Old 08-31-2013, 02:50 AM   #15
ft_sjo
Drives: GT86
Originally Posted by sw20kosh View Post
Yes I am. You have a suspicion about something?
Well, you said the only symptom is you 'loose throttle control'. You didn't say the engine cuts out, splutters, hesitates, or anything. Therefore it looks like an electronic issue, and as you know the electronics are often controlled by software... and I know RaceROM in the past has had issues with fuel gauges and stuff.
The Following User Says Thank You to ft_sjo For This Useful Post:
mad_sb (08-31-2013)
Old 08-31-2013, 06:29 AM   #16
mike the snake
Losing throttle control=cutting out IMO. Otherwise what else would it be? If it stayed where it was that would be a "stuck throttle".
Old 08-31-2013, 07:52 AM   #17
mad_sb
Drives: 2013 Asphalt FR-S
Sounds like the pump is getting starved to me. The pump is probably pushing more fuel than the siphon can pull. Should probably fill up before the light comes on if you want to keep your motor happy.
It's possible the pump has shifted in the housing if this a relatively new symptom. Also possible the pump is meeting a pre mature end.
This is a weird question that maybe someone here who has modified their ecu + fuel system has a simple answer to.
Twice now I have lost throttle control while cruising on the freeway when the fuel low level light was on. Both times were several minutes after the light came on.
A. It will drop me out of Cruise Control and I will not be able to accelerate.
B. Car will coast for a few secs (engine still on) and then abruptly I'll have throttle control back again.
C. A few secs later I will lose throttle control again.
D. This cylce repeats.
Both times I pulled over to a gas station and filled her up with gas. Issue disappears after that.
I am thinking it must be a fueling issue but can't figure out what it may be? I haven't touched the fuel system since the Innovate Supercharger and Deatschwerks Fuel Pump install 3-4 months ago.
The car runs perfectly otherwise. AFR's are spot on. Fuel trims look good. No hesitations or loss of fuel to the engine when the tank is filled. No codes.
The Following User Says Thank You to mad_sb For This Useful Post:
sw20kosh (08-31-2013)
Old 09-02-2013, 10:10 AM   #18
chadstyle
chadstyle's Avatar
Drives: 2013 Subaru BR-Z Limited
My guess is that it has something to do with the fuel pump install and the sending unit. There should be no fueling starvation or issues at "cruising" speeds. I agree with the above comments regarding logging the event. I didn't see any mention of an aftermarket throttle control module being used so I have to believe its something mechanical.
Best of luck diagnosing the gremlin..interested to see what it is.
chadstyle is offline   Reply With Quote
Old 09-02-2013, 01:20 PM   #19
448hpsti
In Test:Oil Fed SC
448hpsti's Avatar
Drives: Vortech Prototype Test Car
Whose tune, just curious
Otherwise stock?
448hpsti is offline   Reply With Quote
Old 09-02-2013, 09:34 PM   #20
xjohnx
Grip>Slip
xjohnx's Avatar
i had a similar issue when i was having fuel pump install issues. My tuner was able to see that from my datalogs (specifically the fuel rail pressure).
Low Fuel Light. Draco-REX Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 64 11-07-2015 08:33 PM
Dynosty Fuel System Upgrades- Billet Fuel Rails!!! Dustin@Dynosty Forced Induction 4 10-08-2014 10:00 AM
Premature low fuel light WolfpackS2k BRZ First-Gen (2012+) — General Topics 76 06-21-2013 09:45 AM
Check Engine light after: Major service (Fuel pump, ECM, and 7500 miles oil change) R2RO Issues | Warranty | Recalls / TSB 3 02-04-2013 10:06 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
