Old 08-12-2013, 01:09 PM   #15
Ndgreely
Ndgreely's Avatar
Drives: 2013 FR-S 2003 SRT-4 1964 Impala SS
I just purchased a drop in filter and would be interested in the snorkel delete DIY.. is there a link to this ??
Ndgreely is offline   Reply With Quote
Old 08-12-2013, 01:21 PM   #16
chrisbfrs
2012 car of the year
chrisbfrs's Avatar
Drives: Frontengine Reardrive-Sportcar
There is I think bit ill tell you how to do it.
First remove 10 mm bolts on top of the clip there are 5 of them. Then undo the 2 clips towards middle. Remove the hood gasket strip. Next part is easier with a helper but I did it by myself....pull gently up on the clip amd youll see 2 bolts that attach the snorkel. I think they are also 10mm may be 12mm cant remember. Now while still pulling up on the clip ypu have to finagle the snorkel out after a while it may start to seem impossible just keep at it, it will eventually come out just need the right angle and finess. But this mod is great and adds that boxer tone.
Modern Ink Tattoo
chrisbfrs is offline   Reply With Quote
Old 08-13-2013, 04:16 PM   #17
CaptivaBlueTeg
Drives: WRB Brz
Didn't perrin do a bunch of testing on intakes? I had planned to make my own, but from their r&d they posted on this forum just simply moving the maf can cause the car to run lean. That was my worry. I wanted to do an aluminum "icebox" style intake with a snorkel, but running lean scares me. No money for tuning software at the moment. Drop ins are supposed to be good till 200whp.
CaptivaBlueTeg is offline   Reply With Quote
Old 08-13-2013, 04:34 PM   #18
chrisbfrs
chrisbfrs's Avatar
The TRD intake relocates the MAS and it doesnt affect the afr. As long as MAS is housed in a 3 inch diameter pipe it will be ok.
Modern Ink Tattoo
Old 08-13-2013, 04:42 PM   #19
Kodename47
Kodename47's Avatar
Drives: UK GT86
That's not quite true. Any changes to the path will affect the air passing over the sensor. Quite how much is down to testing but even a dead straight pipe will cause different readings.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-13-2013, 05:13 PM   #20
CaptivaBlueTeg
Drives: WRB Brz
This^ basically what I was trying to figure out how to explain.
Old 08-13-2013, 07:36 PM   #21
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
Originally Posted by FR-Sizzle View Post
If you just make one that fits the OEM air box out of plastic then I am sure a ton of people would be interested as the Syms is just over priced
Yeah, if he made that snorkel I'd totally buy it + an elbow for mine. Have a drop-in and the rest stock at the moment. The FA20Club CAI looks slick, especially for the awesome price, but I don't want to remove my front bumper to service the filter. Shoot me PMs if anyone decides to fab up something like this.
Nightbringer is offline   Reply With Quote
Old 08-15-2013, 05:01 PM   #22
chrisbfrs
chrisbfrs's Avatar
Yes I know. There are many parameters that go into an air intake. I was just stating that you can move the MAS and still have a good AFR. You can also move it and run lean, it does take testing to find out what is optimal.
The intakes I made never had any stalling or idle dips and I relocated MAS. Relocating MAS can change the AFR readings....what I was meaning is change in OD of the intake pipe where MAS is housed will disrupt readings significantly.
Modern Ink Tattoo
AT owners only, custom CF paddle shifters, pin stripe custom color BRZPDX Cosmetic Modification (Interior/Exterior/Lighting) 80 02-03-2016 10:35 AM
FS: Custom Acrylic Accents, $13. YOUR custom design! Cupholder and Mission Tray too! Diode Dynamics Interior Parts (Incl. Lighting) 155 11-19-2014 11:42 AM
Need Help: Looking for built-in nav for FR-S! carlo1912 Electronics | Audio | NAV | Infotainment 1 09-06-2012 09:34 AM
Where is each AS1 car built? Fox Scion FR-S / Toyota 86 GT86 General Forum 18 01-08-2012 04:33 PM
