Old 10-10-2013, 08:53 PM   #15
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
also Shiv,.. do you have maps available for people who have the nameless OP/downpipe full exhaust combo? I know you have stock tunes and your working on intakes of some sort.. just curious as to how ytour coming along with exhausts
thanks
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
The Following User Says Thank You to Boofneenee For This Useful Post:
zc06_kisstherain (10-11-2013)
Old 10-10-2013, 09:35 PM   #16
akyp
Drives: 2012 86
Originally Posted by shiv@vishnu View Post
Yep! Finally have stock again.
Mine is still in pre-shipment.
akyp is offline   Reply With Quote
Old 10-10-2013, 10:14 PM   #17
ciro
Drives: Scion FR-S
Just say you took it to another dealer and play dumb.
Sent from my HTCONE using Tapatalk 2
ciro is offline   Reply With Quote
Old 10-11-2013, 06:56 AM   #18
mswhong
Drives: FT86
Okay so.. I just download this rom, buy a cable/software from you guys and reflash my car?
I live in Australia, I'm wondering if these parameters are safe to use for my ft86 straight out of the box?? I intend to drive it for a little bit before taking it to a dyno and getting it ffine tuned for my environment.
mswhong is offline   Reply With Quote
Old 10-11-2013, 09:22 AM   #19
andrew20195
Drives: 2013 Subaru BRZ
It's very unlikely that the dealership can detect the number of flashes... That doesn't effect what you are concerned with because the OpenFlash Tablet saves your original rom file which means that you can load it back into the ecu prior to dealership visit, restoring your original calibration ID.
Can you confirm that the OFT also correctly sets the Verification Number identical to stock when returning to the stock calibration? I know that's one way Subaru can tell if the ECM has been flashed if the CID and CVN don't match.
The ECM does not record number of flashes. At least not accessible at a dealer level. It does record mileage since DTC clear, time since DTC clear, and key cycles since reflash. So if the dealer has a reason to suspect the car was modified, they will probably look at those.
andrew20195 is offline   Reply With Quote
Old 10-11-2013, 03:06 PM   #20
MarcusM117
Shiv, do you have any future plans for Stage 1 or is 1.2 considered complete?
~2013 Scion FR-S~
~2004 Honda CBR600RR~
~Skip Barber Grad~
MarcusM117 is offline   Reply With Quote
Old 10-11-2013, 09:36 PM   #21
jeebus
Nothing illegal or warranty voiding about clearing DTCs
jeebus is offline   Reply With Quote
Old 10-11-2013, 10:15 PM   #22
mad_sb
Drives: 2013 Asphalt FR-S
thanks
Unless you have a header, the stg 1 tunes should be a fine starting point for those with exhaust mods. Headers change the VVT requirements dramatically, the rest of the system with the stock header in place just reduces back pressure and allows for more aggressive timing.
Old 10-11-2013, 11:38 PM   #23
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
thanks
have same question
Shiv, can you confirm on this?
Old 10-12-2013, 02:05 AM   #24
Kodename47
Kodename47's Avatar
Drives: UK GT86
@zc06_kisstherain what @mad_sb said is correct. I wouldn't try adding timing until you can log to test it though.
.: Stealth 86 :.
Kodename 47 DJ:
zc06_kisstherain (10-14-2013)
Old 10-12-2013, 03:14 AM   #25
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Hi guys,
I Palm Springs this weekend for a wedding so I have limited access to the Internet and no access to my laptop. But I did manage to finish the Stage 2 map before leaving town. It is for use in cars with catless headers. You can safely run our Stage 1 map for such a with headers. It will still pick up good power. Where Stage 2 differs from Stage 1 is that it runs a more generous fuel table (to compensate for improved airflow) and run a bit more timing. It's more ~5whp more power at 7000rpm. But another 6-8whp all through the midrange which is good. It is currently being tested by a few people. When it gets greenlit, I'll post it up publicly
Shiv@Openflash is offline   Reply With Quote
The Following 5 Users Say Thank You to Shiv@Openflash For This Useful Post:
boxer 2.5 (10-12-2013), clintavo (10-13-2013), JETRED (10-14-2013), SloS14 (10-12-2013), YMAA (10-12-2013)
Old 10-13-2013, 01:30 AM   #26
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
does this new xdf file fix the launch control, no start issue? i noticed its at a different rpm
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Old 10-13-2013, 03:05 AM   #27
MarcusM117
Nope, I'm using 1.2 and suffer the same no start issue.
~2013 Scion FR-S~
~Skip Barber Grad~
The Following User Says Thank You to MarcusM117 For This Useful Post:
Grip Ronin (10-13-2013)
Old 10-13-2013, 06:21 PM   #28
YMAA
Maximum puntential
YMAA's Avatar
Drives: 2013 DGM BRZ 6MT LTD
Just got the 1.2 update flashed today (was using 1.0 previously). Went for a semi-spirited drive after the flash and while the butt dyno doesn't notice much change over 1.0 while driving, the car definitely does idle smoother.
On a somewhat unrelated note, do you have of intakes in mind that will eventually have a tune written for them? I'm interested in an FA20Club CAI at some point in the future and would love to see a tune for one.
Thanks for providing the updates!
Perrin CAI + intake tube || Tomei UEL || OFT Stage 2 tune
YMAA is offline   Reply With Quote
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
anyone trying to use the openflash tablet with forced induction? FRSTEVE Software Tuning 69 12-07-2014 04:07 PM
1st Dyno Tested/Tuned 6AT - OpenFlash Tablet Anorexic 86 Software Tuning 13 07-25-2014 03:09 PM
OpenFlash Tablet Stg 2 Tune (Dyno Progress) Rombinhood@OpenFlash Software Tuning 26 10-24-2013 01:19 PM
OpenFlash Tablet (free install) in NYC this weekend Shiv@Openflash NY / NJ / CT / PA 8 09-19-2013 07:32 PM
