#15 |
Just a dude
Drives: Scion FR-S 2013
Wouldn't running say -2.2 to -2.5 up front and -1.7 to -2.0 in back clean this up alot? Several guys locally doing Auto X are either -2 all around, or slightly more in front always seems with their BRZ & FR-S.
#16 |
#17 |
Drives: 13 BRZ Limited WRB
Ok - Let me try to take in all of the above posts and respond as so that it makes sense:
I do not want to change my springs at all. I'm very happy with the level and being square. I guess I was unaware that the rear camber was, not ideal. I would be perfectly willing to go to something like -2.5 front, -2 or -1.5 rear. What is the advantage of that, though? The reason I like the rear sway idea, is because of the adjustability. Once i get the car figured out, i'd like to have something simple like that to adjust between the road course and AutoX. (Keep in mind HPDE is not a fiercely competitive event for me, it's just the fun of it - I am not willing to drive the bleeding edge when there is no incentive except for a timed lap - Don't want to throw 30k into a wall - so i will be less interested in changing the car setup to cater to it) So, if the three points on a rear sway make a big difference in oversteer/understeer (again, once the car is setup correctly) then that would be awesome. Unfortunately I didn't bring out my GoPro this weekend - I never do anything with the footage after I get it ![]() Also, if it helps - I plan on running Rivals next year instead of the ZII's
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925 |
#18 | |
Lost in Kansas
Drives: 2013 Scion FRS (Raven)
Since the front of the car is a strut setup, you are not getting extra camber on compression. (not much at least) The rear of the car has the multi-link instead which gives you additional camber on compression. |
#19 | |
I am happy with the firmness and the little amount of body roll in turns with the stiffer springs - that's what i'm referring to. So having more negative camber in the front while cornering will ________? Keep it from understeering and provide better grip?
#20 |
Fix your alignment issues first before attempting to add something to a setup that may make things more complicated. And difficult to dial in. If you drop your rear camber to 1.5 the car will rotate again. And be more neutral in autox. Go simple first. Rivals are a good tire but grip levels are close to ZII so its not going to change things all that much.
#21 | |
i'm sorry, what?
Drives: Canada
anyway, there is no "advantage", you are simply adjusting the car's behaviour to fit your desired goal. Like i said at the very beginning, if you want less understeer you have to either add grip at the front or reduce grip at the rear. Increasing front camber from 1.5 to 2.5 in the will give you slightly more grip (in the front) during cornering while reducing the rear camber in the will reduce grip in the rear by a small amount during cornering.
#22 | |
However, the spring rates affect how your suspension loads; you're making the front work a LOT harder with square springs, so they give out faster than the rears, making you understeer. Aligning to give the front more grip is a band aid in this case. The real fix is to add a rear sway (or do both sways, but make the rear stiff in comparison to the front, relative to the stock sway balance), or change springs. I'm not one to recommend parts that are not necessary. There are plenty of cases where an alignment helps, and this is one of those cases, but it will only "just help", not solve the issue. |
#23 | ||
I do agree with the OP that the adjustability of a rear swaybar would be helpful (bump it up a notch for auto-x) but IMO the alignment needs to be taken care of first. - Andy |
#24 |
I think I'll start with Camber, and then go from there. Still interested in getting a rear sway, but i'll change one thing at a time.
I'll be going into garage mode here pretty soon anyways (You know, North Dakota and all) so we'll see how things go next year! Thanks all!
#25 |
Drives: 1993 Impreza w/ WRX Swap + FWD!
I'm curious why you were running so much rear camber in the first place?
#26 | |
Seemed like a good idea at the time... I went from Stock everything to wheels, tires, suspension, alignment in a few days before an event. Didn't have a ton of time to research.
#27 | |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
What's happening in your situation is that you're quickly going positive up front while the rear is staying closer to square with the road. So to counteract this, you need more negative camber up front so you can afford to lose some to body roll. Reducing the rear camber will nudge it further into positive and reduce rear grip slightly, to assist with rotation. |
| The Following User Says Thank You to Draco-REX For This Useful Post: | Lateral G (02-09-2017) |
#28 |
Corner Junkie
Oh, and as a side note:
Sway bars will reduce body roll which, in turn reduces camber loss. However, by linking the two sides of the suspension more firmly, you're essentially shifting more weight to the outside tire, off of the inside. This can actually reduce the overall available grip. Often this loss of total grip is balanced by a more controlled suspension. But a well set up and more independant suspension will have a greater ultimate grip level and be better behaved over rough surfaces. This is why I'm not convinced that sways are the answer for this car as opposed to say, a Subaru impreza (rear sway first thing!). Our cars are so well set up from the factory that body roll isn't as big of an issue. So we can take advantage of that fact with smaller sways. (Granted, I have had some moments of doubt on this stance. There's a set of RCE sways sitting in my garage, still in the box, in case I change my stance on them again..) |
| Sway Bars: What's The Trade Off? | Captain Snooze | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 45 | 04-24-2020 12:18 PM |
| brz and fr-s sway bars different? | 1010110 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 08-03-2013 02:43 AM |
| ST sway bars | bmxhotsauce | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 05-09-2013 04:11 PM |
| FR-S/BRZ SWAY BARS & STRUT BARS @ NINJA AUTOSPORTS!!! | NJA | Brakes, Suspension, Chassis | 18 | 04-07-2013 07:00 PM |
| Cusco Sway Bars? | wootwoot | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 18 | 08-04-2012 06:31 AM |
