#15 |
#RememberTheBuster
Drives: Firestorm FRS MT
how much are these?
#17 |
#RememberTheBuster
#18 |
AutoX-10/10ths every run
Car is still on jackstands ATM. Won't be driving it until next weekend as I need to get an alignment done so I don't kill my rear tires. I'll post back once I've driven it for a bit.
#19 |
Ok. So been driving on these for about a week.
I ended up going with -2.5 camber 0 toe in the back to start. I've been told that it may be too much with suggestions of -1.7 to -2 and -1.5. I want to run an AutoX event with it as it sits now to see how it does and then decide if it is too much. As far as noise, I don't notice much more than the car was already making with the other mods that I had on there. Two things that you need to be aware of with these parts: 1) The end links are a REALLY tight fit in the LCA. Depending on the tolerances of the LCA and the endlinks, you *might* have to shorten the bolt barrel or eyelet bushings to get them to fit. 2) There are 2 keyed washers for the toe link eyelet where it mounts to the subframe. When you are installing them the washer likes to rotate. If it does the eyelet will float in the subframe and make the car have bumpsteer-like behavior in the rear. Make sure they seat properly when you tighten them up.
| The Following User Says Thank You to whataboutbob For This Useful Post: | RehabJeff86 (10-19-2013) |
#20 | |
Drives: 2013 FRS Asphalt
How much camber do you have in the front. The general rule is to always have more up front then you do in the rear. I'm running -1.9 in the back side to side. and -2.5 in the front.
2013 Scion FR-S AT Picked up 5/30/2012
#21 |
Right now I'm -2.75 F -2.5 R.
#22 | |
Just a dude
Drives: Scion FR-S 2013
Say this as well when we lower this car, the back is natural, front thats a different story in getting past -2 camber up front without tophats is well impossible??
#23 |
Crash bolts not the oem ones. The white line bolts gave me over -2degrees.
#24 |
Drives: '13 BRZ in WRB--let's mod!!!
Are you experiencing any clunking noises?
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD * '22 Z51 Vette--sold. * '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties. * '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot. |
#25 |
Me? With the camber bolts no. But a shit ton when i used the whiteline top hats.
#26 |
I haven't got any clunking noise out of the rear at all.
My fronts are still quiet as well. I put the subie washers on at the same time I replaced my COMCs with a fresh set. I should also note that I've got the whiteline camber bolts, and both front LCA bushings, and RCE springs.
#27 | |
#28 |
PM me.
| BC Racing, Whiteline Sway Bars, Kartboy Rear End Links, Carbotech, DBA@ OAKOS | OAKOS Automotive | Brakes, Suspension, Chassis | 226 | 01-19-2015 02:46 PM |
| Rear Whiteline UCA bushings, possible dealer F**Kup? | OICU812 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 06-19-2013 02:22 PM |
| WORKS Rear Upper Control Arm Bushing - Inner Camber Correction | 86_ZN6 | Brakes, Suspension, Chassis | 0 | 02-06-2013 01:20 AM |
