Old 10-23-2013, 03:54 PM   #15
topazsparrow
Drives: slow
Originally Posted by TylerLieberman View Post
RWD is extremely dangerous and should not be considered by a novice driver. Too much aggressive driving will cause you to go into over-drift and drift into another dimension.
FILLED WITH DINOSAURS!!!!
Nah, just granny-shift it with the double clutch in.
topazsparrow is offline   Reply With Quote
The Following User Says Thank You to topazsparrow For This Useful Post:
Squishy86 (10-23-2013)
Old 10-23-2013, 04:02 PM   #16
Rampage
Senior Member/Old Fanboi
Rampage's Avatar
Drives: 2000 2ZZ-GE MR2 Spyder HT
Originally Posted by Whitigir View Post
RWD has oversteer, FWD have understeer problem.
RWD = pretty much bad in the snow, where you loose traction and got stuck.
RWD = Fun Factors
FWD = Safe and Easy
Not so. Understeer and oversteer are almost always due to where the engine mass is located, no so much which wheels are driven. For example the Camaro, Mustang, Challenger and Cadillac CTS-V are all front engine-rear wheel drive. They all understeer when pushed hard. Porsche 911s were famous for their oversteer charecteristics and they are RWD but they are also rear engine.
Any car, including both FWD and RWD can be engineered to be nuetral or oversteer through use of tire sizes, sway bars, struts/shocks and other suspension tweaks. They do that in race cars all the time but for road cars and the average mom and pop (and son) drivers understeer is almost always safer.
Rampage is offline   Reply With Quote
The Following User Says Thank You to Rampage For This Useful Post:
jblmr2 (10-23-2013)
Old 10-23-2013, 04:02 PM   #17
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
This WILL happen if you are a noob with RWD
[ame="http://www.youtube.com/watch?v=N2IWxqvsSY8"]Overdrift - YouTube[/ame]
TylerLieberman is offline   Reply With Quote
The Following 4 Users Say Thank You to TylerLieberman For This Useful Post:
Diode Dynamics (10-23-2013), Evil Jesus (10-23-2013), humfrz (10-23-2013), SportInjected (10-23-2013)
Old 10-23-2013, 04:03 PM   #18
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
I've always been a fan of AWD so I'm still a bit weary of having a RWD as my daily driver here in the winter. I'm hoping that with the LSD and traction control and decent winter tires, I should at least have enough grip to give me control and traction through the slippery conditions.
The thing about FWD is that even though it may technically have a little more weight over the axle, it still torque steers and doesn't do THAT great in the snow. I may actually prefer RWD over FWD in the snow as it will likely give me a little more handling capability. But there is a fine line between fun and scary so I worry that it may cross over into out-of-control zero-traction situations whereas my current AWD Eclipse never puts me in that situation; it's fun when I want it to be but always has just enough traction to get me through things.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 10-23-2013, 04:27 PM   #19
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
Originally Posted by Suberman View Post
Understeer is always safer. Understeer is always quicker.
ALL modern road cars understeer at the limit. Only excess engine torque can induce oversteer in a road car. There are those who claim some cars, particularly fwd hot hatches, will oversteer but this is technically inaccurate. Drop throttle induced oversteer is not a result of chassis behaviour or characteristics but of deliberate driver induced instability and is of very little use for quick road driving. Ditto inducing oversteer in our gloved BRZ. That's just poor driving to be honest.
Unless there's too much power for the drive wheels to put down onto the road fwd will always be quicker.
Only when the engine torque significantly overwhelms the drive wheel traction will rwd be quicker.
There is a myth that rwd is "better" but it just isn't.
The only real advantage rwd has in a low powered car is driving feel.
The oversteer you get in the BRZ actually slows the car down significantly. Better tires are the answer to get what little power there is down onto the road and driving the car forwards. Sideways may be exciting but it is very slow.
holy shit what are you smoking. Oversteer is faster than understeer. I know companies set up their stock cars to understeer more for the "general public" because it's safer, but imo that makes them more dangerous.
bkblitzed is offline   Reply With Quote
The Following User Says Thank You to bkblitzed For This Useful Post:
FReSh (10-23-2013)
Old 10-23-2013, 04:39 PM   #20
fatoni
how does making something more safe make that same thing more dangerous?
Old 10-23-2013, 04:40 PM   #21
Sarlacc
/dev/null
Sarlacc's Avatar
Drives: Uphill
That whole understeer/oversteer thing applies to winter conditions, too.
