Old 10-03-2013, 11:31 PM   #15
robot
There are now 2 carseats!
Drives: 2013 DGM BRZ
Originally Posted by mmontes View Post
If you can post any pictures I would be so happy! Haha
I will once I have it all figured out. I've been taking them as I go.
robot is offline   Reply With Quote
Old 10-04-2013, 06:56 PM   #16
robot
So I plugged my video source into vv+ and vv-. Ground to vv- and signal to vv+. Nothing happens. Am I using the correct pins?
There is no aux option in the menu and diagnostics show nothing plugged in to "aux".
Old 10-04-2013, 09:51 PM   #17
nalc
Drives: 13 BRZ Limited 6MT GBS
Try grounding CGND. I was having a similar problem, and I'm not sure if it was what fixed the problem, but I have it grounded and it works.
nalc is offline   Reply With Quote
Old 10-04-2013, 11:57 PM   #18
Foobar
SLO NO MO
Foobar's Avatar
Scroll down on your audio menu where the Bluetooth option is. Aux is on that second page.
Sent from my Nexus 7 using Tapatalk 4
Old 10-05-2013, 03:00 AM   #19
Zoti
Drives: BRZ Limited 6MT
You need to have the camera powered and have alive video signal when the radio is turned on and going through its start up sequence. It checks if a camera is present.
The car also needs to be in reverse or the head unit needs to be tricked to think it is I reverse.
Also, if you need 12v for your camera you can tap into the 12v accessory which I think is 13 on the 28 pin plug. It's a red/white wire.
That's how I did my rear view cam.
Zoti is offline   Reply With Quote
Old 10-05-2013, 06:26 PM   #20
robot
Zoti...I'm currently trying to get just the standard aux video in working (rev camera input works but puts up a parking guide overlay.). It doesn't seem to work. I tried grounding to many different grounds and I just can't seem to get an option in the interface to enable it.
Old 10-06-2013, 01:55 AM   #21
robot
I went back at it again tonight.
I added a switch to vss and grounded my e-brake wire while I was there. These things seem to work fine.
This time I tried to ground the ADPG wire. On one version of the Bespoke units this switches it from audio aux to video aux. This didn't work. I double checked all my connections.
I also started using painters tape to avoid scratching everything up with all the in and out of the head unit.
FooBar says SVXdc said it should work (and I found the thread where he does...I think, so far, no one has hooked this up successfully. So far, it is still speculation). I messaged SVXdc and we'll see what he says. I have a sinking feeling that aux in video is disabled in software.
Old 10-06-2013, 02:19 AM   #22
Zoti
Gotcha. Your VSS switch worked? I assume you put it on#17 of the 28 pin connector.
Mine didn't work. The head unit uses the GPS speed to determine that the vehicle is in motin
Old 10-06-2013, 09:53 AM   #23
robot
I have the older version of the firmware. The newer version uses gps and vss.
Old 10-06-2013, 03:57 PM   #24
robot
And apparently I'm wrong. The vss switch I installed does turn off the vss, but the car still switches to moving/restricted mode when I'm moving.
My firmware is 15:30/30.07 9.2.2.250040 and 08,07,2012 ver. 44.1004 .
Old 10-07-2013, 12:38 AM   #25
robot
Even more crap news. It appears the rev detection (at least on my firmware version) is a two step thing. I wired a spst switch to the #2 pin on the 28 pin harness (labeled in diagrams as the "rev" pin.). With this switch I can turn off reverse detection but I cannot turn on reverse at will. In other words I have to switch this to on and then actually put it in reverse to get the rear camera input to light up.
Old 10-07-2013, 02:33 AM   #26
Zoti
That's probably because when you put the car in revers that wire gets a ground signal just like the hand brake. Try to connect that switch to ground on one side and the radio on the other.
Old 10-07-2013, 11:09 AM   #27
robot
I was going to dismiss your post, but it actually makes good sense. I hooked the switch in in-line with the reverse wire. I should have hooked it pin2 -> switch -> ground. This is what I get for messing with electronics late at night.
Old 10-07-2013, 02:34 PM   #28
Zoti
That's simply how the handbrake signal works. It makes sense that the reverse signal is the same.
Pinout for FRS Bespoke head unit - video inputs? ATSAaron Electronics | Audio | NAV | Infotainment 2 12-09-2014 10:59 PM
FS: Stock FR-S head unit ghost86 Audio/Visual, Electronics, Infotainment, NAV 4 11-09-2013 01:49 AM
Stock head unit. Flawless22 Audio/Visual, Electronics, Infotainment, NAV 1 03-27-2013 02:39 AM
Stock head unit fitcious Electronics | Audio | NAV | Infotainment 1 01-16-2013 05:57 PM
Video on FR-S head unit? wparsons Electronics | Audio | NAV | Infotainment 2 12-18-2012 03:31 PM
