#16 |
To be fair, the one universally consistent observation of this is that the crickets usually do not occur until the second tank of gas (at the soonest which is why the poll has 300 miles on it) and that a fresh pump is quiet for at least a tank of gas. Indicating that after an initial break in period the pump starts chirping.
I fail to see how it can be anything other than the pump. |
#17 |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
Does anyone actually know what make and model the HPFP is?
EDIT: Reason I ask is because I want to look at breakdown of the unit and see why it would chirp like that. Just cuz...
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
#18 |
FR-S Newb
^No exact answer but from what I've heard, the ethanol in fuel eats at some seals internally. Don't know for sure just sharing what I've been told.
"Driving is the synchronization of vision, analysis, and movement. It is an art form." -Unknown
#19 | |
http://www.ft86club.com/forums/showthread.php?t=41776 |
| The Following User Says Thank You to strat61caster For This Useful Post: | Frost (12-19-2013) |
#20 |
Drives: 2013 Subaru BRZ MT Limited
This is my third pump...not really circumstantial, the crickets are known to be from the HPFP it's not a guess and Toyota/Subaru have admitted it. Whether or not the crickets will come back is yet to be seen but the crickets ARE from the HPFP. So far I have 1000 miles with the new pump so it's looking promising but I'm not going to hold my breath.
Dark Blue 2020 Subaru Forester Sport, Name: Apollo - God of Music
WRB 2013 Subaru BRZ Limited MT, Name: Zeus - Father of all God's and God of Sky and Thunder Perrin Cat-Back, ECUTek Tune by Kaizen Tuning, Perrin Silicone Radiator Hoses, Perrin Master Cylinder Brace, Perrin True Cold Air Intake |
#22 |
Drives: 2014 Scion FR-S ハチ
To be honest I see no reason to NOT have them install it. If it was a computer and someone wanted to replace a stick of RAM for free just because it was newer, I would say "Hell Yeah, when do I bring it in?"
#23 |
The crickets will be back on the new pump, it's just a matter of when. I'm convinced it's a lubrication issue. Temperature doesn't affect my crickets on the new pump. Someone just posted today in the other main thread after 6,000 km, crickets returned on the new pump.
#24 |
Drives: small
#25 |
Hi guys,
I was concerned about complications from the install, but I went ahead and let them put it in anyway. Upon getting the car back, I immediately noticed a brand new "Ticking" sound coming from the HPFP, it was really noticable when cold, but seemed to go away once it was warmed up. The car seems to actually be running a little better with the new pump, but I found it odd that they did not reset the ECU. I would assume any type of mechanical work on a car would require disconnecting the battery... I'll keep you guys posted on the "Ticking" noise, I'm hoping it was just a "Brand new part" noise and will go away in a day or two. If not, back to the dealership I go...
| The Following User Says Thank You to Hakuzen For This Useful Post: | Mr.EvoMR (12-23-2013) |
#26 |
Returned the car to the dealership, after about 5 hours I got a call back saying it was a "normal noise", and this coming from the guy who initially heard it with me and agreed that it was a new noise, and a weird one at that.
He said they are going to listen for it again tomorrow morning when its cold and get back to me, but I'm starting to become concerned that they are going to try and force the car back to me with this new noise as a permanent feature. What would my options be in that case? Can I take it to a different service department and have them try and fix it? Or does my warranty lock me to the place I bought it at? There is no way this noise is normal, my old pump worked fine and never made this noise once in over 2,000 miles. If I get the vehicle back without the noise fixed, Ill record it and post it up and see if any of you have heard it before.They are claiming they heard the same noise from another FR-S on the lot, but A: I don't believe them and B: Even if it's true it's a BAD sounding noise that was never present before they performed service on the vehicle. Hoping these guys figure this out tomorrow and this doesn't have to go down a bad road. =\ |
#27 |
Drives: small
Sorry for the new noise issues. But for other people, let this be a warning when you decide to let people you don't know work on your car. T10 tech or otherwise. Stealerships are structured to make more money the faster they work, which means they can never ever treat your car the same way they would treat their own. Each car repair has a set number of hours assigned for that job completion. Beat that number, make money. Take longer and lose money. This means they are incentivized to cram as many hours worth of work into as few hours of actual labor as possible to maximize revenue. Warranty repairs also need to be in and out asap. However, they do loose time and money if they have a 'comeback'. Which is why he's fucking with you now. They don't want it back cuz he'd be working for free.
This all assumes the tech in question was actually properly trained in the first place and gives a shit. Ultimately, no one will care about your car as much as you do. Worse come to worse, write a letter to Toyota Motor USA about your dealer. Or threaten to first. Last edited by Boxer486; 12-24-2013 at 05:18 PM. |
| The Following 2 Users Say Thank You to Boxer486 For This Useful Post: | Mr.EvoMR (12-24-2013), strat61caster (12-24-2013) |
#28 | |
FR-S Newb
| Fuel pump | sw20kosh | Engine, Exhaust, Transmission | 1 | 12-10-2013 10:21 PM |
| High Pressure Fuel Pump Difference? Toyota vs. Subaru | 86_ZN6 | Engine, Exhaust, Transmission | 18 | 06-03-2013 06:48 AM |
| Fuel pump issue. | sevi21 | Issues | Warranty | Recalls / TSB | 13 | 02-01-2013 09:57 AM |
| Car fuel pump on... | Genomaxter | Engine, Exhaust, Transmission | 5 | 11-29-2012 10:06 AM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 3 | 08-21-2012 04:53 PM |