When a FWD loses traction on ice it basically goes straight into the surrounding geography.
When a RWD loses traction on ice you still have a chance to steer, using the gas pedal.
It is of course highly recommended to practice this before getting into that kind of pickle on public icy roads.
Personally I take every opportunity I get to practice RWD ice skating skills, and try hard to avoid having to use them when there's oncoming traffic.
Saved my life, or at least my car, several times in the past though.
The Following 2 Users Say Thank You to Sarlacc For This Useful Post:
Evil Jesus (10-23-2013), jblmr2 (10-23-2013)
Old 10-23-2013, 04:49 PM   #22
muffinz
Drives: 2013 DGM BRZ Ltd
I hope this is a troll and you aren't serious.
Please learn about vehicle dynamics and then try to tell us something that isn't total nonsense.
muffinz is offline   Reply With Quote
The Following 3 Users Say Thank You to muffinz For This Useful Post:
Braces (10-23-2013), Evil Jesus (10-23-2013), FReSh (10-23-2013)
Old 10-23-2013, 04:57 PM   #23
MightyMeeple
Slower than Fast
MightyMeeple's Avatar
Drives: BRZ Limited 6MT
Originally Posted by WolfpackS2k View Post
^^I'm gonna have to go ahead and disagree with a fair amount of your post. If a vehicle is FWD that means it's weight distribution is grossly imbalanced and it's polar moment of inertia is far from idea. Both anathema to a naturally good handling car. You can't beat the laws of physics.
And lift throttle oversteer, mainly for FWD sporty cars, is most certainly helpful in getting that vehicle to rotate in turns. A little bit of oversteer in a turn is always faster than a little bit of understeer.
Sure, almost all cars these days are tuned to understeer at the limit. But that's because mandatory driver training is practically non-existent and because (at least in the US) someone is always looking to sue automakers for things that aren't their fault (see: Toyota's runaway acceleration).
What he posted. I absolutely agree that the steering feel, but probably as important is the better weight distribution is better with RWD. FWD, in general, is going to be porky up front and lighter over the rear tires...and that isn't good for cornering.
I've owned 2 RWDs, 2 FWDs and a quattro...the RWDs handling and driver feel are tons better hands down.
MightyMeeple is offline   Reply With Quote
Old 10-23-2013, 05:00 PM   #24
Dipstik-sportech
Dipstik-sportech's Avatar
Holy shit man you need to be wearing a helmet at all times if that's what you think. So a rally car would be faster if it understeered, oversteer is used to rotate the car rather than it plowing straight into a tree.
The Following 2 Users Say Thank You to Dipstik-sportech For This Useful Post:
Old 10-23-2013, 05:07 PM   #25
bkblitzed
is better than you
bkblitzed's Avatar
For the more experienced drivers, when you're oversteering you still have control of the car, but when you're under steering you lose some of the control
Old 10-23-2013, 05:13 PM   #26
fatoni
being experienced has nothing to do with a car being fast. also, that makes no sense at all. why are you losing control if you are understeering but maintain control when you are oversteering?
Old 10-23-2013, 05:18 PM   #27
PR FR-S
Drives: 2013 FR-S, Asphalt
Has nothing to do with the thread but i just realized that I've never owned a FWD car...
PR FR-S is offline   Reply With Quote
The Following User Says Thank You to PR FR-S For This Useful Post:
BRZ21 (10-23-2013)
Old 10-23-2013, 05:34 PM   #28
BRZ21
i kill cones.
BRZ21's Avatar
Drives: around cones in a parking lot
same.
93 suburban
97 mustang
13 brz
and I drifted all of them
2013 SSM BRZ Limited 6MT
BRZ21 is offline   Reply With Quote
rear end difference between the frs and the brz charlesandrew22 Scion FR-S / Toyota 86 GT86 General Forum 4 07-06-2013 03:55 PM
WTB: CHEAP rear wheel drive practice drift car Juurian Canada Classifieds 0 05-16-2013 10:39 PM
TGIF[R-S]: Can You Drive a Rear-Wheel Drive Sports Car All Year Long? No5ki Scion FR-S / Toyota 86 GT86 General Forum 27 01-06-2013 08:30 PM
Subaru BRZ rear wheel drive - WHY? Hawk77FT AUSTRALIA 86 11-25-2012 06:37 PM
Rear lights difference… gtaqv Scion FR-S / Toyota 86 GT86 General Forum 15 01-26-2012 11:59 AM
