| View Poll Results: What weight oil do you run for track days? | |||
| 0W-20 |
98 | 40.66% |
| 5W-20 |
12 | 4.98% |
| 0W-30 |
21 | 8.71% |
| 5w-30 |
76 | 31.54% |
| 10W-30 |
7 | 2.90% |
| 0W-40 |
16 | 6.64% |
| Other |
11 | 4.56% |
| Voters: 241. You may not vote on this poll | |||
#15 |
I took a gamble with Redline 0w20 for street and track because of higher moly content and favorable UOA so far. My UOA after track and autox is good. Seems like one of the better choices in 0w20 land for hard driving. But, lets face it don't have a lot of data to compare it to.
#16 | |
At the track, the 0W-20 would probably flow more quickly at start-up especially if you are ice racing. The cold cranking viscosity of a 0W oil is measured at -35C and a 5W is measured at -30C. http://www.pqiamerica.com/coldcrank.htmI'm pretty sure that the 5W-20 uses no Viscosity Index Improvers which is why the VI is so low. VII's are usually the first thing in oil to break down. You can also email Red Line as they are very good at responding to emails and recommend the proper oil for your specific application. In all likelihood, Dave will probably recommend to use the minimum viscosity recommended in the manual. You could also ask if one oil has any advantages over the other (like shear stability) at the track. The NOACK volatility (% of evaporation loss) is also slightly better on the 5W-20 than the 0W-20 (8% vs 9%). The same goes for most Amsoil 0W-20's vs the 5W-20's. Most 5W-20's of any brand have lower NOACK than 0W-20's, but definitely better than 5W-30's. I would want lower NOACK in something like an HPDE. Probably not quite as important at an Auto-X with only short bursts of hard driving. Look at the NOACK on typical 5W-30's: http://www.pqiamerica.com/March2013P...sallfinal.html Many are right around 12-14% and the maximum allowed is 15%. NOACK can be difficult to find since lower NOACK usually means a better base stock and manufacturers don't want you to know about their base stocks. The lowest NOACK figures usually come from oils made from or contain ester base stocks (some Amsoil, Red Line, some Motuls) and GTL base stocks (Pennzoil Ultra). More info on NOACK = http://www.pqiamerica.com/noack.htm Unfortunately, the numbers on the bottle don't tell you much. They only tell you that the oil passed the cold cranking viscosity test at -30C or -35C, and the viscosity at 100C is within a certain range (5.6 - 9.29 for a 20 grade and 9.3 - 12.49 for a 30 grade). -Dennis Last edited by bluesubie; 09-05-2013 at 11:54 AM. |
| The Following User Says Thank You to bluesubie For This Useful Post: | kster1 (09-05-2013) |
#17 | |
![]() -Dennis |
| The Following User Says Thank You to bluesubie For This Useful Post: | Dezoris (09-05-2013) |
#18 |
Drives: 2013 SWP BRZ
Where are you getting that figure of 25% shearing? and how is it measured? just curious.
#19 |
In Test:Oil Fed SC
Drives: Vortech Prototype Test Car
300v also come 0w20 good stuff
#20 |
Curious to see your samples when you have time.
| The Following User Says Thank You to Dezoris For This Useful Post: | 448hpsti (09-05-2013) |
#21 |
Drives: 2013 Firestorm FR-S
anyone care to comment on the overall results of the poll? I guess I'm surprised by how many people are running 0W-20 based on the comments I've seen posted.
2013 Firestorm FR-S, MTX, build date 1/13.
#22 | |
Oil Weight Poll For Track Usage
http://www.redlineoil.com/product.aspx?pid=124&pcid=21 9.1 when new and 6.91 in the used oil analysis. Of course there will be slight variances from batch to batch in oil as well as the margin for lab error (as well as my math error). The best way to compare is to submit a virgin (unused) sample of your oil along with the used sample. If Blackstone doesn't have a voa on your particular oil in their library, sometimes they'll do it for free. You can also find a lot of them posted in the VOA forum at bobistheoilguy (although the search function there is a real pain. google ftw). -Dennis P.S. - There are some Motul 300V 0W-20 uoa's in the Maintenace forum in the ongoing used oil analysis thread. Don't recall if there are any on tracked or auto-x cars though. http://www.ft86club.com/forums/showthread.php?t=13286 Last edited by bluesubie; 09-05-2013 at 06:44 PM. |
#23 | |
Oh cool, well in that case I had 15.45% shearing in 988 miles on my German Castrol 0w30 based on Castrol's specifications and my Blackstone UOA (about 250-300 track miles) |
#24 |
we use the Motul 300V 0W20 on our car.
#25 |
Drives: bmw
any consensus or updates on this
?0w20 now wondering if i should switch to 0w30 or 5w30. chicagoland. |
#26 |
Drives: 13' Scion FRS Track car
what's the 2015 consensus
?0W20 MOTUL 300V ? I am in miami so it's pretty hot in here
2013 Scion Frs Track Car - Sold.
#27 | |
Drives: bmw
http://www.bobistheoilguy.com/forums...topics/3739658
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com |
#28 | |
-Mike Paisan ![]() Maintaining, Modifying and Educating TriState Enthusiasts since 2001. Like us on Facebook! | E-mail: sales@azpinstalls.com | 725 Fairfield Ave | Kenilworth, NJ 07033 | 908.248.AZP1 (2971) |AIM: AZP Installs "Race Tested, Enthusiast Approved!" |
| Scratches from Window Usage? | DieselxIndustry | Issues | Warranty | Recalls / TSB | 27 | 03-08-2015 09:03 PM |
| Help: keyless access trunk usage | ohtheantics | BRZ First-Gen (2012+) — General Topics | 13 | 09-07-2013 03:17 AM |
| Track Day: Upcoming Joey G Open Track Day for ADVANCED Drivers, Aug 20 NJMP Lightning | AZP Installs | NY / NJ / CT / PA | 11 | 08-21-2012 12:31 AM |
| Stock tires usage in winter? | ft86Fan | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 07-13-2012 10:38 AM |
