Old 04-11-2014, 09:19 PM   #15
Prog
Prog's Avatar
Drives: 2016 Cadillac CTS
Originally Posted by PatrickSAN View Post
Did the Metra 71-042C plug in up in the dash location?
It fit in the factory harness, but something about it didn't work...I forgot what it was. I never finished messing with the dash speakers, but I think it had to do with the tweeters...
Prog is offline   Reply With Quote
Old 04-22-2014, 01:51 PM   #16
PatrickSAN
Drives: SWP GR 5DR
Solution:
Originally Posted by KBRZee View Post
So Crutchfield sells a harness, Item# 12071042, for the dash speaker. It does not work. It fits the plug that goes to the 3.5 inch speaker but it doesn't work because the sound has to travel through the tweeter plug to get to the 3.5 inch speaker. No idea why they wired it that way.
I was about to splice the wire when I came up with this idea, that worked. I had some 14 gauge house wires laying around. I cut the ground wire into small pieces and bent them into a small horse shoe shape. Then I flattened them out with a hammer. I used them to bypass the tweeter plug so the sound can travel to the 3.5 harness, and then I used the harness from Crutchfield. Hopefully this picture can explain what I did better than I can.
PatrickSAN is offline   Reply With Quote
Old 09-07-2016, 04:24 AM   #17
Here2rock
Drives: 86 GTS
Originally Posted by MidnightRunner View Post
Ok... The stock amp sits behind the driver side rear seat btw.
Sent from my LG-P769 using Tapatalk
Any pics, I did not think that it had any separate amp.
Here2rock is offline   Reply With Quote
Old 09-08-2016, 04:47 PM   #18
PatrickSAN
Drives: SWP GR 5DR
The tweeters don't.
Old 09-08-2016, 06:13 PM   #19
jwvand02
Drives: 2013 SWP BRZ Limited
I decided to just run new wires... that way I can return to stock easily if I want to.
jwvand02 is offline   Reply With Quote
Old 09-08-2016, 06:16 PM   #20
PatrickSAN
Drives: SWP GR 5DR
That is by far the easiest way. I recommend it for any install with an amp.
The other easy way is a couple t-taps or even cutting off the connector and using some quick disconnects to revert to stock if needed.
Tweeter Wire Harness Lambo_FR-S Electronics | Audio | NAV | Infotainment 4 06-13-2018 09:08 PM
JL C5-653 mid and tweeter sure74 Electronics | Audio | NAV | Infotainment 25 02-18-2015 06:02 PM
Aftermarket Tweeter Help FRS1010 Electronics | Audio | NAV | Infotainment 9 08-02-2013 03:27 PM
Tweeter mount installation AL008 Electronics | Audio | NAV | Infotainment 2 06-02-2013 10:16 PM
1" tweeter pcporo Electronics | Audio | NAV | Infotainment 1 03-15-2013 04:02 PM
