Old 05-15-2012, 02:12 AM   #15
Primo86
Primo86's Avatar
Drives: '05 Toyota Celica (Sold) Scion FR-S
in my '05 Celica i was having problems with wind noise and road noise. After upgrading the stereo sys. i wanted to be able to enjoy the sound quality and also drive hard at the same time..
Seeing as the car was modified, it had a loud exhaust (GReddy Ti-C cat-back) which was very overpowering after 3,000 RPM.
I installed the Dynamat in a matter of a few hours, it was all very simple,
1. carefully take off your door panels, carpets, and anywhere else you wish to deaden noise.
2. put on thick gloves because the black adhesive on the underside is STICKY and can be sharp when cut to fit.
3. simply lay the Dynamat out and cut it to fit flush against any metal surface, roll over the material with something heavy to reinforce the bond.
4. reinstall interior.
this made a HUGE difference in the ride comfort (MUCH less vibration), sound quality, as well as livability with all the mods seeing as the car was my daily driver.
HOWEVER
Dynamat weighs a metric shit- ton , and decreased performance by a slim margin. however, after tearing half of it out and strategically placing the remaining few pounds in smart locations, i got the best of both worlds.
Primo86 is offline   Reply With Quote
Old 05-21-2012, 06:25 PM   #16
Symbiont
Tall guys fit, too.
Symbiont's Avatar
Drives: BRZ Premium 6MT (SWP)
Originally Posted by Slartibartfast View Post
I used to be a huge fan of Dynamat for it's performance, but hated that it was so heavy. Adding 100+ lbs of sound deadening is painful on the performance. I just couldn't do it on my RX-7. I used Cascade for the RX and loved it. It's half the weight, and works as good, or better, than Dynamat. I did it just around the speakers in the RX, but did the doors and trunk in my Camry (I didn't care if I added weight to the Camry)
I am adding Focal Utopia Be speakers to my FR-S and will be using Cascade again around the speaker only. I'm justifying the extra 10-15 lbs or so by adding a Siebon CF hood to compensate (do no harm)
http://cascadeaudio.com/car_noise_co...ntrol_kits.htm
http://cascadeaudio.com/car_noise_co...B-2HD_Tech.pdf
The 5500 dollar set of components? Hope you have a good install place. The default soundstaging in the FR-S probably isn't optimized for a set up like that.
Symbiont is offline   Reply With Quote
Old 05-21-2012, 11:38 PM   #17
Slartibartfast
Klaatu barada nikto
Slartibartfast's Avatar
Drives: Raven FR-S MT
The guys I deal with are very good, with plenty of experience working with high end "audiophile" components. The system I'm putting in will be about $9000 they put a lot of time and effort into making the system "fit" the confines of the car.
I have two weaknesses. Cars, and music. My car is my sanctuary, I spend a lot of time there, I want it to be sonic heaven. From the exhaust on the twisty bits, and from the speakers on the highway.
I vow to do no harm.
2013 Raven FR-S Manual "Lenore"
1985 Silver RX-7 GSL-SE (Gone and missed)
Slartibartfast is offline   Reply With Quote
Old 05-21-2012, 11:42 PM   #18
Symbiont
Tall guys fit, too.
Symbiont's Avatar
I understand completely, but my budget is more around the 3-4k mark, installed :P
Let me know what you find out about the sound dampening material, please (product, number of sheets, location, etc.). Good luck!
The Following User Says Thank You to Symbiont For This Useful Post:
Slartibartfast (05-22-2012)
Old 05-26-2012, 03:14 PM   #19
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
My older daughter and I did her Black 2008 Scion TC, firewall to rear, doors and rear hatch, rear pillars to headliner, rear wheel wells. Raammat and ensolite.
Solid, quiet (borla exhaust is loud), better bass from subwoofer, cooler car in the heat of South Florida.
Added 75 lbs to the weight of the car.
I explained this to my younger daughter and her response was "Why make a light car heavy dad?"
We are applying ensolite only to the rear trunk loud right now. Hoping to cancel the hollow sound coming from the rear when the seats are folded.
tonystewart is offline   Reply With Quote
