Old 10-29-2013, 11:29 AM   #15
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
I can confirm that the scaling is incorrect on the OFT for A01C (offset at -30, should be -50). Need to direct Shiv to this thread.
Td-d is offline   Reply With Quote
Old 10-29-2013, 02:12 PM   #16
jeebus
Drives: 2015 Mustang GT (on order)
I really don't understand why they won't flash 00C cars. I have an 00C car and I bought OpenFlash primarily so I could correct this issue.
jeebus is offline   Reply With Quote
Old 10-29-2013, 02:14 PM   #17
jeebus
Are you sure about that? It looks ok to me...
Old 10-29-2013, 03:01 PM   #18
Td-d
From the raw disassembly of A01C:
Code:
ROM:000CECF8 Table_Transient_Ignition_Retard:.data.w 7 ; DATA XREF: sub_6F170+6Eo
ROM:000CECF8                                         ; ROM:off_6F340o
ROM:000CECFA                 .data.w h'18
ROM:000CECFC                 .data.l flt_1184B0
ROM:000CED00                 .data.l flt_1184CC
ROM:000CED04                 .data.l byte_11852C     ; = -9.922
ROM:000CED08                 .data.l h'4000000
ROM:000CED0C                 .float 0.3515625
ROM:000CED10                 .float -50.0
From Tunerpro:
Old 10-29-2013, 04:24 PM   #19
jeebus
Code:
From Tunerpro:
does it matter if the offset is at -30 when the table values are appropriate? Or am I missing something here?
The offset for shiv@vishnu 's 00C and 01C bins is the same, but so are the values in the table.
Old 10-29-2013, 05:58 PM   #20
Td-d
That's exactly the point. Let me demonstrate it by how the ecu actually uses the values from the tables.
In 00c, the value of the first cell is 0x39. So to get the 'human readable' decimal version, convert 0x39 to decimal = 57, then multiply by the multiplier (0.3515625) which equals 20.0390625, and then add the offset (-30) which equals -9.9609375.
Now, with A01c, you want the table to also pull 9.96* at that cell. So you put in 9.96, which using the incorrect scaling as per above would translate back into 0x39. Except, the way the ecu is reading it now, is 0x39*0.3515625*-50 - so actually, you have told the ecu to pull 29.96*.
So yes - asking the ecu to pull 30* as opposed to 10* makes a big difference.
Old 10-29-2013, 07:13 PM   #21
jeebus
ok, now I see what you are talking about. I apologize for misunderstanding before. 01C actually uses -50 in its conversion of the cells for the transient ignition retard table, however Shiv's definitions have -30 in the conversion because that's how it WAS done in the 00c ECU...so while the table looks correct in 01c, it's actually 20 degrees off everywhere. GOT IT.
WHY THE CRAP WOULD THEY CHANGE THE CONVERSION in the later ECU? And is it really just for that table alone?
Old 10-30-2013, 05:32 AM   #22
Td-d
No problem, it is pretty dry stuff!
No idea, really bizarre - I've disassembled well over a hundred roms, and this is the first time I've seen this.
Old 10-30-2013, 05:35 AM   #23
ft_sjo
Drives: GT86
Why wouldn't they change the definition? It's their prerogative, they don't own the 'community' anything.
As to why, though, who knows. Maybe something else hooks into it that required it.
Old 10-30-2013, 06:44 AM   #24
Td-d
Sure - I don't recall anybody even vaguely insinuating otherwise.
Not likely. There is very little churn within Subaru ecu sub models of code, let alone scaling. And these two roms have the calibration in identical ROM locations, bar this one change.
Old 10-30-2013, 10:16 AM   #25
jeebus
Has anyone verified this through datalogs between shifts? Not that I don't believe it, but it would be lovely to see 100% proof of it before people start tweaking the definition.
Old 10-30-2013, 01:32 PM   #26
strat61caster
strat61caster's Avatar
There are logs showing a knock detection during shifts, I can't find it at the moment but it's somewhere in this forum.
ineedyourdiddly
Old 04-28-2014, 04:59 PM   #27
ayau
Drives: Some rust bucket
Bring this thread from the dead. Just an FYI, both Scion and Subaru have posted a TSB to update people to the ZA1JB01C calibration file. I just got mine updated. It feels like the initial throttle has a little "lag".
Old 05-08-2014, 09:15 PM   #28
dsgerbc
Drives: BRZ(sold), STI
Did your dealer update you or not? Mine appears to have left me on ZA1JA00C after doing the RPM drop TSB.
dsgerbc is offline   Reply With Quote
First romraider defs are up jamesm Software Tuning 95 01-13-2015 05:29 AM
FRS Ignition Key ft86Fan Scion FR-S / Toyota 86 GT86 General Forum 120 07-22-2014 09:23 PM
My car seems slow ... do these car retard for bad gas? rskdsk Scion FR-S / Toyota 86 GT86 General Forum 46 09-24-2013 01:34 PM
Ignition vs Argento? Pacific Auto Scion FR-S / Toyota 86 GT86 General Forum 3 08-17-2013 04:24 PM
Can DBW tables be changed via Ecutek tune??? Norkoastal Engine, Exhaust, Transmission 1 09-11-2012 06:51 PM
