Old 08-29-2013, 04:08 PM   #15
Admiral Ballsy
Shorter of breath
Admiral Ballsy's Avatar
Drives: a soft bargain
We have 2010+ LGT rears. LGT fronts are a semi-popular upgrade on the WRX as well; them sumbitches are HEAVY though.
They add six pounds per side; five in the disc and one in the caliper/bracket.
Originally Posted by SuperGTBRZ View Post
It's an affordable brake upgrade. Just an idea if someone is looking for a cheap brake upgrade.
It can be done for less than $200 if you shop around.
Admiral Ballsy is offline   Reply With Quote
Old 08-29-2013, 04:43 PM   #16
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
But many have argued that bigger disk isnt actually providing you better stopping power. A few have actually done some testing/power and basically said the stock set up is as good or better than this "upgrade" route
Old 08-29-2013, 04:53 PM   #17
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Bigger disk isn't going to provide you outright increased stopping power, it will help with fade resistance.
You're better off with upgrading pads and fluids/lines for an immediate improvement.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
charged86 (08-29-2013)
Old 08-29-2013, 05:34 PM   #18
Admiral Ballsy
Shorter of breath
Who?
I've seen nobody here claim to have done Legacy/Forester XT front brakes. If I've missed it in my searching, please direct me!
These brakes have a little more clamping power, both from the larger pistons and the larger 'lever arm'...neither probably noticeable.
All else equal, it's undeniable that there is a potential thermal management improvement from the extra mass and surface area.
Old 08-29-2013, 05:36 PM   #19
Admiral Ballsy
Shorter of breath
I agree, disc size has little to do with stopping power; are you seriously claiming that lines do?
Old 08-29-2013, 05:59 PM   #20
mav1178
mav1178's Avatar
For stopping power, lines won't matter.
Yes, stainless lines help with pedal feel and modulation. But one needs to consider the context... no point in running a superior pad (higher temp range) than stock, only to have it limited by stock fluid and/or lines. Pads + fluid/lines are easy mods that improve the braking performance. You can go without line upgrades but if one isn't going BBK, it's a definite worthwhile upgrade to have when changing out to better brake fluid.
For the average driver, lines and pads make the biggest difference in terms of feel. And if one were to swap out lines, you'll need to replace fluid anyhow.
-alex
Old 08-29-2013, 06:10 PM   #21
mid_life_crisis
Drives: FR-S 10 #103 AT
According to the basic rules of leverage, if you change nothing except the disc size and move the calipers outward to fit, you should improve stopping power. Maybe not enough to notice the difference, but it should make a difference. Are you guys saying reality does not match up with theory in this case?
Is there any consensus on what pads are best for hard street use?
Old 08-29-2013, 06:29 PM   #22
Admiral Ballsy
Shorter of breath
I'm saying in this particular example it's not noticeable. You're moving the caliper out bit less than a half-inch; the pistons are larger but I suspect once you factor in the fluid displacement-per-unit-distance-of-pedal-stroke, that change is negligible as well.
Pad composition is going to make a much bigger difference than anything else. And it seems like increasing friction characteristics works in direct oppostion to cleanliness!
Old 08-29-2013, 06:45 PM   #23
Dezoris
Dezoris's Avatar
Originally Posted by ft86me View Post
Found my answers . going wilwood with 6 front and 4 rear. Thanks everyone.
Why did you chose Wilwood? Cost?
Old 08-29-2013, 06:46 PM   #24
CSG David
CSG David's Avatar
Brake bias will change when you swap brake setups. Some BBK companies have done their calculations, R&D, and testing to ensure it retains similar brake bias or what they believe to be a more optimal brake bias with their system. More than likely, you will need to experiment with different brake compounds to find the best match if you intend to change the front brake setup that's different from stock.
To give you an idea of how proper brake balance should look:
https://www.facebook.com/photo.php?f...type=1&theater
If you let us know what your car setup is, your driving resume, and intended application is, we can help better assess your braking needs.
Brake Pads, Rotors and All Your Brake/Suspension Needs! Great Prices!! Check it out!! Mike@CZP Brakes, Suspension, Chassis 348 06-01-2018 01:29 PM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-25-2013 12:26 AM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 11:20 PM
Secondary Rear Brake Caliper for drifting or parking brake?? (pics) Axel Scion FR-S / Toyota 86 GT86 General Forum 20 02-25-2010 11:28 AM
