Old 12-10-2013, 10:07 PM   #15
bgibbsunc
bgibbsunc's Avatar
Drives: Firestorm Scion FR-S
Originally Posted by Pablitomarrero View Post
Well he made them so the nipples would be facing the firewall so as to make the cleanest setup possibles without having hoses all over the place. Wait arent long hoses preferable? I mean it gives more surface area to precipitate oil droplets.
Yes long hoses are great buy not 4 ft across the engine bay. But yea I have the same setup just didnt have them welded. I like the look of one on each side just need to do some relocating first.
Ill post some pics tomorrow
FA20 club 60 trim + flex fuel
467 whp 356 ft lbs @ 19 lbs
Owner of Sidewinders Auto LLC.
San Antonio TX
bgibbsunc is offline   Reply With Quote
The Following 2 Users Say Thank You to bgibbsunc For This Useful Post:
FearBoy (12-11-2013), Pablitomarrero (12-10-2013)
Old 01-04-2014, 09:18 AM   #16
Pablitomarrero
Pablitomarrero's Avatar
Drives: FR-S 10 series
Update!! Installed the catch cans an this is how the sit right nowName:  ImageUploadedByTapatalk1388841370.518355.jpg
I was able to tuck in the hoses for a very stock look.
Cant comment on functionality yet. Ill check back again in three months to let you know! I can say however that i love their sleeper/stock look!! Very sleek!!
Pablitomarrero is offline   Reply With Quote
The Following 2 Users Say Thank You to Pablitomarrero For This Useful Post:
FearBoy (01-04-2014), kster1 (01-04-2014)
Old 01-04-2014, 11:03 AM   #17
kster1
kster1's Avatar
@Pablitomarrero
Did Saikou Michi sell the catch cans with the hoses? If not, do you mind sharing the specs on the hoses?
The install looks very clean.
kster1 is offline   Reply With Quote
Old 01-04-2014, 11:29 AM   #18
Pablitomarrero
Originally Posted by kster1 View Post
@Pablitomarrero
They did provide goodyear hoses. For the pcv: 30R7 or equivalent hose- 2ft 3/8" hose, 2ft 1/2" hose. The thicker hose is for return
Crankcase was 10ft of 1/2" 30R7 (return= intake). But keep in mind that this is for my greddy turbo kit so the crank hoses may vary in length but that is the correct diameter for crankcase hoses.
The Following User Says Thank You to Pablitomarrero For This Useful Post:
kster1 (01-04-2014)
Old 01-04-2014, 11:52 AM   #19
FearBoy
Drives: 2013 BRZ Limited
Nice install. I think this is the setup I'll run.
FearBoy is offline   Reply With Quote
The Following User Says Thank You to FearBoy For This Useful Post:
Pablitomarrero (01-04-2014)
Old 01-04-2014, 11:57 AM   #20
Ross
Drives: 85 corolla gts
You do have a check valve between the can and the intake manifold?
Ross is offline   Reply With Quote
Old 01-04-2014, 11:58 AM   #21
Pablitomarrero
No. Pcv already has one
Old 01-04-2014, 02:32 PM   #22
Ross
The can is before the pcv valve, you are running a sealed system. There should be one between the intake manifold and the catch can itself.
Old 01-04-2014, 02:35 PM   #23
Pablitomarrero
Saikou Michi dual catch can Build and Review!!!
When in boost the pcv valve closes. The crankcase is preassurized by blowby and therefore exits via the breather which has excelent vacume from before the turbo. Pcv works when there is actually vacuume in the manifold (eg low throttle and idle). This is why boosted tsetups tend to have more collection in breather
I dont understand why you say sealed system
Old 01-07-2014, 12:02 PM   #24
Pablitomarrero
Heres a pic of the hose routing that the installer did.
Size:  80.6 KBName:  ImageUploadedByTapatalk1389109494.878854.jpg
Size:  81.1 KBName:  ImageUploadedByTapatalk1389109683.831106.jpg
Can anyone make anything out of this? I thought routing was different but i assure you they know what they are doing. Two cans are actually connected to each other. From PCV valve it enters the top of the first can(closest to the cockpit) and exits toward a T connection. This T also recieves gases that EXIT the second can. Both of them flow towards the super vacuume in front of the turbo intake. The top of the second can recieves gases from breather side. This seems to be the best setup imo as it joins both cans together. What do you guys think? In case youre wondering, what ised to be the return for pcv on top of manifold is now used as the vacuume port for the BOV and Boost Gauge
Marcoscrdo (01-04-2015)
Old 03-23-2014, 11:04 PM   #25
Pablitomarrero
Bump for opinions on my last post a few months ago? Im kinda worried that the cans are completley dry after checking them today for the forst time... Turbo pipe and intercooler are clean insode though... No oily residue at all
Old 02-03-2015, 01:26 PM   #26
kbye
kbye's Avatar
Drives: 2014 FR-S
I came across this post while searching for saikou michi catch can review. Your catch can setup is unnecessarily complicated. All you need to do is put a catch can between each line, there is no need to connect the two cans together. I recommend you get boost readings by teeing off the brake booster line (before the check valve) into a vacuum manifold, instead of the PCV line. This greatly simplifies your setup and is how most people run their cans.
kbye is offline   Reply With Quote
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Engine, Exhaust, Transmission 23 05-15-2016 05:21 PM
Saikou Michi Catch Can Installed! Hanakuso Engine, Exhaust, Transmission 21 06-22-2015 01:40 PM
Dual Catch Can, hoses and fittings Sportsguy83 Engine, Exhaust, Transmission 9 02-21-2013 02:13 AM
Perrin Engine Mounts and Cusco Catch Can Install and Review @ Pure Automotive Pure Automotive Mid-Atlantic 9 01-31-2013 02:03 AM
dual injection is just a long overdue solution to carbon build up? Hasjwandje Engine, Exhaust, Transmission 19 11-08-2011 06:53 PM
