Old 10-21-2013, 03:00 PM   #15
TOTO_86
TOTO_86's Avatar
Drives: Scion FR-S
That's awesome! lol
TOTO_86 is offline   Reply With Quote
Old 02-18-2014, 11:28 AM   #16
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
Same issue here - it began when it got cold out. Pretty much happens every start up but no codes.
I'm not concerned about it.
robwbright is offline   Reply With Quote
The Following User Says Thank You to robwbright For This Useful Post:
SSchifko (02-18-2014)
Old 02-18-2014, 11:44 AM   #17
kevman_101
Drives: 2013 Scion FRS
DI seals would pop all the time at any temps. The cat warmup will only do it on pretty cold days and stop after a few minutes. Mine only did it late in the fall when the temps got close to 0c.
kevman_101 is offline   Reply With Quote
Old 02-13-2015, 12:58 PM   #18
Jfheisenberg
Jfheisenberg's Avatar
Drives: 2015 BRZ Series Blue WRB
Originally Posted by Wepeel View Post
Yeah mine are like that. It's captured pretty well here:
http://www.ft86club.com/forums/showp...58&postcount=3
Although mine doesn't pop that much, but the sound is similar. But usually I start driving earlier and I never get those sounds other than on occasional cold startup.
I don't think it's DI seals since I have an 01C cal and still under 5k miles.
The lean misfire thing makes sense - I just switched from E0 to E10 and the first cold startup on E10 it popped more than it ever has before - probably because fuel trims were dialed back for E0, and as a result E10 was probably running a little lean before the ECU had a chance to learn and adjust fuel trims.
I notice the same sound (even i can feel it a light rumble) when starting up my car this morning. It was a very cold morning in jersey (it felt -10 F). it only happens for the first 15 seconds that the car is starting up. Then it goes away and never hear it or feel it when driving.
Should i be concern?
Jfheisenberg is offline   Reply With Quote
Old 02-13-2015, 01:24 PM   #19
Nope. Until the engine warms up a tad you can and will get some bad ignition. If it continues after warm then start to worry.
Old 02-13-2015, 01:28 PM   #20
D_Thissen
D_Thissen's Avatar
Nah I wouldn't be. I get the same thing when its colder than -20C (-4F). If I have the car plugged in for a few hours it never happens. Maybe post a video?
Old 02-13-2015, 01:57 PM   #21
Jfheisenberg
I'll try to record a video if it happens again., thanks!
The Following User Says Thank You to Jfheisenberg For This Useful Post:
D_Thissen (02-13-2015)
Old 02-14-2015, 04:38 PM   #22
Jfheisenberg
Originally Posted by afx View Post
is that sound you are talking about? Please, vol up! Can be heard clearly 33-35
GT86, 98 fuel, St Petersburg, Russia
sec
Yes mine does the same thing when is very cold outside. It goes away after the car is warmed up. I read on the forum and somebody its said that is related to the cat warming up and stuff like that. Im not worry about it the car drives fine.
Old 02-18-2015, 09:21 AM   #23
I don't think it is "ok". Typical symptoms of dying injector seals. Time to search for tune!
Tapatalk
Why automatically jump to the conclusion of "dying injector seals"? Very cold systems act strange and as long as it clears up when warmed then it does not immediately mean there is a failure.
afx (02-18-2015), Jfheisenberg (02-18-2015)
Old 02-18-2015, 09:51 AM   #24
Jfheisenberg
The car has about 500miles on the odm. Its not doing that anymore (and its still doing cold starts). Maybe it was doing that because the car was too new.. anyways worth case i'll take to the dealer, i have 6 year subaru gold extended warranty.
Old 02-18-2015, 09:52 AM   #25
Stang70Fastback
A.K.A. Starlord
Stang70Fastback's Avatar
Drives: 2015 Series.Blue
You can add me to the list. Pretty sure it's "normal" as I've asked some other local owners and the same thing happens to them as well.
Stang70Fastback is offline   Reply With Quote
Old 02-18-2015, 09:53 AM   #26
With that few miles the ECU would have still been learning so that could be a big part of it.
Not much sense taking to the dealer since it has stopped and they can't replicate it they won't do a thing.
Old 02-18-2015, 10:24 AM   #27
nivek111070
Drives: 2014 GB Scoobie BRZ
okay first off, that's not normal, notice when it happens in either video the RPM's immediately drop off about 300?
nivek111070 is offline   Reply With Quote
Old 02-18-2015, 10:24 AM   #28
Jfheisenberg
Agreed, the car overall feels better as miles goes up.
Tcoat (02-18-2015)
Cold start question retrosmiths Scion FR-S / Toyota 86 GT86 General Forum 106 11-15-2016 03:14 PM
Cold start up popping noise Weeber Issues | Warranty | Recalls / TSB 51 09-23-2016 01:54 PM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 06:05 PM
Cold Start Exhaust Volume SilentMike Engine, Exhaust, Transmission 15 04-04-2013 11:49 AM
Loud cold start and mpg drop since new be6sti Issues | Warranty | Recalls / TSB 7 11-28-2012 02:35 PM
