#15 | |
Drives: Toyota GT 86
#16 | |
What parts do you need to buy to get this done? Any need to reprogram ABS or other braking systems? Thanks for the info! |
#17 | |
#18 | |
Señor Member
1974 TA22 Celica
2013 86 GT |
| The Following User Says Thank You to Turdinator For This Useful Post: | OnionTou (08-10-2013) |
#19 | |
#20 |
#21 | |
I'll PM you to clean up the topic a bit. Again, there are multiple brake pad compounds that do exactly what they are supposed to do for your intended application. Now if you can fade full on race brake pads with brake ducting, then you will need to upgrade brake components. |
#22 |
Drives: 2012 Toyota 86 GT Spec
I have a GT86 and completely fried my front pads and rotors after my last trackday. The stock pads were good for 3 laps and couldn't lock up the front anymore. This time I was running Dunlop Z1's so I think the added grip of the tyre simply cooked the brakes.
Heading to the brake man today to see about the larger slotted rotors plus better pads and fluid. Hopefully they will fit under the standard 16 inch wheels. |
#23 | |
Second, Slotted rotors won't fix a fade issue. It cuts the pad so you get that extra bite, but it doesn't help you after your brake pads are overheated. Boiling brake fluid is also an issue that just needs to be addressed with better brake fluid. In conclusion, use the proper brake pads and brake fluid. Even BBKs will fade if you don't use the right pads and fluid. Do it right the first time and you won't have all the issues you have now. |
#24 |
A few months ago I asked about the brakes on the base GT86 vs the US Spec (or top spec in other countries). and with some advice and difficulty to obtain the vented rotors/calipers for the top spec, I decided the best thing at that moment was to upgrade my current setup with better fluid, better pads and stick to the current vented rotors front, solid rear disc.
I bought some brakepads from CSG (thanks Dave!), but I never got around to install them hoping to swap a bunch of parts at the same time (rotors, fluid, pads, lines). This week as I was window shopping for rotors (vented slotted rotors front, solid slotted rotors back) I got a call from a friend who was selling his rotors from the upper spec version. Just the rotors, so I would need to buy some calipers. I kept asking around and it turns out that the price of calipers, would be the same as the cost of the rotors. I can always sell my unused pads to a friend from my local GT86 club. I've noticed the difference in size of the pads is virtually none (front pads are the same, rear there is a slight 2 mm difference in width). so the contact area with the disc is virtually the same, the key difference is that the rear rotors would be ventilated. How much difference does that make? |
#25 | |
#26 |
Drives: GT86
I have the "lower" spec GT 86 in Aust, changed my wheels to 17x9 +38.
Upgraded rear rotors to DBA t3 4000 (not ventilated as they wont fit, unlike "upper" spec) and have upgraded front brakes to Buddy Club 330mm BBK. [IMG] [/IMG][IMG] [/IMG]
#27 |
Drives: AE86, 2x GT86, TE27
I have the same lower spec car. I've replaced the front with wilwood bbk, and trd rear lines and pads in the rear. Well balanced. IMO you don't need anymore rear braking than that.
#28 |
Drives: GT86
i noticed a little bit of bias when i was bedding in the rotors, but that could have been road surface. got a couple of track days in a few weeks to test them out properly. pb was a 1.10.9 on stock rotors/ferodo ds2500 front pads, stock rear pads. hoping to knock of a second or 2 with the new setup
| ** PRE-ORDER ** Nur Spec GT86 Aero Kit ** From Carson Toyota | Carson Toyota | Exterior Parts - The Rest | 91 | 01-20-2016 10:15 PM |
| UK Spec Toyota GT86 2.0M | lordgrover | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 0 | 10-18-2012 08:38 AM |
| First UK Spec GT86 Delivered! | Keszki | Member's Car Journals | 9 | 07-27-2012 02:51 PM |
| New Zealand to receive TRD Spec GT86 Priced from $63,486 ($50,841US). | CozmoNz | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 07-22-2012 09:00 AM |
| please explain the different lower front lights on US spec BRZ | torquemada | BRZ First-Gen (2012+) — General Topics | 30 | 12-04-2011 12:18 AM |
