#15 |
That Guy
Drives: 2013 asphalt FRS MT
I'm gonna take a stab at the cause.
While you're at part throttle the ECU is running in closed loop mode, meaning that the sensors that provide feedback to the ECU so it can adjust trims such as air fuel ratio, cam phasing and ignition timing, are active and the ECU is using them to adjust those trims. When you go to full throttle the ECU goes to open loop mode, no longer accepting those sensor readings, and using factory tuned maps to determine the engine parameters. Clearly your ECU has found that's it's safe to run more aggressive trims then the factory WOT maps. If I were you, I'd thanks the gas gods for having decent fuel, and contact a tuner. |
#16 | |
Drives: 2013 Asphalt FR-S
~Namaste~ |
#17 |
That Guy
So, does that mean my explanation and thus understanding of this is plausible? Other then the AFR?
#18 |
Drives: GT86
It's to do with gas velocity.
#19 |
Drives: waiting on a 2021...
I would think that with a partially closed throttle body the MAF would see less air flow and adjust the fuel accordingly. Less air, less fuel, less power.
2016 4Runner Tail edition
2020 Camry 2020 RAV4 2013 Chevy 3500 4x4 Duramax 1999 Ford F250 Powerstroke, the tow rig 1969 Mustang, the fast car....(: |
#20 | |
Weight Nazi
Drives: 13 FRS -399lb, 11 335is, 05 Tiburon
Lots of good theories so far. I have nothing to add, but I do hope this is the case:
#21 |
Drives: 2012 subaru brz
i noticed the same thing lmfao thought i was the only one.
#22 |
Weight Nazi
@wholeeoh, your username instantly reminded me of Ling and Ling's Father from Kung Pow.
#23 |
Drives: GT86 DGM
Definetly noticed it too. I'm subscribing to the open/closed loop theory. Notice it both stock and tuned (N/A)
#24 | |
Drives: They have four wheels
And yes, I noticed the part throttle effect during the gentle part of my break-in cycle. Was wondering if it was only in my head, guess not. |
#25 |
Drives: GT86
#26 |
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
Stupid question.
But what is 'bogging'? |
#27 |
Drives: FR-S 10 #103 AT
Not sure the origin but I always interpreted it as meaning you expect to take off in a sprint but move like you are running in a bog.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#28 |
Drives: 2013 Scion FR-S 10 Series MT
It's essentially lag, or a delay.
When you push your foot all the way down on the throttle, you expect an instant response from the engine to go faster. This is usually coined as throttle response. Bogging is when you don't get instant response from the engine. There is a delay of time before the car starts to accelerate fast. Bogging can be as quick as a split second, or as long as several seconds or more. |
| Full throttle Electric Supercharger Build Thread | fenton | Forced Induction | 11315 | 04-07-2025 06:42 PM |
| Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
| 86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
