Old 11-28-2013, 04:45 PM   #15
Zach3794
Drives: 2013 Scion FR-S, Raven, Manual
You've got me there, I don't really know other than the weight. I just don't see the need for a 9" over an 8" in the first place at stock power..but that's just my lowly opinion.
Tuned by Delicious Tuning
http://www.delicioustuning.com/node/209
Kraftwerks Supercharged
Zach3794 is offline   Reply With Quote
Old 11-28-2013, 05:01 PM   #16
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Lots guys around here that track and auto x their cars run the 17x9 and a 245/4017. That said that tire is easy to come by in many performance tires as well for such purposes: ie BFG Rivals, RS3, etc...
As far as POKE goes up front, if you're on stock suspension just get some WL or SPC camber bolts, or HVT top hats whatever you prefer and tuck up the front tops to around -1 to -1.5 if anything you'll enjoy having camber more as the car handles FAR better IMO with front camber vs stock of 0 basically. People that do not want to have camber up front have no idea what you are missing out on. From stock to having some - camber up front for me was literally night and day in how the car can handle when driving spirited in twisties..
Old 11-28-2013, 05:22 PM   #17
mid_life_crisis
Drives: FR-S 10 #103 AT
If you want to turn the car into a gokart just about anyone can drive reasonably fast while taking away the potential for a skilled driver to do amazing things, just throw the widest rims and tires you can fit and drop it to the ground.
Last edited by mid_life_crisis; 11-29-2013 at 05:40 PM. Reason: Removed quote that didn't belong
Old 11-28-2013, 08:59 PM   #18
autobrz
Drives: Mazda 3
245 tires are slower on stock power on track because they never get enough heat in them to maximize grip
autobrz is offline   Reply With Quote
Old 11-28-2013, 09:01 PM   #19
autobrz
Drives: Mazda 3
the additional rolling resistance and resulting slower acceleration isnt made up by more grip
Old 11-28-2013, 11:25 PM   #20
blue cat
blue cat's Avatar
Drives: Toyota 86 GTS
I'm running this exact setup 17x8 +35 on stock suspension and it sits very flush. The front is almost exactly flush without poke, and the rear is slightly inside the guards. Tires are 215/45/17, so with fatter tires it would decrease that wheel gap too.
This is the only decent photo i have at the moment.
blue cat is offline   Reply With Quote
The Following User Says Thank You to blue cat For This Useful Post:
1Cor10:23 (11-28-2013)
Old 11-29-2013, 04:06 AM   #21
fatoni
Originally Posted by mid_life_crisis View Post
Sure, if you want to turn the car into a gokart just about anyone can drive reasonably fast while taking away the potential for a skilled driver to do amazing things, just throw the widest rims and tires you can fit and drop it to the ground.
well if you want to blow things out of proportion youre going to have a tough time extracting potential when you are just driving on the sidewalls on the narrowest rims possible. even if i took what youre saying without the ridiculous assumptions, there is more potential on a nine inch rim than there is on an eight inch rim. why do you think otherwise?
Old 11-29-2013, 11:15 AM   #22
wparsons
wparsons's Avatar
A 245 on a 9" wheel will be faster than a 245 on an 8" wheel, assuming the same tires and similar wheel weight.
245's on a 9" aren't stretched at all, but won't be bulging either so you'll get better steering feel too.
I'm personally running 225's on an 8" wheel (+45 RPF1's) and there is a ton of grip with good tires (I have ZII's).
flickr
The Following User Says Thank You to wparsons For This Useful Post:
whataboutbob (11-29-2013)
Old 11-29-2013, 12:34 PM   #23
mid_life_crisis
For starters, I'm assuming properly fitted tires on those rims. Starting from there, call me naive if you want, but when pretty much every suspension expert that posts on this forum has made it crystal clear that wider tires without significant other mods will ruin this delightful suspension, I believe them.
Old 11-29-2013, 01:32 PM   #24
1Cor10:23
1Cor10:23's Avatar
In your opinion, what would ideal setup be (size, width, offset, and tire specs) for stock suspension?
Old 11-29-2013, 01:53 PM   #25
gabeg86
gabeg86's Avatar
Drives: 2013 Raven FR-S
For performance on stock power levels, everyone is going to tell you to get a 17x7-17x8 wheel with 215 or 225 width tires. Offset is your preference on how you define "flush," but on those widths I'd say +35 to +40
Sent from my HTC One using Tapatalk
Perrin (LWCP) - Blox (shift knob) - HID Powerhouse (LED's and HID's) - Eibach (sportlines) - Muteki (lugs) - SPL (LCA's) - Rays Engineering (57dr's) - Dunlop Direzza ZII (tires) - Greddy (Evo3) - Full Race (turbo kit) - Ecutek (tuned)
gabeg86 is offline   Reply With Quote
The Following 3 Users Say Thank You to gabeg86 For This Useful Post:
1Cor10:23 (11-29-2013), BabaYaga (07-15-2015), mid_life_crisis (11-29-2013)
Old 11-29-2013, 04:12 PM   #26
fatoni
id like to see you support that claim. please name one person who has any evidence of a 225 tire being faster on an 8" rim over a 9" rim. i have never even made the argument that wider tires will be faster. hell, in the original post you quoted from me, i mentioned that its likely the wider tires that would be responsible for slowing you down.
Old 11-29-2013, 05:55 PM   #27
mid_life_crisis
I have never even made the argument that wider tires will be faster. hell, in the original post you quoted from me, i mentioned that its likely the wider tires that would be responsible for slowing you down.
You are absolutely correct. I should not have quoted you and have removed that from my post.
I stand by my concern, though. Properly fitted tires on 9 inch rims are too large for this car. I have real issues with function taking a back seat to style when it comes to choosing rim/tire combinations. I have never understood the logic of stretching a narrow tire over a rim that is too wide for it. It just seems like it's begging for trouble.
Old 11-29-2013, 06:56 PM   #28
fatoni
i guess we just differ on what is proper. like i said before, nine inches is only 228mm so a 225mm tire is hardly what i would called stretched. if we are really stalking about form over function, the 9" rim should be faster.
Wheel Directory: Enkei RPF1 17x8.0 +45 track_warrior Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 163 03-17-2022 02:00 AM
Wheel Directory: Enkei RPF1 17x8.0 +35 Faceless Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 70 10-12-2020 06:16 PM
FS enkei RPF1 17x8 subaruferrucci Wheels and Tires 8 05-13-2013 05:01 PM
FS: 17X8 +45 RPF1'S (TX) track_warrior Wheels and Tires 20 02-26-2013 06:07 PM
Any vendor have in stock rpf1's in black 17x8 +45 offset? track_warrior Wheels and Tires 0 06-25-2012 01:57 PM
