Old 12-13-2013, 11:20 PM   #15
humfrz
Well, 1086, like they say back on the farm, it's your tractor.
(I just made that up ....)
I will admit that you have identified some interesting ways to reduce the weight of the car.
However, I agree with @campy and your "car's diet" doesn't seem to go along with your driving objective:
" I am a casual daily driver and on the weekend I enjoy spirited driving in the mountains/back roads/hills, etc. like I am sure many of you.".
Personally, I don't notice much difference in driving around the back roads, byways and in the mountains, whether mrs humfrz is along or not ...... and she weighs in at a bit more that 138lbs.....
I would think that proper tires and honed driving skills would net you more "comfortable" driving fun, than stripping the car.
humfrz
Old 12-13-2013, 11:24 PM   #16
R.S-HawK
Drives: '13 Gen Coupe 3.8 R
Might as well lose the stock wheels while you're at it.
Get something like RPF1s, which are 5-6 lbs lighter than stock...in turn translate to an ever further weight loss because rotational mass is exponential.
R.S-HawK is offline   Reply With Quote
Old 12-13-2013, 11:40 PM   #17
MeFryRice
Drives: '13 SWP BRZ
If we're going to discuss rotational mass then also look into a carbon driveshaft and a brake kit.
MeFryRice is offline   Reply With Quote
Old 12-14-2013, 02:37 PM   #18
campy
No rice, no life
campy's Avatar
Drives: 2013 Asphalt FR-S
Originally Posted by 1086 View Post
@campy hypothetically, with the shredded weight, it would be like driving with 75.6% less of my own body weight sitting in the car. I imagine that reduced weight, met with adequate wHP increase, has to feel noticeable (even on backroads?) - then again I wouldn't know yet lol
I'd suggest you start with the tune first and see how you like the feel of the car, then you can move on to weight reduction.
I used to daily an older Porsche with a roll cage, coilovers, aftermarket exhaust, racing seats, and some of the insulation/carpeting taken out to reduce weight (and make space for the cage). It's cool at first, but it definitely makes the car more tiring to drive. With the FRS, I can go on a 300 mile trip and feel good at the end of it. In that Porsche, after 15 minutes I would have a headache and backache.
Also, girls hated how loud and uncomfortable it was
Of course, this is just my $0.02. You may like it, but in my personal experience, I'd prefer all the comforts that come with a less-modded car for a DD. That said, don't let strangers on the internet make your decisions for you! haha
campy is offline   Reply With Quote
Old 12-14-2013, 02:44 PM   #19
dabocx
dabocx's Avatar
Drives: Scion FRS
I bought a road bike for a grand, going to loose 40-50 pounds off the car with it. Pretty good value
dabocx is offline   Reply With Quote
Old 12-14-2013, 03:46 PM   #20
NWFRS
NWFRS's Avatar
Drives: ‘13 FRS
Agree with everyone above.
Find some lighter wheels.
Keep your sound deadening and upholstery.
Do an intake, exhaust and a tune if you still feel that it's lacking.
NWFRS is offline   Reply With Quote
Old 12-14-2013, 04:48 PM   #21
raptor87
Drives: 2013 DGM BRZ Ltd
don't lie you never have girls in your car
raptor87 is offline   Reply With Quote
Old 12-14-2013, 05:59 PM   #22
root
Drives: Raven FR-S
Bought a mt bike for 4, gained 30lb plus another 30+ for the rack to carry it in car! And gain weight from the increase in calorie intake, aw hell, no matter, I enjoy it!
Here's another weight reducer, delete stereo, speakers, and wiring. Free. Dump water from the windshield squirter. Run with only two gals of gas in tank. With your estimates, this will now get you easily below 2600. Heck the gas alone will drop more than 50 lbs, more than any single item listed!
Just don't blame us when you're out in the boonies, stuck in a ditch, windshield covered in mud, tire blown, cold because engine doesn't run from no gas, and listening to the wind whistling through the trees.
root is offline   Reply With Quote
Old 12-14-2013, 07:17 PM   #23
Bach415
Bach415's Avatar
Drives: Whiteout FRS
@Bach415 - So in order for weight reduction to work you must first lower the car, but using coilovers or springs? And only a light weight wheel works? Why not the OEM set? Although I know each are 41s lbs. I guess shaving 10-15lbs off each wheel/tire adds up nicely :o
Also, is it a decent option to go with Koni's and some eibach sportlines or teins? or is that weaaaaaaak
You don't need to lower the car. Lowering the car only affects the handling of the car, not the weight reduction. Replacing coilovers maybe a lighter yet stronger solution in terms of reduction weight as well as maintaining and modifying handling. You can still use oem wheels and tires but those are the easiest way to remove unsprung weight assuming you have a good wheel tire combo(aka light rims not on super meaty tires)
For those two options, I have no opinion on them. You may be better off asking someone who is good with suspension as I have no experience running them on the car.
