Old 08-04-2013, 03:08 PM   #15
cslntuee
Drives: Subaru BRZ Limited
Originally Posted by wparsons View Post
You definitely don't want to swap out just the rear sway bar. Doing so will upset the balance of the car. This isn't a front heavy FWD car that needs help rotating, it's a well balanced RWD car.
I saw the TRD (USA) only release the rear sway bar for FRS without front. ><
http://www.toyotaterritory.com/scrip...idproduct=1733
cslntuee is offline   Reply With Quote
Old 08-04-2013, 03:26 PM   #16
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by FriedRicr View Post
about a finger to a finger and a half from stock if possible. and oh no, you didn't offend anyone. didn't mean to sound hard like that. completely appreciate your help!
It's been said, but I want to repeat it because it's true. Audi's are nose heavy and because of it require VERY different suspension tuning.
For what you've stated I'd suggest Racecomp Engineering springs, front camber bolts, and possibly front control arm bushings.
If you get an alignment and the rear camber isn't even then you should look into a way to correct that, but I think you should leave it until then.
The Following User Says Thank You to Calum For This Useful Post:
console_cowboy (08-04-2013)
Old 08-04-2013, 03:55 PM   #17
console_cowboy
console_cowboy's Avatar
Drives: 2013 Black BRZ Limited
I'm going to have to say that I agree with most of the above posts... Starting with a rear sway bar is an odd place to start for these cars. Not the worst place to start if you have an audi though.
I would really go with what other people say and recommend a quality set of springs that matches your goals. I went with RCE Yellow springs myself, but I wanted a neutral handling car. You could look at Swift or some other options if you want different handling characteristics than the RCE Yellows provide.
I would say that the alignment matters quite a bit on the FT86 platform. Small changes in alignment have given significant changes in handling. I am currently running about -1.3 front camber, -1.2 rear camber, 0 front toe, and just a slight toe in on the rear. This, combined with RCE yellow springs has given me an excellent handling and very predictable car. I'm running the inexpensive SPC rear control arms in the rear, as well as crash bolts up front to even out my camber. With only crash bolts, I could only get about -.9 front camber (and had some rubbing), so I added the whiteline top hats to get more negative front camber and clearance for my wheels. I'd recommend staying away from the top hats till they get some issues worked out. Rear control arms and crash bolts are all you should need to even out your camber. You could also try the whiteline camber replacement bushings for the rear. I have a set, but never installed them. The install process was a serious PITA since I could not find a shop locally willing to deal with it.
console_cowboy is offline   Reply With Quote
Old 08-04-2013, 03:59 PM   #18
Miniata
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
I'd suggest taking your advice from fellow BRZ/FRS owners, but even that will vary widely. Better yet, try to find some other BRZ/FRS owners in your area with suspension modifications and get rides in their cars to see what feels right to you. You could also go to a local autocross, there should be a number of twins there, and most owners will welcome ride-alongs. We usually have at least half a dozen at our autocrosses, with everything from bone stock to heavily modified suspension.
Personally I added a front bar only to my BRZ, and was very pleased with the improvements in feel and handling. Did the same to my Mustang and Miata. My Mini is getting a rear only bar, and I've done just rear bars to other FWD cars in the past.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar
Miniata is offline   Reply With Quote
Old 08-04-2013, 04:35 PM   #19
FriedRicr
Woop Dee Woop Woop Woop
FriedRicr's Avatar
Drives: Raven 6MT FR-S
Thank you all for the input! I will do alot more HW and See what best fits me! saved me a couple hundred that i didn't even need to spend right now!
FriedRicr is offline   Reply With Quote
The Following User Says Thank You to FriedRicr For This Useful Post:
Calum (08-04-2013)
Old 08-04-2013, 05:59 PM   #20
Calum
That Guy
Something I forgot to mention, tires.
Sent from my GT-S7560M using Tapatalk 4
Old 08-04-2013, 08:59 PM   #21
Isn't your shop car running stock sways??
Yup!
wparsons (08-04-2013)
Old 08-04-2013, 09:49 PM   #22
utekineir
blowhard
Drives: frs, project forester
are your friends audis 10 years old and slammed on cheap coils?
utekineir is offline   Reply With Quote
The Following User Says Thank You to utekineir For This Useful Post:
wparsons (08-05-2013)
Old 08-05-2013, 11:23 AM   #23
Sccabrz192
Detroit Region, MI
Sccabrz192's Avatar
Drives: 13 BRZ, 13 Volt, 02 WRX
Start here:
[ame="http://www.amazon.com/How-Make-Your-Car-Handle/dp/0912656468/ref=sr_1_cc_1?s=aps&ie=UTF8&qid=1375716117&sr=1-1-catcorr&keywords=how+to+make+your+car+handle"]Amazon.com: How to Make Your Car Handle (9780912656465): Fred Puhn: Books[/ame]
Detroit / NWOR SCCA Member
2005-06: #192 ES 91 MR2 N/A Hardtop
2007-08: #54 STX 05 WRX Sedan
2009-12: #92 BSP/ASP 07 Solstice GXP
2013-14 : #192 CS 13 Subaru BRZ
Sccabrz192 is offline   Reply With Quote
The Following 2 Users Say Thank You to Sccabrz192 For This Useful Post:
CSG Mike (08-05-2013), FriedRicr (08-05-2013)
Old 08-05-2013, 11:27 AM   #24
Originally Posted by Sccabrz192 View Post
That's a great book.
- Andy
Did something extremely retarded... Tylub Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 09-24-2013 10:53 AM
Extremely RARE Nixon 48-20 Chrono LTD (eBay) ThaBigUnit Miscellaneous 5 07-18-2013 12:34 AM
Having an extremely tough time deciding... SVTSHC Scion FR-S / Toyota 86 GT86 General Forum 75 02-13-2013 01:58 PM
Am I Extremely Lucky? Ordered one month ago, already have a VIN! bkneal BRZ First-Gen (2012+) — General Topics 13 08-15-2012 01:10 PM
Tapatalk app notification extremely annoying Zgrinch Off-Topic Lounge [WARNING: NO POLITICS] 14 07-19-2012 11:20 AM
