Old 10-08-2013, 10:52 AM   #15
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by VisionRx7 View Post
1. Its running on the FBM 300hp pump gas tune just to break the clutch in until I switch to the E85 tune.
2. FBM 270LPH Pump
3. 1000cc Injectors
4. I don't know yet... had to leave town before I could get a log to them.
Could under hood heat soak be causing sensors to freak out?
I thought LJ's 300hp pump gas tune was setup for the 550cc injectors that normally come with the kit? I would make sure you are running on a tune for the 1000cc injectors. My guess would be the BOV opening slightly at idle and high vacuum conditions causing turbulance going across the MAF. This is easy to notice. Just watch the valve on the BOV at idle and if you see it move at all then you need a stiffer spring. I am running the 11 psi spring with a couple washers. I think the correct spring is the new 12 psi spring.
Old 10-08-2013, 10:53 AM   #16
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Originally Posted by Gen View Post
Conversely... I went with an even lighter spring in my BOV and did not have those issues.
What spring are you running now?
Old 10-08-2013, 10:54 AM   #17
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Originally Posted by FA20Club.com View Post
sounds like you just need a proper tune to be honest.
http://www.fa20club.com/product.php?...cat=251&page=1
It is only a basemap, and I agree that everyone should get a proper tune. I would make sure you get a boost gauge and AFR gauge asap though to make sure whatever tune you are running is running properly without having to datalog with EcuTek.
Old 10-08-2013, 12:19 PM   #18
Gen
Drives: Scion FR-S
If memory serves, I think it's a 9 or 10 lb spring and the valve connected directly to the manifold. Still doesn't solve the flutter, but it's a bit better. I don't like how late the valve actually opens. It's a good 2-3 second delay between taking my foot off the gas to the valve actually opening (not just the surge / flutter noise)
Gen is offline   Reply With Quote
Old 10-10-2013, 08:39 PM   #19
VisionRx7
Drives: 2013 Scion Frs
Thanks everyone for the good responses! Hopefully one of your suggestions solves this problem! I have a lot to look at when I get back home and since it will be December by then, I will have all winter to track the problem down before driving the car again.
VisionRx7 is offline   Reply With Quote
Old 10-11-2013, 08:51 AM   #20
aagun
Drives: 86
re-tune ur car , do u have any black smoke ? can u use laptop and check the old tune
aagun is offline   Reply With Quote
Old 10-11-2013, 09:34 AM   #21
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Jesse, we were suppose to link up remotely to do some logging/adjustments. The 1000cc tunes will need to be touched up to make sure everything is fine.
When you get back into town, please give us a call and we will sort those problems out Free of charge.
FullBlown is offline   Reply With Quote
The Following User Says Thank You to FullBlown For This Useful Post:
Sportsguy83 (04-07-2014)
Old 10-11-2013, 09:56 AM   #22
ft_sjo
Drives: GT86
Let's hope this doesn't turn out to be like the FRS300 fiasco. Bad install/wrong_calibration leading to engine failure leading to 6 month+ $5k+ engine build at another tuner still waiting to happen.
Old 10-11-2013, 10:06 AM   #23
Dipstik-sportech
Dipstik-sportech's Avatar
Do we know for sure it was partially the tune?
Old 10-11-2013, 10:10 AM   #24
ft_sjo
Drives: GT86
No, of course not. 'We', as in internet forumites, know nothing about the actual cause, but this is a bulletin board and the modus operandi is to speculate.
Old 10-11-2013, 10:58 AM   #25
King Tut
NASA SpecE30 Racer
King Tut's Avatar
It very well could if he doesn't have anyway to monitor how the engine is performing. Please make installing a boost and AFR gauge the first thing to be done.
Old 10-11-2013, 11:41 AM   #26
bgibbsunc
bgibbsunc's Avatar
Drives: Firestorm Scion FR-S
It kill me when I see FI cars without boost AFR gauges. I bought my gauges 2 months before I went FI.
FA20 club 60 trim + flex fuel
467 whp 356 ft lbs @ 19 lbs
Owner of Sidewinders Auto LLC.
San Antonio TX
bgibbsunc is offline   Reply With Quote
Old 04-06-2014, 09:58 PM   #27
VisionRx7
Sorry I haven't replied to this in awhile... I was finally home long enough to work on the car. I data logged and found out it was loosing fuel pressure while idling for awhile. It turned out to be nothing but a bad fuel pump. FBM sent me a new pump and 20 minutes later the car was fine!
2013 Scion FRS
Full Blown Stage 1 Premium Turbo Kit, 1000cc injectors, Walbro 485lph fuel pump, E85
The Following User Says Thank You to VisionRx7 For This Useful Post:
Old 04-07-2014, 10:05 AM   #28
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Awesome! Thanks for letting us know!
A few problems...but how bad are they? deedz Issues | Warranty | Recalls / TSB 20 07-21-2013 02:27 AM
Turbo Problems please help whitefrs Forced Induction 126 05-02-2013 07:29 PM
Gas Problems Kelbyat07 Issues | Warranty | Recalls / TSB 3 04-20-2013 09:21 PM
No CEL problems here BRZranger Issues | Warranty | Recalls / TSB 41 12-08-2012 01:36 PM
Do you think this car is going to have some problems? Huss Scion FR-S / Toyota 86 GT86 General Forum 45 03-21-2012 01:48 PM
