Old 11-16-2013, 01:18 PM   #15
TheBatman
TheBatman's Avatar
Drives: Scion FR-S 10 Series
Nice! I already have a TapTurn and love it. Might have to upgrade to the new model with strobe.
TheBatman is offline   Reply With Quote
Old 11-22-2013, 07:34 PM   #16
raptor87
Drives: 2013 DGM BRZ Ltd
Originally Posted by JPxM0Dz View Post
This is a 120 second mod. Lay down under dash with flash light. Disconnent cable from stock relay. Use a cable tie to secure the the new relay leaving the stock relay alone. Plug in harness. It doesn't need to be anymore complicated than that
Sent from my GT-I9500 using Tapatalk
yeah that's what i did pretty much except the cable tie i just stuffed the thing up there somewhere. its been working fine for almost a year now.
raptor87 is offline   Reply With Quote
Old 01-12-2014, 03:57 PM   #17
White64Goat
Installed mine just a while ago and here are some additional pictures that may help with install.
In the first picture you see the flasher, white clip and the metal brace. 2 10mm bolts (red circles) removes the cross brace and makes it way easier to get to the flasher. Flasher is on the left side of the column.
In the 2nd picture you want to insert a long thin flat bladed screwdriver on the right side of the white clip (red line) between the clip and the dash brace. In the drawing in the 4th photo (I'm no artist) you will see that the clip has a horseshoe type U-shape to it that goes into the dash brace hole and that is in essence sort of a spring loaded type attachment. You want to try and push the horseshoe part towards the left as you twist the screwdriver counter clockwise to pop the clip out of the hole.
3rd picture is the flasher unit itself and how it is oriented under the dash. To remove the white clip from the original flasher you have to lift the beige tab from the firewall side of the flasher to slide the clip out.
Now, the bottom picture is of the main wiring harness crossing under the steering mechanism and where the red line is is where I found my harness pressed hard against the bottom edge of the steering unit. The factory has installed a black sleeve over the blue wires because this harness is going to rub/vibrate (at least on my car) against the steering unit. I rolled up a small piece of bubble wrap and shoved it between the wires and the steering unit. While you're in there installing your Tap-Turn, check your harness. This, a few years down the road, could be a problem that will arise. I've seen a power steering hose eat its way into a wiring harness under the hood and that was a rubber hose, so I can't imagine that rubbing/vibrating against a metal edge won't do the same thing over time.
Old 05-09-2014, 06:44 PM   #18
johnnyfast11
Drives: none yet
i sent you PM!
WANT!!!! so if i just want 2 blinks (called the tapturn?), then i turn "off" on the strobe?
should the ING/always switch be where? "Always" im assuming?
i dont want 3 blinks, just 2.
thanks.
johnnyfast11 is offline   Reply With Quote
Old 05-12-2014, 09:18 PM   #19
scottmcphee
scottmcphee's Avatar
Drives: 06 Subaru Legacy
There is no more switch on strobepack, this one KAR had was an early prototype.
Everything is controlled in soft settings now.
TapTurn flasher learn more here.
scottmcphee is offline   Reply With Quote
Old 05-25-2014, 05:16 PM   #20
xcelir8brz
Drives: 2013 BRZ Limited
Originally Posted by scottmcphee View Post
PM me !
I have a tapturn. Would like one with strobe option. How?
Sent from my SCH-I545 using Tapatalk
xcelir8brz is offline   Reply With Quote
Old 06-02-2014, 03:25 AM   #21
BlueThunder
Drives: brz
sry but what does this flasher do that the stock one doesn't?
BlueThunder is offline   Reply With Quote
Old 06-02-2014, 01:56 PM   #22
mackdaddytran
mackdaddytran's Avatar
Drives: Toyota Skyline Type-R
soft touch 3 blink
strobe function for hazards/signals
elminates hyperblinking with LED signals
plus a couple other functions im missing. Read their website for all the features
mackdaddytran is offline   Reply With Quote
Old 06-11-2014, 06:50 PM   #23
BRZGM3
BRZGM3's Avatar
Drives: CBS brz limited
So I replaced my flasher when I got my toms tail lights. If I bought one of these will I have any issues with my toms??
BRZGM3 is offline   Reply With Quote
Old 06-14-2014, 12:29 AM   #24
scottmcphee
Works perfectly with TOMS tail lights!
Scott
TapTurn flasher - convenience signaling for LEDs or stock bulbs! scottmcphee Exterior Parts - Lighting 120 09-22-2017 01:45 PM
TapTurn - best signal flasher upgrade for FR-S BRZ scottmcphee Audio/Visual, Electronics, Infotainment, NAV 160 03-30-2015 11:15 PM
My New LED+TAPTURN=COOL KAR Cosmetic Modification (Interior/Exterior/Lighting) 0 10-09-2013 02:26 AM
FS: gently tested TapTurn flasher scottmcphee Exterior Parts (Aero, Lighting, Etc.) 7 09-02-2013 11:14 PM
Blue/Red Strobe Lights? 636 Cosmetic Modification (Interior/Exterior/Lighting) 15 11-04-2012 10:10 PM
