Old 08-02-2013, 07:40 PM   #15
KONVERTER
KONVERTER's Avatar
Rebuild kit is really only needed if the rubber is cracking (TPMS are old). Not really "needed" on a new car, however, might as well do it now to avoid any issues in the future...
KONVERTER is offline   Reply With Quote
Old 08-02-2013, 07:42 PM   #16
KONVERTER
KONVERTER's Avatar
Originally Posted by Touge Factory View Post
$80.00 is on the high side.
We charge $10 per
So you charge $80 as well...
Remove from original wheels and re-balance with rubber valve stems. 4 x $10 = $40
Mount / Balance new wheels w/ TPMS... 4 x $10 = $40
Total $80
If I am mistaken please explain?
Old 10-04-2013, 05:51 PM   #17
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
OMG! I got a quote from America's Tire for $30
1. take off my stock TPMS
2. Install new valve stems and inflate.
hanabie is offline   Reply With Quote
Old 10-04-2013, 05:55 PM   #18
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Discount Tire told me $7 per wheel for their transfer kit. Not a bad deal. I'd go that route if you can.
ericmpena is offline   Reply With Quote
Old 10-04-2013, 06:09 PM   #19
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by topazsparrow View Post
Skip the TPMS swap entirely.
0$
the ONLY outcome is that the warning light will be on in your dash. A tune will take care of that if you go that route as well.
You can tune out tire pressure light? wut?
Link me brah
Is the brz/frs too expensive? huma BRZ First-Gen (2012+) — General Topics 74 05-12-2015 12:28 AM
Expensive light Rims+Expensive light Tires or Suspension+Cheaper Rims+Cheaper Tires? OnionTou Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 44 08-09-2013 06:57 PM
Changed to new wheels w/o TPMS, car still thinks I have TPMS sensors? Ahz Issues | Warranty | Recalls / TSB 9 11-06-2012 08:25 AM
Why are expensive brakes better? hotaka Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 08-28-2012 01:26 AM
FA20 + gearbox weight Vs Transplant setups.... FT-86GOD Engine, Exhaust, Transmission 2 08-21-2012 09:42 PM
