Old 09-02-2013, 08:25 AM   #15
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
how much are these?
Enraged21 is offline   Reply With Quote
Old 09-02-2013, 08:45 AM   #16
Dan@AWD
Drives: 2013 Argento FR-S
Originally Posted by Enraged21 View Post
how much are these?
$476.91
Sent from my Moto X.
Dan@AWD is offline   Reply With Quote
The Following User Says Thank You to Dan@AWD For This Useful Post:
Enraged21 (09-02-2013)
Old 09-02-2013, 08:49 AM   #17
Enraged21
#RememberTheBuster
Enraged21's Avatar
Originally Posted by Dan@AWD View Post
$476.91
Not bad
Old 09-02-2013, 11:53 AM   #18
whataboutbob
AutoX-10/10ths every run
Originally Posted by OICU812 View Post
God damn the lca look good to bad they're a unicorn to the common joe!
Any oddities with noise or feel after driving with them?
Car is still on jackstands ATM. Won't be driving it until next weekend as I need to get an alignment done so I don't kill my rear tires. I'll post back once I've driven it for a bit.
Build thread:Here
Old 09-18-2013, 01:43 PM   #19
whataboutbob
Ok. So been driving on these for about a week.
I ended up going with -2.5 camber 0 toe in the back to start. I've been told that it may be too much with suggestions of -1.7 to -2 and -1.5. I want to run an AutoX event with it as it sits now to see how it does and then decide if it is too much.
As far as noise, I don't notice much more than the car was already making with the other mods that I had on there.
Two things that you need to be aware of with these parts:
1) The end links are a REALLY tight fit in the LCA. Depending on the tolerances of the LCA and the endlinks, you *might* have to shorten the bolt barrel or eyelet bushings to get them to fit.
2) There are 2 keyed washers for the toe link eyelet where it mounts to the subframe. When you are installing them the washer likes to rotate. If it does the eyelet will float in the subframe and make the car have bumpsteer-like behavior in the rear. Make sure they seat properly when you tighten them up.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
RehabJeff86 (10-19-2013)
Old 09-18-2013, 05:36 PM   #20
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
How much camber do you have in the front. The general rule is to always have more up front then you do in the rear. I'm running -1.9 in the back side to side. and -2.5 in the front.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 09-18-2013, 09:50 PM   #21
whataboutbob
Right now I'm -2.75 F -2.5 R.
Build thread:Here
Old 09-19-2013, 02:20 AM   #22
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
General rule if you are racing and tracking the car I presume?
Say this as well when we lower this car, the back is natural, front thats a different story in getting past -2 camber up front without tophats is well impossible??
Old 09-19-2013, 09:30 AM   #23
feldy
feldy's Avatar
Crash bolts not the oem ones. The white line bolts gave me over -2degrees.
Old 09-19-2013, 03:37 PM   #24
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Are you experiencing any clunking noises?
* ‘23 Corolla GR—AutoX/DE toy
* '13 Toyobaru P&L Turbo WRB BRZ SCCA XS-A build starting. SOLD
* '22 Z51 Vette--sold.
* '09 Nissan GT-R--gone, but not forgotten... 10.63 @ 131+ on streeties.
* '90 ZR-1 11.0 @ 130.2 & 11.2 @ 132.4 sprayed 120 shot.
GTB/ZR-1 is offline   Reply With Quote
Old 09-19-2013, 04:21 PM   #25
feldy
feldy's Avatar
Me? With the camber bolts no. But a shit ton when i used the whiteline top hats.
Old 09-19-2013, 09:36 PM   #26
whataboutbob
I haven't got any clunking noise out of the rear at all.
My fronts are still quiet as well.
I put the subie washers on at the same time I replaced my COMCs with a fresh set. I should also note that I've got the whiteline camber bolts, and both front LCA bushings, and RCE springs.
Build thread:Here
Old 09-20-2013, 10:49 AM   #27
GTB/ZR-1
GTB/ZR-1's Avatar
I'm having issues with clunking & rear instability. I'm using stock toe links. I'm trying to visualize your # 2 point & if this may somehow be involved with what's going on...
Old 09-23-2013, 01:06 AM   #28
whataboutbob
PM me.
Build thread:Here
BC Racing, Whiteline Sway Bars, Kartboy Rear End Links, Carbotech, DBA@ OAKOS OAKOS Automotive Brakes, Suspension, Chassis 226 01-19-2015 01:46 PM
Rear Whiteline UCA bushings, possible dealer F**Kup? OICU812 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 06-19-2013 01:22 PM
WORKS Rear Upper Control Arm Bushing - Inner Camber Correction 86_ZN6 Brakes, Suspension, Chassis 0 02-06-2013 12:20 AM
