#15 |
Drives: 2013 FR-S Argento
Is your car new? If so break it in first, it picks up some pep in the first few thousand miles. In those few thousand miles learn the car and get comfortable with how it behaves. Then go ahead and get your car tuned - OpenFlash, EcuTek, BRZEdit, or the new ECUFlash software coming out soon. Won't provide massive gains but will make your car feel more responsive overall, and will be necessary down the road if you go further with the mods.
Regarding the 'torque dip', just learn to drive around it - I drive in two 'modes'. One is just driving around mode where I upshift around 3500, which drops revs revs right back into the nice lower torque 'bump'. Mode 2 is 'fun' mode, I don't upshift before 5500, which would drop your revs to right at the upper edge of the torque dip. BTW I used to own a 1973 911 S, still hate myself for selling it! Once you get comfortable with tossing it around, the FR-S is likely quicker than your 1969 (unless it's hot rodded) and definitely faster around the bends (especially with good performance tires instead of the factory rubber). Enjoy! |
#16 |
Drives: C6 Corvette Z06
I guess you need to ask yourself is if ~185WHP is enough with full bolt on going N/A.
There is no denying going forced induction is going to be some good power. At any rate a tune is necessary for whichever route you go and so is a header if you go with a supercharger. If you go turbo you won't need the header by no accident. |
#17 | |
Drives: 2014 BRZ Limited
As much as I enjoyed them I have gotten somewhat spoiled in later years by the power of my M3's, my current 911, my 3rd gen RX7 twin turbo etc. Although I did retro when the Miata's first came out. I keep trying to remind myself that the 69' 911T had 125 HP and a 0-60 time of 9.6. Dang, it sure seemed faster than that. That's what a small light car will do for you. |
| The Following User Says Thank You to RSH For This Useful Post: | FT86Z (01-02-2016) |
#18 | |
See above for my 911T, I looked up the specs. Maybe it seemed so fast because I was coming from the 96 HP 356. |
#19 |
Drives: gts 86
why not go the headers and a header back with a flex fuel kit to run e85. There's been some really good looking torque output with these setups. Almost as good as some supercharges running 10 psi.
#20 | |
But as you can see from the above post on my 69 911, it is all weight and size and that is precisely why I bought the BRZ. During my lifetime almost every great sports car introduced grew in weight, size and horsepower until it became almost unrecognizable. That is true of my current 911 and also of my E36 M3 compared to my E46 M3. In my view they were not improvements. |
#21 |
We get 93 and I've always had premium fuel cars. I can't honestly say there is E85 around but there very well may be. I'll start looking.
#22 |
i'd go fi. no need to piss around, just get it done. leaves more power on the table for when you inevitably get bored with it as is.
#23 |
Drive it & enjoy it for at least 5-10k miles and then maybe make a choice? That'll give you plenty of time to get used to the car and figure out what you want out of it.
An innovate supercharger should fix all your torque needs, and at ~$3500 is a pretty good bargain. Only downside is I've heard lots of probs with people in high heat and/or 91 octane, because it doesn't have an intercooler. Or you could do header + tune + drop in filter for ~$1500 and have a moderate boost in torque & power. This will also go well with the S/C. Either way, this car is lots of fun and I'm sure you'll have a blast. |
#24 |
the tuna, no crust.
Drives: 2014 Hachiroku of the year
honestly, if i'm driving spiritedly i'm usually well above the dip in rpm's so the car has plenty to pull itself out of a corner.
you can always go header, and then ad FI down the line. there are a few good v-band headers on the market that make that possible. since you've driven cars with similar platforms i really don't suggest FI be your route to go, its plenty fun with suspension and a tune. if you're local i'd be more then happy to meet up and show you what i'm on about. |
#25 | |
#26 |
the tuna, no crust.
well if you're ever in NJ shoot me a pm. i might be down that way come spring, but i'm not sure.
regardless if you're into driving this car with suspension and tires is a pure joy. can it use more power, sure...so can any other car. i love mine as is, idc that i can lose to everything in a straight line, it has plenty of power to over take people when needed and on track/auto-x/exit-entrance ramps/anything but a straight road not much will keep up. the speed this car carries through turns will blow your mind. its a joy. but honestly, everyone is different, buy it and drive it as is and see what you want to change. |
#27 |
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
FWIW from my N/A and Tuned build I managed 35+ rwhp
Base "STOCK" 86: ~132 hp My Modified 86: 168.1 hp DELTA: ~36.1 hp ================================================== ======================= STOCK CAR DETAILS: Toyota 86 GTS(Black) - NON MODIFIED FUEL USED: Unknown ------------------------------------------------------------------------------------------------ MY MODIFIED 86 DETAILS FUEL USED: United P100 Intake - HKS Cold Air Feed(with 3x ducting holes cut out in front bumper) - TRD USA Intake Exhaust - HKS 4-2-1 Equal Length Headers(NO CAT), has O2 Sensor bung to fool computer there is a CAT - MOTIV Concepts Overpipe - MOTIVE Concepts Front Pipe(with HFC) - HKS Spec-L Cat Back Exhaust MISC Mods - The DriveShaftShop Carbon Fibre Drive Shaft ------------------------------------------------------------------------------------------------ I believe S/C will net you an easy 70 hp at least. Happy atm with my setup, will have to see how I go against the S/C guys on track day in the middle of summer in two months time
#28 | |
Don't care
Drives: 2013 Whiteout FRS
| The Following User Says Thank You to lickitysplit For This Useful Post: | stevo_12v (10-26-2013) |
| Drift Office Tune vs Visconti Tune | mechaghost | Engine, Exhaust, Transmission | 109 | 07-03-2014 01:57 AM |
| SARD Japan Header & Mid-Pipe & Header & ECU | nigel-jdmparts | Engine, Exhaust, Transmission | 63 | 01-21-2014 01:20 PM |
| Borla UEL Header, works automotive parts and ecutek tune | clayrush | Engine, Exhaust, Transmission | 14 | 06-27-2013 04:37 PM |
| Should I buy my header or get a tune this week? | Jtymay92 | Engine, Exhaust, Transmission | 27 | 06-20-2013 04:55 PM |
| Dynotronics and their E-Tune/ OTA tune. | Ricepuddin | User/Vendor/Sponsor Reviews, Feedback, Comments | 5 | 12-24-2012 10:53 AM |
