#15 |
SLO NO MO
Good job. I also recommend adding some copper or stainless steel wool in there to give the oil vapor some surface area to condense on to.
#16 |
Drives: Asphalt Scion FR-S
I'm interested to see how you mounted it. The first image doesn't seem to be working.
Sent from my SCH-I535 using Tapatalk 4
#17 |
Drives: 13 White MT FR-S
Its really not mounted to anything. The hose is stiff enough that the can just kinda leans on the support bar
#18 |
Drives: slow
What exactly is that thing marketed as? There's no Harbor freight in Canada, The next best thing is Princess Auto, but I'd need to know what I'm asking for if I go looking for it.
#19 |
Drives: WR Blue BRZ, 240Z
The four screw holes at the top of would be perfect for mounting two cushioned clamps.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
| The Following User Says Thank You to Gary in NJ For This Useful Post: | ML (08-13-2013) |
#20 |
blowhard
Drives: frs, project forester
#21 |
Drives: 2005 Lotus elise, 2013 Scion FRS
why did you remove the filter?
#22 |
Drives: Firestorm 86
Great job for a cheap alternative oil catch can I'll definitely look into it and do it soon
Also I think its great for it to be clear so you'll know when you need to drain. Thanks for posting |
#23 | |
SLO NO MO
The filter media probably restricts quite a bit. Not sure that would be good for an air/oil separater or catch can use case. Would probably get clogged up with oil pretty easily as well. Typically you would want some loose material with a lot of surface area for the vapor to condense on to, and something that wont deteriorate or rust, since you don't want any of that crap going back into your engine. |
#24 |
ML, from a safety perspective, it would be worth investigating if you could safety wire the bottom fitting of the catch can to the top mount. This would keep it from twisting off the boss fitting. I would also run the safety wire through some clear tubing from top to bottom so the wire doesn't cut through the plastic oil trap.
#25 | |
#26 |
I hold a aircraft repairmen's certificate and I've done a little bit of motorcycle racing, so I'm a little obsessive about these things.
So the bottom part (plastic) of that air/oil separator just twists off. There is a possibility that the bottom could inadvertently twist off due to vibration. I would secure the plastic bottom to the metal top. Since there isn't a hole in the plastic body to insert twisted safety wire, you will need to attach something to the bottom drain fitting where you can pass safety wire. To keep the safety wire from damaging the plastic housing, I would encase the wire (that now runs from the top to the bottom) in plastic clear plastic tubing. I suggest clear so you can always inspect the condition of the safety wire.
#27 |
Possibly use their larger unit
Item 68230 http://www.harborfreight.com/38-in-c...ter-68230.html Sent from a Motorola DynaTAC 8000X |
#28 | |
| Freight charge on Scion FR-S? | euroshowoff | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 04-25-2013 11:36 AM |
| Oil Catch Can.? | Cjs_ | Engine, Exhaust, Transmission | 18 | 03-01-2013 12:58 AM |
| Remember Pearl Harbor today | ML | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 12-07-2012 10:40 AM |
| Aluminum 1.5 Ton Racing Jack on sale at Harbor Freight | Foobar | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 22 | 11-22-2012 02:42 PM |
| Museum and Harbor Panaromas (caution wide) | Dadhawk | Other Vehicles & General Automotive Discussions | 0 | 04-08-2012 06:20 PM |
