Old 11-06-2013, 10:34 PM   #15
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Originally Posted by SmsAlSuwaidi View Post
@FullBlown what oil do you guys run/recommend ?
On our built motors we use redline 10/30
FullBlown is offline   Reply With Quote
The Following 2 Users Say Thank You to FullBlown For This Useful Post:
DAEMANO (11-10-2013), SmsAlSuwaidi (11-06-2013)
Old 11-06-2013, 10:56 PM   #16
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
What about a stock short block ?
Old 11-06-2013, 11:07 PM   #17
MrSlay
Drives: Gx 460, FRS, Prius
Go with an actual engine builder who specializes specifically building engines.
15 FRS
12 Prius
12 ISF
15 Gx 460
My YouTube Channel
MrSlay is offline   Reply With Quote
The Following User Says Thank You to MrSlay For This Useful Post:
Sportsguy83 (11-07-2013)
Old 11-07-2013, 08:02 AM   #18
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Fabron757 View Post
I stuck between dynosty, Full blown, or accelerated to build my motor. My goal is 600hp-700hp which ever this efr7064 can produce. I've spoken to all three shops and they were helpful in explaining the break down of how they build their motors. I'm leaning towards full blown because they have the most motors sold on here an no problems reported. Also they have a company that deals with the piston design our cars came with. Plus there turn around time is reasonable.
Isn't there any reputable shops close to you? Building a motor is not rocket science. I agree with @MrSlay , get a shop that specializes in building motors.
The thing I am really picky about and consider not everyone can do is tune this ECU, but building this engine is no different than building any other engine.
Proper clearances need to be measured, proper torque values and techniques need to be used, proper lubricants and obviously proper parts need to be bought. Any good reputable shop with experience and proven results can do it.
The Following 3 Users Say Thank You to Sportsguy83 For This Useful Post:
cf6mech (11-08-2013), diss7 (11-30-2013), MrSlay (11-07-2013)
Old 11-07-2013, 08:09 AM   #19
350matt
Drives: toyota mr2/ Toyota GT86
I don't see any blocks or heads on Fullblowns' site?
is this a phone call deal only?
what do they do to the heads?
350matt is offline   Reply With Quote
Old 11-07-2013, 08:44 AM   #20
SmsAlSuwaidi
Boosted
You just need a shop that's proven and trusted which is kind of hard. Here in SoCal we had issues with subie tuners ( personal experience ) my brothers Sti took over 4 months for a basic engine build and was full off issues, and a friends Sti has been "getting built" for over 8 months
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
Old 11-07-2013, 09:09 AM   #21
Fabron757
Drives: 2013 blue frs m6 BW EFR 7064 Turbo
They have not updated their web page but if you call them they will tell you what you need to know. Yes they do heads. Yes there are plenty of shops around that do motors but this motor is new and i rather go with someone that has customers with no complaints. And my tuner that built my custom kit is the only one that touches my car. I'm @ 470rwhp@16lbs i want to turn the boost up 1-2lbs to get 500hp but not balls z enough on my stock block lol. My turbo is not running in its efficiency range yet. Once i get into the 23lbs and higher it be happy. This EFR7064 has a 52.2mm inducer and 70mm exducer. Think its just a bit smaller then a gt3071. But hopefully i can get 600hp out of it. But my goal is 700hp. If i can't get 600hp i'm swapping to the next efr size up.
http://www.ft86club.com/forums/showt...t=31807&page=3
Fabron757 is offline   Reply With Quote
Old 11-07-2013, 09:18 AM   #22
Sportsguy83
Drives: Limited BRZ
Ok, if I had to choose between your 3 options I'd say Full Blown.
Old 11-07-2013, 09:28 AM   #23
FullBlown
FullBlown's Avatar
Drives: Scion FRS
We will be adding our short block to our site today. We have sold quite a few of these so far.
Old 11-07-2013, 09:38 AM   #24
Fabron757
[ame="http://www.youtube.com/watch?v=AFLPIyWcMPQ"]Turbo FRS EFR 7064 walkaround - YouTube[/ame]
Old 11-07-2013, 10:11 AM   #25
Ross
Drives: 85 corolla gts
In all fairness to Fabron I understand him wanting to use someone that has built several of these engines. As well I believe the guys listed were beating me in price to build him an engine as I have to sublet out balancing and machining. I am sure who ever he ends up choosing will have a well put together short block.
Ross is offline   Reply With Quote
The Following User Says Thank You to Ross For This Useful Post:
Old 11-07-2013, 04:15 PM   #26
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
While building a motor isn't rocket science, there are little details that people that have built the same motor multiple times before will know about versus your old V8 engine machine shop down the street. I wouldn't want my motor to be the FA20 that they "learn" on.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
diss7 (11-30-2013), WHITE (11-08-2013)
Old 11-07-2013, 04:17 PM   #27
Sportsguy83
Drives: Limited BRZ
Fair.
Old 11-08-2013, 09:14 PM   #28
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
@Ross
Don't know if I mentioned this before, but pipe routing on Fabron's is spot in.
If/When I roll my own setup I could see it very similar.
Legit.
@Fabron757
I see your power goal, and understand you'll be on corn.
Do you or your tuner have any interest to make a refined pump gas tune on the new build?
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
The Following User Says Thank You to Floggin Tires For This Useful Post:
Ross (11-08-2013)
Who has a built motor? Fabron757 Forced Induction 77 11-19-2020 10:04 PM
Frs300 Fa20club built motor and turbo build Frs300 Member's Car Journals 32 01-18-2014 05:27 AM
Crawford Limited Turbo BRZ - built motor Mrqb22 Forced Induction 8 11-11-2013 01:34 PM
Built motor over 600hp Fabron757 Forced Induction 19 11-02-2013 04:54 PM
Fully built motor with a supercharger. Ruckus Forced Induction 38 10-30-2013 11:21 AM
