#15 |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
also Shiv,.. do you have maps available for people who have the nameless OP/downpipe full exhaust combo? I know you have stock tunes and your working on intakes of some sort.. just curious as to how ytour coming along with exhausts
thanks
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
| The Following User Says Thank You to Boofneenee For This Useful Post: | zc06_kisstherain (10-12-2013) |
#16 |
Drives: 2012 86
#17 |
Drives: Scion FR-S
Just say you took it to another dealer and play dumb.
Sent from my HTCONE using Tapatalk 2 |
#18 |
Okay so.. I just download this rom, buy a cable/software from you guys and reflash my car?
I live in Australia, I'm wondering if these parameters are safe to use for my ft86 straight out of the box?? I intend to drive it for a little bit before taking it to a dyno and getting it ffine tuned for my environment. |
#19 | |
Drives: 2013 Subaru BRZ
The ECM does not record number of flashes. At least not accessible at a dealer level. It does record mileage since DTC clear, time since DTC clear, and key cycles since reflash. So if the dealer has a reason to suspect the car was modified, they will probably look at those. |
#20 |
Shiv, do you have any future plans for Stage 1 or is 1.2 considered complete?
~2013 Scion FR-S~
~2004 Honda CBR600RR~ ~Skip Barber Grad~ |
#21 |
Drives: 2015 Mustang GT (on order)
Nothing illegal or warranty voiding about clearing DTCs
#22 |
Drives: 2013 Asphalt FR-S
Unless you have a header, the stg 1 tunes should be a fine starting point for those with exhaust mods. Headers change the VVT requirements dramatically, the rest of the system with the stock header in place just reduces back pressure and allows for more aggressive timing.
~Namaste~ |
#23 | ||
Drives: SWP BRZ
Shiv, can you confirm on this? |
#24 |
Drives: UK GT86
@zc06_kisstherain what @mad_sb said is correct. I wouldn't try adding timing until you can log to test it though.
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | zc06_kisstherain (10-14-2013) |
#25 |
Drives: 2013 FRS
Hi guys,
I Palm Springs this weekend for a wedding so I have limited access to the Internet and no access to my laptop. But I did manage to finish the Stage 2 map before leaving town. It is for use in cars with catless headers. You can safely run our Stage 1 map for such a with headers. It will still pick up good power. Where Stage 2 differs from Stage 1 is that it runs a more generous fuel table (to compensate for improved airflow) and run a bit more timing. It's more ~5whp more power at 7000rpm. But another 6-8whp all through the midrange which is good. It is currently being tested by a few people. When it gets greenlit, I'll post it up publicly
#26 |
The Mechanic
Drives: Civic Turbo,FR-S
does this new xdf file fix the launch control, no start issue? i noticed its at a different rpm
#27 |
Nope, I'm using 1.2 and suffer the same no start issue.
~2013 Scion FR-S~
| The Following User Says Thank You to MarcusM117 For This Useful Post: | Grip Ronin (10-13-2013) |
#28 |
Maximum puntential
Drives: 2013 DGM BRZ 6MT LTD
Just got the 1.2 update flashed today (was using 1.0 previously). Went for a semi-spirited drive after the flash and while the butt dyno doesn't notice much change over 1.0 while driving, the car definitely does idle smoother.
On a somewhat unrelated note, do you have of intakes in mind that will eventually have a tune written for them? I'm interested in an FA20Club CAI at some point in the future and would love to see a tune for one. Thanks for providing the updates! |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 07:35 PM |
| anyone trying to use the openflash tablet with forced induction? | FRSTEVE | Software Tuning | 69 | 12-07-2014 05:07 PM |
| 1st Dyno Tested/Tuned 6AT - OpenFlash Tablet | Anorexic 86 | Software Tuning | 13 | 07-25-2014 04:09 PM |
| OpenFlash Tablet Stg 2 Tune (Dyno Progress) | Rombinhood@OpenFlash | Software Tuning | 26 | 10-24-2013 02:19 PM |
| OpenFlash Tablet (free install) in NYC this weekend | Shiv@Openflash | NY / NJ / CT / PA | 8 | 09-19-2013 08:32 PM |
