Old 09-25-2013, 09:30 AM   #15
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
You have to remember you will get natural camber as you lower the vehicle so rubbing should not be an issue unless you want to get back to -1 or 0 camber. Most people are not happy with the little drop on the Pro Kits so Sportlines are kind of the go to.
WE can offer the same kit in the Pro kit springs as well if you would like. I think Yo will have them on the site later today.
FT-86 SpeedFactory is offline   Reply With Quote
Old 09-25-2013, 06:20 PM   #16
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
I know but living where I live the one inch will be enough now it's just a matter of eibach or swift
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 09-25-2013, 07:02 PM   #17
itisthumper
itisthumper's Avatar
Drives: WRB BRZ MT
I have the Pro Kits. They are fine with the stock shocks, just go over bumps slowly. I've only scrapped 1-2 times.
itisthumper is offline   Reply With Quote
Old 09-25-2013, 07:24 PM   #18
thehapaone
Wasian Ninja
thehapaone's Avatar
Drives: 2013 Crystal Black Silica BRZ-L
I'm running pro kits and they are great for daily driving I have only scraped a few times and most of those times were due to my street being under construction the ride is fine compared to stock and the car looks better lowered that inch
check out my build thread here
Previous Cars: 1970 Chevelle 350 (crashed still have in CA), 2000 Honda Accord Coupe (sold)
thehapaone is offline   Reply With Quote
The Following User Says Thank You to thehapaone For This Useful Post:
ftc~brz (09-25-2013)
Old 09-25-2013, 07:29 PM   #19
ftc~brz
Done
Drives: WRB BRZ
+1 pro kits with very similar wheel set up as you. I only chub rub when going to fast over "construction" bumps on the highway. I dd this and approve
ftc~brz is offline   Reply With Quote
Old 09-26-2013, 09:10 PM   #20
ScionFR-S
ScionFR-S's Avatar
how long have you had these on ?
Old 09-27-2013, 11:43 AM   #21
ftc~brz
Done
Drives: WRB BRZ
since april.
Old 09-27-2013, 12:46 PM   #22
kALMIGHTY
Drives: TRD Ultramarine '13
Go for TRD springs. ~1 inch drop and pretty cheap too, I think around $250 ish if I remember correctly, around $350 installed by dealer. Plus you keep stock strut warranty if they blow out early.
Old 09-27-2013, 01:40 PM   #23
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
Excuse my poor search skills, but what part # are they through Scion (Canada)?
Thanks
drewbot is offline   Reply With Quote
The Following User Says Thank You to drewbot For This Useful Post:
Verbal21 (02-01-2014)
Old 09-27-2013, 01:54 PM   #24
kALMIGHTY
Thanks
PTR07-18130 is the part number. I haven't called any dealers yet here in Canada but you should give it a try. A few people have pre ordered them using the part number, but I don't know if any of them were in Canada. Apparently they should come in by late November.
Old 09-27-2013, 02:03 PM   #25
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Ok thanks. When I went to the dealer they gave me an accessory list from the JRP online store...
Old 09-27-2013, 02:21 PM   #26
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
prokit or sportline springs, depending if you want a 1" drop or 1.4" drop
malubawla is offline   Reply With Quote
Old 10-07-2013, 04:04 PM   #27
Corner3garage
Corner3garage's Avatar
Drives: FR-S & BRZ
I would say swifts are probably the best engineered springs out there!
Corner3garage is offline   Reply With Quote
Old 10-07-2013, 05:39 PM   #28
Team STILLEN
Mark @ STILLEN
Team STILLEN's Avatar
Drives: 2015 Subaru BRZ
Any springs that have been discussed will work fine with the stock shocks. One thing to keep in mind when pairing lowering springs with OEM Shocks/Struts is the longevity of the dampeners. Because the OEM Dampeners were designed to be used with the stock springs, going with a shorter travel (lowering), higher rate spring will put extra stress on them. The OEM Shocks will not last as long as they would with stock springs. I can't give you exact numbers but from past experience new OEM dampeners last around 25k-50k miles on a lowered car.
You can test your dampeners on the car by pressing down on one corner and seeing how it responds. If the car returns to normal ride height without oscillating or bouncing your dampeners are okay. If it bounces up and down like an old Cadillac, your shocks/struts are blown.
Team STILLEN is offline   Reply With Quote
FRS as a Daily Driver? Pake1 Scion FR-S / Toyota 86 GT86 General Forum 104 08-15-2012 11:48 PM
My new daily driver since FRS always in the shop Pekingduck FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 18 07-24-2012 04:03 PM
Will the BRZ be your daily driver WRXGuy1 BRZ First-Gen (2012+) — General Topics 47 05-23-2012 12:15 PM
BRZ as daily driver? Pakjk89 BRZ First-Gen (2012+) — General Topics 80 03-22-2012 09:50 AM
The daily driver KiingDavid CANADA 25 02-06-2012 01:14 PM
