#15 |
Drives: Subaru
Here's a useful read for the OP if he hasn't read it already.
http://www.ft86club.com/forums/showthread.php?t=5136 At the end of the day, it all depends on what you are using the car for. If it's gonna see a ton of track days, it probably wouldn't hurt to go bigger to address issues of heat and fade. If you are only going to autocross/track every once in a while, you could probably convince yourself it is useful even though a majority of people, myself included, will think it doesn't make a difference. If you are never going to see an autocross/track, you are getting it for the BLING factor. |
#16 | |
Site Moderator
Drives: Stuff
Brakes are simple to install/fit but not always so simple to get correct performance out of them. With the fronts only, do they have any difference in pad area? Or piston area? More pistons doesn't mean more piston area by default. If it's the same as the stock slider you will improve feel/modulation only (and some slightly better pad wear), not performance.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#17 | |
Site Moderator
Drives: Stuff
And about 12 other threads... increase the size of the heatsink only if you have problems that can't be addressed with cooling, otherwise you won't see performance benefits (but yes, feel/modulation and pad wear benefits), but there will be negatives.
-Dave
#18 |
Registered you sir
Drives: 99 impreza coupe
Pretty cool results from this test on Nasioc, some evidence toward me being on the more probable side of this argument. (4pots also weighed in a lb lighter.)
http://forums.nasioc.com/forums/show...&highlight=pot |
#19 |
Drives: Attitude
Heh, I remember when irish posted it some years ago. In any case, they're expensive new and a provide some benefit to the heavy pig car. It remains to be seen whether or not moving bias rearward does anything relatively helpful for this car.
#20 |
Brake bias wouldn't be a concern if the person swapping the brakes over spent the $40 on an adjustable proportioning valve.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
#21 | |
Site Moderator
Drives: Stuff
Which is worthless unless someone knows how to set it up
-Dave
#22 |
Of course, but that's like saying "don't buy coilovers because you don't know how to set them up." That's where a good performance shop can step in and set it up for you.
#23 | |
Site Moderator
Drives: Stuff
Here I think they'd maybe be able to set it up to a specific weight, but suggestions on rates/damper settings.. good luck. And brake bias.. even more good luck. About the only people who would know are the race shops, which there are plenty of, but they tend to be busy and therefore you won't get it done quickly.
-Dave
#24 |
An adjustable prop valve is a ton of work for a Subaru and IIRC requires replumbing the lines and possibly losing ABS. It's not something you're going to do on a street car.
- Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | OrbitalEllipses (04-30-2012) |
#25 | |
Site Moderator
Drives: Stuff
I guess you could use an adj valve with ABS but I could see some issues there. Good input And regardless, 99% of the people who put on a big brake kit NEVER touch any other part of the system anyways.
-Dave
#26 | |
#27 |
Track Junkie
Drives: Faster than the Stig!
Why not do the TRD upgrade up front and keep the oem rear ones but do rotors pads and lines? I dont think this car will need huge brakes since its light , that should be more than enough.
Compensating a heavy car with horsepower is like giving an alcoholic cocaine to sober him up...
#28 |
| which brake pads? | NESW20 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 165 | 02-25-2018 03:07 AM |
| TireRack has big brake kits for FR-S. | Cheddar | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 04-17-2012 03:42 PM |
| Secondary Rear Brake Caliper for drifting or parking brake?? (pics) | Axel | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-25-2010 11:28 AM |
| Brake override system in the FT-86? | mrKiKaZ | Scion FR-S / Toyota 86 GT86 General Forum | 10 | 02-22-2010 12:33 PM |