Think about it this way, in order for weight reduction to actually work, you have to have a good balance between unsprung and sprung weight. Too much or too little of one or another may have an effect on your control of the car as well as how planted the car will be towards the ground..
Bach415 is offline   Reply With Quote
Old 12-14-2013, 08:12 PM   #24
campy
No rice, no life
campy's Avatar
Hey man we went on 2 dates so I'm gonna count that as dating.
Who needs girls when you have cars anyways.
Old 12-15-2013, 12:41 AM   #25
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
You should see @Anthony 's if you want to see a car on a diet
the new guy is offline   Reply With Quote
Old 12-15-2013, 05:56 AM   #26
asnoir
Drives: An old Citroen Xantia TD
I search for weight reduction as you. But you must be carefull to have the same balance ratio. Look at seibon carbon for doors , hood and trunk ! It will cost but it could be effective!
asnoir is offline   Reply With Quote
Old 12-15-2013, 05:24 PM   #27
Anthony
Weight Nazi
Anthony's Avatar
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
DO IT. I see most people are against the idea, but I half-gutted (everything behind the front seats) my DD and loved it so much, I started to consider taking the stereo and A/C out too. That would be a terrible idea living on the Gulf Coast, so I just bought an FR-S and gutted that. Then I un-gutted my DD. Here are some points to consider:
- I drove around over a year with my only car gutted and enjoyed it enough to do as I said with the FR-S.
- If you take your time and stay organized, you can put everything back in whenever you want. Those stupid plastic pushpins tend to snap, but you can also buy more. Just take your time and take them out gently. You can even buy tools specifically designed to take them out. I just used screw drivers and out of the 200 or so (it seems) I've taken out, I feel like I only broke ~10. Also, take pictures if you think you might forget where things go.
- If you care about maximizing performance and not much else, dropping weight is the best $:Benefit thing you can do. Most of it is free. You can always keep it comfortable and still boost performance by buying performance parts and not stripping the inside. But you will not be absolutely maximizing performance. For most people, that's ok, but I get bothered by only giving it 90%. 100% or GTFO.
- The car will become way noisier on the inside, which is either a love or hate thing. Personally, I love it. I can hear the road going by under the car. It increases the sensation of speed, and I feel more connected to both the car and road. It's more motorcycle-esque.
Originally Posted by torqdork View Post
Cool thread, worthy of other's input.
Mine is that your budget is more robust than mine. I'd have a hard time justifying $450 for a Super B battery when I can save 20 lbs. vs. OEM for $150 with a Braille (Amazon).
I went with a Shorai LFX21L6-BS12 off of Amazon for like $176. 3 pounds, 1 ounce. 5 year warranty.
It's true. Still have quite a way to go too!
Build Thread | The Venus Project | Any car which holds together for a whole race is too heavy.
Anthony is offline   Reply With Quote
Old 12-16-2013, 10:27 AM   #28
torqdork
torqdork's Avatar
Drives: RV-7
Originally Posted by Anthony View Post
[SIZE="3"]...I went with a Shorai LFX21L6-BS12 off of Amazon for like $176. 3 pounds, 1 ounce. 5 year warranty...
Now that's impressive. What battery tender/minder do you use? Any issues in use like heat from the car's high current charging system?
torqdork is offline   Reply With Quote
Official Component Weights & Weight Reduction Thread JRitt Tracking / Autocross / HPDE / Drifting 381 10-03-2024 08:02 AM
Weight reduction in the front only KevinBRZ Scion FR-S / Toyota 86 GT86 General Forum 16 04-12-2013 12:25 AM
the weight reduction of FR - S? raiden8383 Scion FR-S / Toyota 86 GT86 General Forum 22 11-30-2012 06:10 PM
Official Weight Reduction Thread - Sort of... merlin2111 Off-Topic Lounge [WARNING: NO POLITICS] 77 10-07-2012 05:09 PM
Spirited 86 driving in Korea ESBjiujitsu FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 05-22-2012 02:47 AM
