Old 08-22-2015, 05:15 PM   #15
why?
Only happy when it rains.
why?'s Avatar
Drives: series.blue
When I do look into coilovers it will be very hard for to look past Fortune Auto. Everything I've seen from them and about them is great.
I guess if it is a trailer queen show car then it doesn't matter how cheap they are.
Old 08-22-2015, 06:20 PM   #16
KenTK808
Drives: White 2014 Scion FRS
If you want to hear from someone who has actually had experience with this brand, not just here say. I had them on a civic. Only reason I was running them was because the car I got had them on already. I know for a fact that they are not meant to go low because the struts gave out after three months being on the lowest height. I highly doubt they match the spring rates to the amount of dampening the struts give. After I pulled them off the car, they actually did not look bad or cheaply made. I have had Ebay no-name coil overs before, and the Racelands are aesthetically better looking. Looks can be deceiving though. I think they are for people on a budget that want a mild drop, but arnt looking for any performance gain. In the case of the FRS I highly highly highly doubt these will handle better then the stock suspension. They do come with the adjustable sway bar links though, which is good. You are better off buying Eibach drop springs.
KenTK808 is offline   Reply With Quote
Old 08-30-2015, 01:22 PM   #17
reardrv
Drives: 2013 Subaru BRZ
No, no, no, no, NO!!!! I purchased an NA Miata to use as a track day/hillclimb car and it unfortunately came with Raceland Ultimo's. The Racelands on it had never been driven on and where brand new. They are horribly under dampened, especially in the rear, and the spring rates are beyond wrong. Because of this the car is prone to snap oversteer, making it slow on an autocross course and IMO to dangerous to use on a hillclimb. I took it for a couple of laps around Canaan Motor Speedway which is a brand new road course that was just paved this spring and even with the new mirror smooth pavement the Racelands still had issues coping, causing sudden oversteer that was more annoying than anything.
As for road manners, they creak, they have a jarring ride, and if the road is bad enough the rear bounces like the dampeners are blown. All this trouble mind you are at 12.5" front and 13" rear fender to hub distance, that's a pretty conservative ride height for an NA Miata. When I first got the car it was significantly lower, allowing it to bottom out constantly making the car virtually unbearable to drive and border line unsafe.
I've owned and driven many different cars on many different suspension setups and I can safely say that this is by far the worst setup I have ever encountered. Do not ruin your car by buying these because that is exactly what you'll be doing.
reardrv is offline   Reply With Quote
Old 08-30-2015, 01:50 PM   #18
fx35s
Bad coilover is worse than the stock suspension. You might as well just get the firmer springs and have a better suspension setup yourself. Don't get those raceland craps
fx35s is offline   Reply With Quote
Old 08-30-2015, 05:25 PM   #19
BigRuss
BigRuss's Avatar
Drives: TBD
I had them on my xB for a few years and they did their job. No problems, but it was meant to be a low and slow cruiser, but I wouldn't put them on the car if you plan on being spirited with the car
Shopping for my perfect BRZ.
BigRuss is offline   Reply With Quote
Old 08-31-2015, 11:19 AM   #20
shifter907
Lurker
shifter907's Avatar
Drives: '14 BRZ Ltd 6MT
I had their standard coilovers on my B5 Passat in Germany, and did 5 laps of the Nordschleife with no problem.
But I bought Ultimos for my MKV GTI and the rear struts didn't even last 2 months, so I replaced them with Koni Yellows.
Instagram : @brampbell_candon
Facebook : Hipster Vision Photography
shifter907 is offline   Reply With Quote
Old 08-31-2015, 10:26 PM   #21
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
no. just say no.
Jive Turkey is offline   Reply With Quote
Old 09-02-2015, 09:43 AM   #22
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
Originally Posted by Jive Turkey View Post
no. just say no.
+1
-mike
AZP Installs is offline   Reply With Quote
Old 09-02-2015, 03:53 PM   #23
bufu07
bufu07's Avatar
Drives: '03 WRX, '15 BRZ
no. just say no.
+1
-mike
Not even once.
bufu07 is offline   Reply With Quote
Old 09-02-2015, 09:41 PM   #24
ka-t_240
ka-t_240 is offline   Reply With Quote
Old 09-05-2015, 03:57 PM   #25
Myth21
Drives: 2012
Myth21 is offline   Reply With Quote
Old 09-05-2015, 04:49 PM   #26
Myth21
Drives: 2012
Old 09-05-2015, 09:24 PM   #27
fatoni
Originally Posted by Myth21 View Post
An s2k was $30-$35k brand new.
So?
Drive upgrades. Don't buy them.
Old 09-05-2015, 10:37 PM   #28
Myth21
Drives: 2012
Originally Posted by fatoni View Post
So?
Lol I must've been reading a different thread at the same time, I thought I read miata, civic, s2k in here
Beatrush Mounts ,BC BR, Bilstein, ISC N1, ST Coils, KW Coils and Stance Coilovers b2autodesigns Brakes, Suspension, Chassis 818 09-10-2017 09:33 AM
Coilovers Coilovers, Coilovers: Tein, KW, BC, D2, Cusco, Eibach + more FREE SHIPPING! No Limit Motorsport Brakes, Suspension, Chassis 204 05-26-2017 01:09 PM
>>>>>>>WANT HIGH-END COILOVERS? LOOK HERE ~ New ST Coilovers l KW l Racecomp l Ohlins Circuit Motorsports Brakes, Suspension, Chassis 230 02-17-2016 01:01 PM
Raceland Coilovers.... $499 glorydays Suspension | Chassis | Brakes -- Sponsored by 949 Racing 71 12-30-2014 09:38 AM
M7 JAPAN COILOVERS for SCION FRS SUBARU BRZ, JDM COILOVERS AMPLIFIED MOTORSPORT Brakes, Suspension, Chassis 0 08-16-2012 03:45 AM
