Old 10-29-2013, 01:00 AM   #15
FLYFISHR
FLYFISHR's Avatar
Drives: 2014 BR"ZED" Sport-tech DGM MT
What I did was order an extra tow hook cover plate just to be on the safe side and have a replacement that I put back in place if I didn't like the way it work out. It only cost a bit over $4
After removing the cover plate and inserting the Grimmspeed tow hook bar I used green painters tape to cover the opening working around the bar.
I then used a small exacto blade to cut the tape from around the opening I had covered.
That left me with a template that I could use to mark the exact place to put the hole in the cover, which was a bit of and oval rather than a round opening.
Old enough to know better but young enough to do it again
FLYFISHR is offline   Reply With Quote
Old 10-31-2013, 05:25 PM   #16
B2FiNiTY
JDM JUNKY
B2FiNiTY's Avatar
Drives: NSX
so much better!
B2FiNiTY is offline   Reply With Quote
Old 11-03-2013, 06:36 PM   #17
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
I followed your direction and drilled with a 7/8" paddle bit as I don't have a 1". The Grimmspeed fit perfect and very snug. Thanks!
- AdrianG
AdrianG is offline   Reply With Quote
Old 09-09-2014, 01:23 AM   #18
enginrd
Drives: 2014 BRZ Limited
Two cents
Wanted to add a few tips.
- I bought an extra BRZ bumper cover from the local (SoCal) dealership for $5.50, and it took about a week to get in.
- When installing the shaft into the car frame, don't forget grease! Also a torque wrench is a must, as it turned many more times than I would have expected.
- While some photos seem to show that the license plate is mounted in the lateral plane, it turns out it only fits on an angle. I have mine at about 10 degrees, which is a bit more than necessary but it gives me piece of mind that the bumper paint is safe.
enginrd is offline   Reply With Quote
Old 04-15-2018, 10:52 AM   #19
slizoth
slizoth's Avatar
Drives: 2013 WRB Subaru BRZ
After the relocation kit is installed, what do you guys use to cover the old front plate holes? Just some bondo or black bolts?
slizoth is offline   Reply With Quote
Old 09-15-2019, 03:00 PM   #20
scoobydrew
Drives: 2001 Subaru Impreza
For anyone with a 17+ BRZ that wants to order a spare, the part number is 57731CA510 not 57731CA210.
scoobydrew is offline   Reply With Quote
FS: Grimmspeed Side plate mount kit. Flawless22 Canada Classifieds 0 06-24-2013 03:49 PM
DIY: Making a GoPro camera mount with a GrimmSpeed front plate mount PMok DIY (Do-It-Yourself) Guides 2 06-11-2013 10:58 AM
license plate mount by grimmspeed ft86me Cosmetic Modification (Interior/Exterior/Lighting) 2 02-11-2013 10:48 AM
How do you mount the front plate? sa1126 Scion FR-S / Toyota 86 GT86 General Forum 71 11-06-2012 08:24 PM
For those of you with grimmspeed or perrin license plate relocator Brimford Cosmetic Modification (Interior/Exterior/Lighting) 24 10-16-2012 08:57 PM
