#15 |
Drives: 2013 "AVO Orange" FR-S
As posted in the other thread:
The MAP sensor is reading your altitude-dependent air pressure + the pressure from the turbo. At sea level, that was be 1 bar - 14.7psi. But if you are in Denver, CO, the atmospheric pressure is around 12.1 psi. So your boost on top of that, if it's 18.85 psi at the MAP sensor, is about +6.85psi. That's what it's reading at the manifold, and not necessarily what it would read with a boost gauge attached. A boost gauge is generally going to be a bit more accurate. This is why cars have MAP sensors, of course, so they can compensate for the changes in altitude. One of the reasons it was important to test in Utah was the fact we were at 5000-6000 feet for so long (and at speed! Gotta love an 80mph speed limit). Now, here's the fun part - what you read at the manifold and what you read at the turbo are going to be two different boost levels. What the wastegate reads is at the turbocharger - it's plumbed directly off the compressor outlet. What your MAP sensor reads is at the intake manifold. Between your turbocharger and your intake manifold, there will be a pressure drop. A big part of that is the intercooler. A fun fact we recorded on the Subaru Legacy/08+ WRX was the fact that the stock intercooler had about a 3psi pressure lost, most likely due to backpressure. Our upgraded intercooler dropped that to only a 1psi pressure loss. So if the wastegate was set to 15psi, at the engine it'd be seeing 12psi with the stock intercooler, or 14psi with the upgraded intercooler. Also factor in that boost gauges, especially the electronic ones, can be +/- 1psi as well. All of this is why our basemaps won't make the most power possible - we have to factor in all the possible variables (that are always going to be there). And it's why you will usually pick up a lot of power with a dyno tune. |
| The Following 3 Users Say Thank You to AVOturboworld For This Useful Post: |
#16 | |
Drives: Subaru BRZ Limited
Thanks for all the info. So you say the 18.58 at map is about 6.85psi. My boostgauge reads this at about 10psi....and according to my tuner this is really about 12psi...ugh, you can see the reason im confused. Thing is, my tuner said that my gauge will probably be about -2psi off due to altitude. So if its reading 10psi, its really putting out about 12psi, etc.. Any thoughts on that? And in the end, does it really matter, as long as the tune is good and the boost is adjusted correctly? I am headed to my tuner in about an hour and hope to get this all fine tuned, and wrapped! |
#17 |
In the end, it doesn't matter that much as long as the tune is done for the current boost, and the power figures come back at what you are expecting. I always default to the boost gauge in regards to measured boost. It's mainly a data point to measure if we are near where we are supposed to be, or if we are too far over or under.
| The Following User Says Thank You to AVOturboworld For This Useful Post: | gdrider77 (10-07-2013) |
#18 | |
Thanks for the new actuator and oil breather bolt. They both worked perfectly! |
#19 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#20 | |
Dirt Trackin'
Drives: '13 Raven FR-S MT
#21 |
Ok all, so worked with my tuner, and as many of you guessed. The map setting was wrong. he had it set for 4bar, as he thought i said that. He changed it to 3bar and all seems good in the readings. Boost gauge and map are much closer now. +/- .5 if that.
| The Following User Says Thank You to gdrider77 For This Useful Post: | Sportsguy83 (10-08-2013) |
#22 |
NASA SpecE30 Racer
That makes sense. My AEM Failsafe and EcuTek with 4 BAR map sensor are also within +/- .5 PSI.
- King Tut
