#15 |
Drives: Silver FRS
are there more benefits going aluminum as opposed to carbon fiber?
#16 |
Drives: Pavement MT GR86
I think just price.....I was looking at cf shafts for my wrx....they were ~25% lighter smaller od and twice the price of aluminum. ( aluminum has to be thicker to equal the strength of cf)
GR86 MT premium
#17 |
That Guy
Drives: 2013 asphalt FRS MT
CF will also twist more before it breaks, acting a little like a sprung hub clutch. This can be an advantage as it's more forgiving.
#18 |
Drives: 86
@slates74 what was the highest speed you have gone with the new drive shaft?
The only thing that is holding me now is that I hear that Aluminum drive shaft vibrates at high speed while Carbon Fiber don't.
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
#19 |
Drives: WR Blue BRZ, 240Z
I like the idea of a single piece aluminum driveshaft, but I keep on coming back to the same question:
On a car that is supposed to be light and inexpensive, why did the factory choose a heavier & more expensive to produce driveshaft? There has to be a reason they went with a two-piece shaft; such as a destructive harmonic vibration that was damaging the transmission or differential...or some other reason. Twelve pounds is a lot of weight savings in the drive train, but I'm just not sure I want to jump on this band wagon until there is long-term experience with the lightweight shafts.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
#20 |
Drift Specialist
Drives: 180SX,GT86
so it sounds like theres some noticeable noise i remember my 1 piece ds on my 240sx made huge wining noises over time. good price though...
#21 | |
degrees
Drives: 6MT BRZ
It's to combat NVH. The same goes for the dual-mass flywheel. Lightweight and/or solid bits cause shakes, rattles, and noise that people would otherwise equate to an issue. Last edited by 37; 08-14-2013 at 06:30 PM. |
#22 |
The Mechanic
Drives: Civic Turbo,FR-S
i wont be there this week cause im in VA but next week if the weather is good ill go. police dam near host the meet lol so zip tie a front plate lol
| The Following User Says Thank You to Grip Ronin For This Useful Post: | charged86 (08-15-2013) |
#23 |
Drives: 13 SWP BRZ LTD 6MT
I've had the car near 100 mph so far and haven't noticed any vibration whatsoever. In regards to any extra noise, as I said before I can't discern any difference at this point at all. The only difference I could at first was that I could hear the typical rattle sound that the transmission makes at under 10 mph slightly more clear but even that has been hard to remember the difference of after driving this much. I really can't say enough good about this mod for the price point. The car feels tighter and more responsive overall with no notable downsides.
#24 |
Drives: FR-S :)
@slates74, i need to get a ride along one time in the car and see how the car feels with the new driveshaft. I'm debating on getting this...
| The Following User Says Thank You to p00mba For This Useful Post: | slates74 (08-13-2013) |
#25 |
Drives: FR-S 6MT
I like the idea of having a lightweight drive shaft.. But why did the OEM choose to use a 2 piece system? Clearances perhaps? Cost? Maybe a stock part from something else? Would like to know some of the reasons behind the OEM design and choice.
#26 |
Update from Mark, the yokes are machined from forged pieces and this particular driveshaft is rated up to 700hp.
#27 |
The two piece construction is supposed to dampen sound more than a one piece but speaking from experience it's not an issue at all. In terms of clearance, after I took the car out for a drive yesterday we jacked it back up and inspected for any points that may have come in contact with the driveshaft and as expected there were none.
| The Following User Says Thank You to slates74 For This Useful Post: | ProjectD (08-27-2013) |
#28 | |
Drives: FR-S 6MT
| DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft | F1point4 | DIY (Do-It-Yourself) Guides | 67 | 04-17-2021 06:21 PM |
| PST vs Driveshaft Shop CF Driveshaft? | RehabJeff86 | Engine, Exhaust, Transmission | 4 | 08-26-2013 01:39 AM |
| DriveShaft's and Axle's | Driveshaft Shop | Engine, Exhaust, Transmission | 34 | 08-21-2013 06:17 PM |
| Driveshaft Shop CF Driveshaft installed. | Hawaiian | Engine, Exhaust, Transmission | 5 | 08-13-2013 03:04 PM |
| GFB 3-Piece lightweight aluminum pulley kit | Touge Factory | Engine, Exhaust, Transmission | 60 | 06-03-2013 02:52 PM |
