Old 10-17-2013, 10:02 AM   #15
WhiteFR-S
Drives: 2013 BRZ MT WRB
i had the single delete on in the video and last night i had a friend weld in a 12" resonator in the piping between the two exits on the dual delete that i have. it got rid of the rasp but not much of the drone....
WhiteFR-S is offline   Reply With Quote
Old 10-17-2013, 10:21 AM   #16
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Originally Posted by WhiteFR-S View Post
header is catless. stock every thing else. except the berk delete. I have both a single exit and a dual exit muffler delete. I have the single exit on in that video because drone from the dual exit is ridiculous. trying to find a solution to cut drone. I ordered some inserts you can put in the exhaust tubing or right in the tail pipe. supposed to cut drone significantly should have that by Monday.
Originally Posted by Admired View Post
Yeah im getting horrible rasp with the dual muffler delete with uel headers and catless fp and overpipe. Do you think these inserts will help with my situation with the raspyness? Where did you get these?
Here is how you fix the drone and rasp, I had a Berk dual delete for a couple months then sold it and got the WORKS AB-M.
Zero drone/rasp anywhere.
http://www.86-zn6.com/WORKS-ABM-Axle...aust_p_48.html
Old 10-17-2013, 10:39 AM   #17
Admired
Drives: 2013 Scion FRS
Yes I have seen this but it looks like the muffler is the same size as OEM so it would seem like it would tame it too much. I decided to go with a Invidia N1 system
Admired is offline   Reply With Quote
Old 10-17-2013, 10:43 AM   #18
ATL BRZ
ATL BRZ's Avatar
The muffler is actually much smaller than OEM.
^WORKS
^OEM
The N1 is also a really nice exhaust.
Old 10-17-2013, 10:46 AM   #19
Admired
Touche, I stand corrected, you are right it is smaller. I'm just praying that the N1 with headers, overpipe and catless fp will be the sound im after. Very loud with little rasp. If not I'm going to sell the N1 and get this AB-M
Old 10-17-2013, 01:57 PM   #20
twag4
Drives: frs
[QUOTE=ATL BRZ;1275696]The muffler is actually much smaller than OEM.
It also appears only the right side is muffled
twag4 is offline   Reply With Quote
Old 10-17-2013, 02:09 PM   #21
DJCarbine
Thupercharged
DJCarbine's Avatar
N1 with header has rasp/drone with a catless frontpipe.
Its not terrible.... but a resonated front pipe will help
2013 FRS
Vortech V3 11psi
Old 10-17-2013, 02:13 PM   #22
Admired
Im sure there will be drone/rasp but im just hoping not as bad as with the dual muffler delete
Borla UEL Header, Full Catless exhaust, Stock Midpipe, Berk Muffler Delete evilconcarne999 Engine, Exhaust, Transmission 34 03-24-2014 02:39 PM
Installed Borla (plus my muffler delete) WhiteFR-S Engine, Exhaust, Transmission 4 10-04-2013 11:32 PM
WTB Berk Dual Exit Muffler Delete or Works AB Delete Admired Want-To-Buy Requests 2 09-10-2013 05:20 PM
GoPro Video from Autox #1 Portland Intl Raceway FRS w/borla header/muffler delete JesseE Tracking / Autocross / HPDE / Drifting 3 03-18-2013 12:53 PM
Muffler Delete sound without deleting muffler sw20kosh Engine, Exhaust, Transmission 10 01-30-2013 06:09 PM
