Old 10-08-2013, 02:33 PM   #15
TM
TM's Avatar
Drives: DGM BRZ 6MT
This happened to me once before. I filled up a a day ago, but I wanted to top it off before going on a road trip. When I started the road trip, I noticed that the needle still rested slightly above 3/4 of the tank.
TM is offline   Reply With Quote
Old 10-08-2013, 03:06 PM   #16
KelvinBRZ
GBS Mafia Member
KelvinBRZ's Avatar
Drives: with Snow mode on
Happened to me as well.. I was pumping about $10 of gas into my car & the needle did not move at all. I called the dealership and they said to come in for a check up.. but the next day it fixed itself so I didn't go
GBS Mafia
KelvinBRZ is offline   Reply With Quote
Old 10-08-2013, 03:50 PM   #17
logoris
Drives: 04 is300 sport design ii
sounds like its the motor for the needle when you fill up it should be right at or just above full, want you can do is pop the needle off and reset it to where it needs to be but be careful on the frs there is no stop so try not to spin the motor as you re apply the needle.
also be sure its not the pump some can have different angled nozzle which can splash back into it getting a false full
logoris is offline   Reply With Quote
Old 10-09-2013, 12:24 AM   #18
FRSupra
FRSupra's Avatar
yeah no problem, after that I'll move on to bomb diffusion.
FRSupra is offline   Reply With Quote
Old 10-09-2013, 02:04 AM   #19
logoris
Hey its not that hard didnt it the week my friend got his 86
Sent from my SGH-I717M using Tapatalk 2
Old 10-09-2013, 03:39 PM   #20
Scionshaun
Aloha!
Drives: Whiteout
Same thing happened to me. Just disconnected battery and reapplied. I'll be filling anytime after the 3/4 mark.
Scionshaun is offline   Reply With Quote
Stock In-Tank Fuel Filter Degradation sw20kosh Engine, Exhaust, Transmission 96 07-28-2014 03:36 AM
AEM High Flow In-Tank Fuel Pump JPxM0Dz Engine, Exhaust, Transmission 0 04-13-2013 12:15 PM
Actual experienced real world fuel mileage MPG? R8 Scion FR-S / Toyota 86 GT86 General Forum 88 07-24-2012 07:50 AM
“saddle-shaped” fuel tank ft86Fan Engine, Exhaust, Transmission 13 06-26-2012 04:22 AM
