#15 |
Drives: 2016 STi DGM
^^^ in that case, not sure why he's even asking if: when he had the light pulley ON before it was totaled and he could "FEEL" the power change/response, whatever, then why not install a pulley again, or 2 or 3...
hes pretty much answering his own question.
-2014 SSM BRZ MT
#16 |
Hadouken
Drives: Whiteout FR-S
Proud owner of the Perrin lw crank pulley and a butt dyno. Def have to say that the butt dyno can feel a difference with the LW pulley. I find it most noticeable when you have to rev match, with the OEM pulley i'd have to give it 2 quick blips, with the lw pulley one good blip is all I need. I had to swap it back to stock to take it into the dealer and I can honestly say I the feel of the Perrin.
#17 |
Drives: Asphalt Scion FR-S
I have GFB lw crank, alternator, and waterpump pulleys, as well as Raceseng idlers. I didn't notice a difference when I installed idlers on, except for rpms dropping faster. Blips are quicker. Regarding acceleration, I didn't notice as big of an improvement as when I got header and tune. I still have stock flywheel and steel drive shaft, so it will be more noticeable after lightening those.
My butt dyno was recently calibrated to Mil Spec. Edit: seems like some people's sarcasm detectors need recalibration.
#18 | |
Drives: 2013 GBS BRZ Limited
I guess "physics" doesnt apply to HP measurements. |
#19 |
No and I dont own any of that magic magnetic jewelry that cures everything either... Point?
Show me just ONE dyno run with JUST the pulley change. Even if you see a difference it is within the margin of error of dyno runs back-to-back |
#20 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
But you are right. OP, there is no negative that would occure from replacing the other pulleys, as it would in fact lower the mass. Can you notice it, maybe, maybe not. But they look nice and sure dont hurt. Fwiw I do own a crank pulley. Its cheap and easy to install so any change is good enough for me at the price. |
#21 |
Just a dude
Drives: Scion FR-S 2013
It's been well discussed what these kits do. Do they show more HP on a dyno?=no.
Do they improve throttle response = yes. Are they harmful= no. This has been well debated and documented here on several other threads and discussed by folks who understand this motors design far better then myself or anyone else in this discussion. That said I'm an engineer however personally I feel that's a terrible card to pull in conversations I see it as abit of a "listen to be because I'm superior" kinda comment. Now if someone that was a engineer for Subaru/Toyota comes on this board and had specific dealings with the design of this engine and the dynamics "YES" I will listen and respect all of what they had to say on "this" topic. Being an engineer doesn't make anyone brilliant, there are hundreds/thousands of disciplines of engineering. I'm a process engineer for example and my knowledge in this topic is limited other then my mechanical engineering in younger years. That said I have the raceseng kit, downshifts match up better and throttle response was definetly noticeable. Others that drive my car noticed immediately and I purposely didn't tell them. Each to their own.
#22 | |
Tire Destroyer
Drives: Firestorm+snail
Thanks guys, case closed. Respect and thanks to those intelligent enough to stay on topic OICU812, Finch 1750, Danthedirt, and JDKane527.
322whp/273wtq
#23 |
If you REALLY wanted to reduce rotating mass, you'd install a cam chain drive sprocket that's 1/2 as big so it spun the timing chain 1/2 as fast! LOL
#24 |
It is simple. It is called physics.
If I simplify the problem enough it is more than obvious. If you assume that JUST the rotating mass of the Pulley, crank, flywheel - Nothing else, it comes to approximately: Pulley, crank, flywheel/clutch/pp (this is the rotating mass that is balanced) 4.9lb + 25lb + 30 lb total rotating mass (NOT counting pistons or rods) = ~60lbs. If you change the pulley to the perrin: "weighs just 1.2 lbs, 3.7 pounds lighter than the stock OEM crank pulley" You just reduced the rotating mass by 4% ASSUMING that all the rotating mass of the crank and the flywheel assembly is the same diameter as the pulley! It is really less than 1%! The real answer is that changing the pulley rotating mass cannot reduce the rotational inertia of the entire engine assembly by even 1/10 of 1% or .001 "Thanks guys, case closed." BTW - I put this SH|T together and take it to my local machinist to have balanced. Any other smartasses on this thread done that lately? Last edited by stugray; 11-07-2013 at 07:59 PM. |
#25 | |
"IF you want to reduce the rotational inertia of the engine as a system, starting with the pulley is silly. It has the lowest return on investment of almost any component being so close to the center of rotation." and "I would not mess with it UNLESS you are doing a dozen other things that would make a bigger difference." BOTH of those statements were directly addressing the OPs original question. |
#26 |
Another "technical" point:
with a racing engine, anytime you change the: flywheel, pulley, crank, piston, piston pins or rods weights you need to have your rotating mass rebalanced dynamically. Changing any dynamic balance part on a performance engine without knowing how it affects balance is not a good idea. |
#27 | |
Drives: waiting on a 2021...
2016 4Runner Tail edition
2020 Camry 2020 RAV4 2013 Chevy 3500 4x4 Duramax 1999 Ford F250 Powerstroke, the tow rig 1969 Mustang, the fast car....(: |
#28 | ||
Drives: Sc10n
[ame="http://www.youtube.com/watch?v=e5VPh9LqjaI"]Worx Tuning Crank Pulley Install - YouTube[/ame] Quote:
| What is best crank pulley? | Mixlplix | Engine, Exhaust, Transmission | 49 | 10-28-2017 05:44 PM |
| Perrin crank pulley / Beatrush alternator pulley | Krimlin | Engine, Exhaust, Bolt-Ons | 7 | 08-26-2013 10:12 AM |
| Kartboy crank pulley | Turn in Concepts | Engine, Exhaust, Bolt-Ons | 5 | 05-22-2013 10:51 AM |
| NEOPLOT Crank pulley Alternator pulley& Waterpump pulley | ANREX | Engine, Exhaust, Transmission | 10 | 10-25-2012 07:45 PM |
