket for it? It looks to me like that would be a easy permanent fix.
No apologies - crossed my mind, too. I think I saw a post by someone who did that. Makes sense to me. I would have given it a shot if I had the right rubber gasket stuff to play with!! (If anyone has done this already - please post on this thread and tell us about it.) Would sure be nice if Fel-Pro aftermarket could help us out with a specific pre-cut application but, probably not enough numbers to justify the effort!
Update: 2 weeks after the high temp red silicone RTV pooky fix (above addendum) and a spirited > 131 mile Twisted Sisters Run out in the Texas Hill Country this past Saturday...hammering the car WOT on numerous twisties - no cam plate oil leak...still dry as a bone.
Extreme86 is offline   Reply With Quote
Old 02-11-2014, 01:15 PM   #16
2_slo
2_slo's Avatar
Drives: 2013 Crystal Black BRZ Limited
I think next time I make it out to the hangar I'll pull it off and make a gasket. I already bought some gasket material. Ill post some pics when I do.
2_slo is offline   Reply With Quote
Old 02-26-2015, 04:17 AM   #17
Satanasso
Satanasso's Avatar
Drives: Subaru BRZ - Satin White Pearl
Send a message via MSN to Satanasso
hi guys,
i'd like to make my own "stopper" for this annoying oil leak , but i don't know the diameter of the hole , has anyone ever measuered it?
( unfortunately i have no chance for the moment to buy raceseng or other cam plates )
Satanasso is offline   Reply With Quote
Old 02-26-2015, 03:22 PM   #18
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Originally Posted by Satanasso View Post
hi guys,
ID or OD? I've got a Raceseng plate coming tomorrow and can measure it when I do the install, probably over the weekend.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 02-26-2015, 06:11 PM   #19
Satanasso
Satanasso's Avatar
the ID , inner part of the plate, i think that just making a stopper , something like this:
but thinner, and use the stock plate to keep it stuck ( and sealant then )
if you can, thanks a lot then
Old 02-26-2015, 06:58 PM   #20
Koa
Have you tried cleaning the area and re-applying rtv/sealant to your stock plate?
Old 02-27-2015, 04:52 AM   #21
Satanasso
Satanasso's Avatar
i will do it tomorrow
( i have to go on holidays next week so it will be a hotfix )
just i noticed some oil leak more than "normal" in the last weeks, and so the smell now is quite strong after a long drive (50km)...
btw i would like to make a handmade stopper (when i will come back to holidays) to fix the problem once for all
Old 02-27-2015, 08:39 PM   #22
Kojiro
Drives: 2014 Black BRZ Limited
Glad this showed up. After searching around a bit,
I'm going to buy the Raceseng plate. I've noticed that I do occasionally get that oil smell.
Kojiro is offline   Reply With Quote
Old 03-05-2015, 02:14 AM   #23
8R6
8R6's Avatar
Drives: FRS
totally forgot about this thread. been meaning to get the cam plate taken care of. ugh
8R6 is offline   Reply With Quote
Old 04-05-2015, 12:51 AM   #24
dnieves
Drives: FR-S 10 Series
Torque Solutions cam plate
Last month I kept noticing a slight burning smell whenever I hit the throttle but would inexplicably instantly disappear. Thanks to this thread I was able to determine the source of my oil leak (light coating of oil towards the bottom edge of the cam plate!). Although this repair is covered by warranty there's no point in doing it unless they change the cover plate design as cleaning it and using new RTV will eventually fail again.
I rarely stray from OEM but I found a cam cover plate from Torque Solution that incorporates a high temp Viton O-ring and made from billet aluminum (in black or silver). For an aftermarket part that that serves a purpose & isn't easily visible in the engine bay it isn't ridiculously priced (like Raceseng). http://www.torquesolution.com/product-p/ts-cam-plts.htm
Very easy install (as detailed in the original cam plate post):
1. Remove three bolts from cam plate with a 11mm socket (easy) and pry off cam plate (takes a couple of minutes but it gets a lot easier from here).
2. Remove all oil and RTV from (engine) mating surface.
3. Smear a little engine oil on the O-ring, install cam plate with supplied 6mm Allen bolts and torque accordingly.
Unfortunately before checking with Torque Solution, I followed the installation instruction for another cam plate and put a bead of RTV on the mating surface of the area outside of the O-ring (not neccessary). After I finger tightening the cam plate I had to let the RTV set for an hour then torqued it and let it cure overnight. I haven't had any traces of a leak since!
Judging from the helpfulness of Torque Solutions' staff, ease & quality of the product I plan on making more purchases with them.
dnieves is offline   Reply With Quote
Old 05-22-2015, 10:11 AM   #25
TheDanimal
I installed my Torque Solution cam plate a few weeks ago and so far no more leaks. Thanks for the review.
TheDanimal is offline   Reply With Quote
Old 05-25-2015, 09:28 AM   #26
dnieves
Great to hear!! Which cam plate did you get the black or the unpainted aluminum? Not that you really see it, I wish I knew about the unpainted one when I ordered the black one (I found out 5 minutes after the order went through).
Such an easy fix for such a lazy OEM solution (really Subaru? a completely flat plate with three bolts and a glob of RTV?)
Old 08-16-2015, 05:39 AM   #27
Speedie
Drives: Subaru BRZ and VW R36
Hi,
Noticed over the past month or so the burning oil smell and smoke sometimes from under the bonnet. After reading these posts, I checked the cam plate is the culprit with a small leak. For those that have used the torque solution cam plate does it require any RTV at all?. I note the Raceseng solution also uses an o-ring, but they also recommend some RTV as well. Leaning towards the torque version and would like to side step the RTV if possible.
Thank you.
Speedie is offline   Reply With Quote
Old 08-16-2015, 05:44 AM   #28
dj2020
What's the best way to remove oil and RTV from the engine mating surfacing before installing the aftermarket cam plate?
dj2020 is offline   Reply With Quote
Oil leak solved - Raceseng billet aluminum cam plate Clipdat Issues | Warranty | Recalls / TSB 156 06-17-2020 11:29 PM
Raceseng | Cam Plate - Stop your oil leak! Raceseng Groupbuys 63 10-18-2013 03:31 PM
Raceseng | Cam Plate - Stop your oil leak! Raceseng Engine, Exhaust, Transmission 2 09-21-2013 07:47 PM
A/T Pan leak goke186 Issues | Warranty | Recalls / TSB 0 04-15-2013 10:31 PM
Exhaust Leak? k33n3r Engine, Exhaust, Transmission 6 08-09-2012 12:59 PM
