Old 08-30-2013, 05:20 PM   #15
White64Goat
Once you get rid of smell the easiest thing to do is to turn off the A/C about 2-3 minutes before you get home and turn the fan to high. You can also turn heat on to aid in drying out the evaporator before shutting off the car.
Old 08-31-2013, 10:41 AM   #16
Yruyur
Yruyur's Avatar
After i use spray to clean thinking of picking some of these up as well to maybe put on top the cabin filter. Should help draw moisture out.
http://mobile.walmart.com/m/phoenix;...83#ip/14707415
Sent from a Motorola DynaTAC 8000X
Old 08-31-2013, 03:02 PM   #17
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
Interested to see if the spray really helps
Kelbyat07 is offline   Reply With Quote
Old 09-02-2013, 10:03 PM   #18
Yruyur
Yruyur's Avatar
So far the smell has gone away but without the spray. I did this
I basically attached a high power hose to the drain tube and let it suck for a minute or two. Its been a few days and its the first time I have not smelled it in months.
http://www.ft86club.com/forums/showthread.php?p=1181499
Old 09-09-2013, 10:35 PM   #19
Yruyur
Yruyur's Avatar
Updating this. The smell is horrendous now that the humidity is up. My can of spray will be here tomorrow. I will be applying it tomorrow.
Old 09-10-2013, 03:10 AM   #20
g0lden
Drives: 2013 Scion FR-S Argento
You can try turning on the outside air circulate and spraying some of the vent cleaner into the outside vent intake. probably have to pop the hood, and look near the windshield area.
g0lden is offline   Reply With Quote
Old 09-10-2013, 11:44 PM   #21
Yruyur
Yruyur's Avatar
So I used the spray. Ultimate test will be over the next few days. Right away the car smelled better. Hopefully the lemon smell will go away soon but id rather that than mold.
Can is a smaller can not larger as I thought. Under the cap is a hard tube that attaches to the can. The tube has a tiny nozzle attached to it to help the foaming process.
The instructions say to spray in the forward vent or for professionals to spray into the drain hose itself. I opted for the drain tube by pulling up the carpet. Make sure you put a bowl underneath the hose opening as it will run back out.
I did about 3/4 of the can then did the rest in the middle vent.
I dont recommend that. I think some fluid leaked and shorted speaker wires. When I started the car eventually the rear speaker was making a crackling noise. It eventually went away.
The contents are listed. Looks like alcohol is the number one ingredient. I think the rest is to make it create a foam. I did spray some on the curb to see how it worked. The foam only lasted a few seconds and went away.
I would recommend shaking the can every couple seconds while spraying. When I did this you could hear it foaming a lot better. If there is no foam then it probably wont make as much contact inside the housing. I would recommend spraying it all in one quick session as well.
We will see how the next couple days go. I asked the dealership about the smell and they offered to spray some ozone in the vents. I opted for this method.
Old 09-11-2013, 06:28 AM   #22
ntron1
Sarcastic Bastard
Drives: '13 DGM BRZ, '13 Mini, 1999 Blazer
Airsept in GA are experts in A/C Odor http://www.airsept.com/index.php
Or you could try these....
http://www.uview.com/index.cfm?PAGEP...tList&ID=45698
http://www.cliplight.com/hvacr/service-tools/purifier/
ntron1 is offline   Reply With Quote
Old 09-13-2013, 09:54 AM   #23
Yruyur
Yruyur's Avatar
So its been a few days now after spraying that can into the ac. Wow. Absolutely no more smell. It feels great not getting in the car and being embarrassed anymore.
I am not not using the recirculation option as others have said now.
I should add that the overwhelming lemon scent has pretty much gona away now as well. Really just a fresh smell now.
Thanks for everyones help.
Old 10-14-2013, 02:28 AM   #24
Yruyur
Yruyur's Avatar
Its been a month now and not one hint of the smell. Im considering that foaming spray a success. Im also not putting on the recirculation all the time now. Thanks for helping out everyone.
Sent from a Motorola DynaTAC 8000X now Free
Old 10-16-2013, 12:01 PM   #25
BareZ
Drives: SUBARU BRZ,VW MK5 R32
[ame="http://www.youtube.com/watch?v=f9dw5mNi7vs&feature=share&list=PL0F79444CB 482921F"]LIQUI MOLY Klima Fresh - YouTube[/ame]
BareZ is offline   Reply With Quote
Old 10-16-2013, 02:25 PM   #26
muffinz
Drives: 2013 DGM BRZ Ltd
One thing that I always do to keep the air in the car fresh is after using the A/C with recirculate ON, I turn the A/C off before turning the car off and make sure the recirculate is OFF.
This way, the inside of the car will be connected to the outside atmosphere.
If you turn the car off with recirculate still ON, it will keep that vent shut, and the air inside your car will be stagnant and unconnected to the outside atmosphere, promoting mildew and mould growth.
~17k miles on my brz and no odors.
muffinz is offline   Reply With Quote
Old 10-16-2013, 03:03 PM   #27
Tman08
Tman08's Avatar
Drives: DGM BRZ Limited
Just grab a damp rid box that sucks the moisture out...10 bucks and no smell.
Tman08 is offline   Reply With Quote
Old 11-09-2013, 08:10 PM   #28
SavEvoIX
Drives: Evolution IX, 13' FR-S White Out
ICMF
SavEvoIX is offline   Reply With Quote
strong odor @ higher rpm's mRdeMs83 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 91 05-31-2021 08:07 PM
Car wont start? Anyone else? ScionFrsFan Issues | Warranty | Recalls / TSB 150 06-09-2017 09:35 PM
Anyone getting an intermittent isopropyl odor? FRiSson Issues | Warranty | Recalls / TSB 10 04-29-2013 11:07 AM
Front bumper wont come off! help! mashal Cosmetic Modification (Interior/Exterior/Lighting) 14 12-17-2012 02:50 PM
how do you remove odor from fabric? prest1ge Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 29 07-03-2012 08:45 AM
