Old 08-13-2013, 08:10 PM   #15
PantsDants
Drives: Scion FR-S A/T, Whiteout
Just got off the phone with Ishii Motor Industries. They're building a stockpile of IS300 differentials just for the purpose of swapping final gears out for our cars.
PantsDants is offline   Reply With Quote
Old 08-13-2013, 10:20 PM   #16
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
Originally Posted by Jeff Lange View Post
Not all IS300's have LSD, so you'll want to make sure before buying one unless all you want is the ring and pinion.
Good point...
I wonder if there's a way to tell gear & LSD. Some are for sale on the 'ol eBay--but some of theses sellers are clueless as to what's inside the pumpkin lol.
GTB/ZR-1 is offline   Reply With Quote
Old 08-14-2013, 01:22 AM   #17
PantsDants
Originally Posted by GTB/ZR-1 View Post
Good point...
You're taking a gamble, but if the carrier still has the sticker on it, you want it to have one of the codes from the title of this thread. Those are the LSD versions.
Old 11-24-2014, 03:28 PM   #18
shif7i7down
Erected Member
Drives: frs
Will i just bought a is300 m85 lsd differential for 350usd and will be swapping out the oem+ 4.67 mfactory differential.
I'll let you guys know if it fits or not.
Couldn't wait for someone to prove it out so i guess I'll prove it to myself if it's a direct bolt on or not.
If theres enough interest i can document the install and if it works, might be of some use to other turbo guys out there
shif7i7down is offline   Reply With Quote
The Following 4 Users Say Thank You to shif7i7down For This Useful Post:
Calum (11-24-2014), Carlitoz3 (11-24-2014), Dipstik-sportech (11-24-2014), GhostOp86 (11-24-2014)
Old 11-24-2014, 05:51 PM   #19
Dipstik-sportech
Dipstik-sportech's Avatar
Lil late to the party bud I've been running with the m85 3.73 diff for 7 months now. 100% direct bolt in they're the exact same third member in both cars, the only differences are that the lexus uses stub axles which u just pop out and the Lexus uses Allen headed bolts for the rear mounts where as our cars have 17mm hex head
The Following 8 Users Say Thank You to Dipstik-sportech For This Useful Post:
brandonblt2 (06-14-2018), jcw99 (03-07-2016), JohnJuan (11-25-2014), murdoc (11-24-2014), shif7i7down (11-25-2014), spitfire481 (11-24-2014), SportInjected (11-24-2014), wparsons (11-24-2014)
Old 11-24-2014, 10:30 PM   #20
spitfire481
spitfire481's Avatar
Drives: 2JZ FRS
I have one as well. Great mod for turbo cars
Pure Automotive Performance
MoTeC
Build Thread
@spitfire481
Old 11-24-2014, 10:56 PM   #21
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
I need one
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 11-24-2014, 11:31 PM   #22
kodyo
Drives: Scion FR-S
Also did the swap with a standard 7.8" V6 toyota gearing (4.56 ratio), documented my build on the tail end of this DIY:
http://www.ft86club.com/forums/showthread.php?t=54054
kodyo is offline   Reply With Quote
Old 11-25-2014, 07:22 AM   #23
shif7i7down
Erected Member
Drives: frs
Do you have a diy thread i can look at.
And...
Old 11-25-2014, 07:37 AM   #24
Dipstik-sportech
No diy thread as I'm the kind of person that just likes to get shit installed lol. It's really not difficult, just got to remember to take the lower control arm and toe arm off the hub side so u can remove the axles from the diff.
I cant remember if I put it in this thread or not
http://www.ft86club.com/forums/showthread.php?t=40169
Old 11-25-2014, 08:28 AM   #25
shif7i7down
Erected Member
Drives: frs
Nice car, i can only wish to be as beasty as you.
The Following User Says Thank You to shif7i7down For This Useful Post:
Dipstik-sportech (11-25-2014)
Old 11-25-2014, 07:30 PM   #26
kodyo
Drives: Scion FR-S
And...
Check my last post, that's a DIY thread on how to do the swap. The original guy who did it was really concise, but my stuff is kind of a cluster f@ck, so hopefully it makes sense and is helpful. Assuming that is what you are asking for.
The Following User Says Thank You to kodyo For This Useful Post:
Old 08-14-2015, 12:17 PM   #27
mrk1
Drives: Sterling BRZ Ltd
Update an old thread, I just purchased a $99 Lexus diff off eBay. I thought it was going to be a 3.91 open and I was just going to pull the ring and pinion but upon arrival I found its a 3.91 Torsen LSD! The part number sticker is no longer there so I know this may not be a huge help but I'm pumped!
3.91 LSD should be M98, I was just under the impression it was clutch type
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
jcw99 (03-07-2016)
Old 08-14-2015, 01:55 PM   #28
fika84
fika84's Avatar
That's a nice surprise! My understanding is that none of the lexus rear ends are clutch type. Where did you read/see that they were?
You're boosted though right? So are you just going to bolt up this rear and for the longer gears?
fika84 is offline   Reply With Quote
FBM 8.8 IRS Rear Diff Conversion FullBlown Forced Induction 133 12-26-2015 11:35 AM
Rear Suspension Video (Look at diff bushings!) d1ck Tracking / Autocross / HPDE / Drifting 0 07-01-2013 11:02 PM
Rear diff service JoeBoxer Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 22 11-06-2012 11:23 PM
T1R Rear Diff colars ! AJ PwR Engine, Exhaust, Transmission 0 10-09-2012 11:00 PM
Cusco Rear Diff. Jewelry Blaaaack-BRZ Engine, Exhaust, Transmission 24 05-12-2012 04:28 PM
