#15 | |
Drives: 2003 Subaru Outback
" I know a lot about cars, man. I can look at any car's headlights and tell you exactly which way it's coming. "
#16 |
I Love custom Turbo kits
Drives: Limited BRZ
Well, there's a Caveat with the LCA's. They move Toe at the same time as Camber. So in my case, I was at -2.4 and was able to dial it in to -1.3. It could not be dialed in down more because the Toe had no more room for adjustment. So in theory yes, you can go from -2.5 to -1, but you will also need adjustable Toe. NOW, specifically talking about the SPC LCA's, they do include a Toe Bushing to allow bigger Toe adjustments. With the Toe bushing, you will be able to make it.
| The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post: | Keenercarguy (04-25-2016), Tansey86 (08-18-2013) |
#17 | |
| The Following User Says Thank You to Tansey86 For This Useful Post: | Sportsguy83 (08-18-2013) |
#18 | ||
Drives: '23 BRZ
Even if that $500 is just kept in a jar instead of being spent on unneeded parts/labor, it would take 20 years to recoup the investment! Much better to not spend the $500, even from a purely financial perspective. FWIW, I'm running -2 in back on the S2000 and my RS-3 rears are at nearly 20k and still 1/32 left to the wear bars. I just looked at them, and the wear is actually EVEN across the four circumferential grooves. The only discernable "camber wear" is a bevel across the inner half of the innermost tread blocks. Quote:
This thread is starting to remind me of threads I see on S2ki where people want to slam their cars and run uber-hella-flush setups, but don't want to have to run any camber! OEM camber settings are WAY conservative. You can run a LOT more without any big negatives and with the big positive of increased ultimate dry grip. -2.35 is not too much for the street, IMO. Toe is way way WAY more of a factor in tire life. |
| The Following User Says Thank You to ZDan For This Useful Post: | Sportsguy83 (08-18-2013) |
#19 |
Drives: Limited BRZ
^ Agreed, I just thought the SPC's at $200 (new revision, the old one did not look beefy and up to the task) are a good option, but you do make great points.
#20 |
Hella Flush
Drives: 2013 SWP BRZ
I have ST coils as well and just swapped the front crash\camber bolts in the front, to get get rid of the current rub i was getting in the front. Once the car was aligned the car handles great for my purpose of DD.
#21 |
I may do an AX or 2, and I may also do a track day as well.
I went with staggered, 245 front and 265 rear, so I figured if I went with less rear camber and more front camber, it might help with the extra understeer that my wheel/tire choices will cause. I still have the stock wheels and tires, and I've tossed around the idea of getting some sticky tires for those wheels and use them for AX or track days. I'm not too worried about tire wear, just trying to set my car up to be balanced if i can. Thanks for the replies, I may just leave it all alone. Asking questions and getting answers helps me decide what I want to do. |
#22 | |
Drives: GT86
I had -1.29 (L) & -2.29 (R) before the bushes.
PROJECTGT86 |
#23 | |
Captain Cocoa
Drives: CBS BRZ MT
| The Following User Says Thank You to SubaSteve For This Useful Post: | Sportsguy83 (05-26-2014) |
#24 |
Thanks
Do they make a complete kit? When i bought a kit for my honda (ingalls) it came with adjustable toe and camber arms.
#25 |
Drives: 2022 BRZ
Just to clarify, lower control arms are used to increase and decrease camber?
| ~~CUSCO Rear Lower Control Arms!!~~ | nemesisdrift | Brakes, Suspension, Chassis | 2 | 05-20-2013 03:35 PM |
| DIY Request: Rear Lower Control Arms | Ryaquinn | DIY (Do-It-Yourself) Guides | 2 | 05-08-2013 07:25 PM |
| SPC Rear Adjustable Lower Control Arms | Bcarlos | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 04-19-2013 11:56 PM |
| SPC rear lower control arms, Fix your camber! | JoeBoxer | Brakes, Suspension, Chassis | 12 | 03-31-2013 08:02 PM |
| cusco rear lower control arms for FR-S BRZ | driver01 | Canada Classifieds | 3 | 02-01-2013 06:28 PM |
