Old 01-02-2014, 09:02 AM   #15
bluesubie
Originally Posted by brillo View Post
I've got a free oil change from the dealer I might use post track day. My ECU is flashed and I'm not sure if the dealer oil change stations check things like the ECU to see if an update is warranted. I don't want to tip my hand over a free oil change.
What have other experienced?
After a track day, they can just look at your tires and tell that you've been on the track or will say that the car has been abused. Generally not a problem unless you try to get them to fix something like a wheel bearing problem under warranty.
Yes, I agree it's dealer dependent.
Originally Posted by HapaHaole View Post
As a former Toyota tech, we don't plug in the scan tool unless it is needed. The only time they flash is if the VIN run shows a TSB or Campaign then we would perform it, or when running the system for codes due to a Check engine / failure light on.
Now the Audi is different since to reset the maintenance light it's easier to plug in the scan tool, on newer ones you have plug in a VAS / VAG scan tool to reset the light.
Your screen name is no ka oi.
-Haole Dennis
bluesubie is offline   Reply With Quote
Help with Oil change at dealer kombatlion Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 9 03-23-2013 10:54 AM
Dealer Oil change Issue Hawaiian Scion FR-S / Toyota 86 GT86 General Forum 9 02-18-2013 04:06 PM
should i change oil myself or let dealer do it? chenshuo CANADA 28 02-14-2013 01:28 PM
Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) R2RO Issues | Warranty | Recalls / TSB 3 02-04-2013 10:06 PM
Dealer Oil Change JSK CANADA 6 10-05-2012 04:36 PM
