Old 08-14-2013, 12:38 AM   #15
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Where did you get the spacer bolt? I have looked everywhere with no luck. They all day it only comes with the kit.
calispec is offline   Reply With Quote
Old 08-15-2013, 06:06 PM   #16
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Mocal non-thermo brz/frs oil sandwich adapter
Originally Posted by mad_sb View Post
I looked around for a while yesterday for a plate and spacer but could not find anything but the mocal thermostatic one. I don't want to run a thermostat because a lot of my DD trips are bairly long enough for the oil to get up to 100*c and i want this setup to help heat the oil quicker. I guess I could remove the thermostat in mocal unit, but I would like to keep the cost down and have bungs for pressure and temp.
Mocal adapter w/o thermostat available for about $130. You can special order through any of our vendors who deal in Mocal.
Part no. MOC-SP1-fa20.
Pm if you can not find it.
Good luck
- When men make plans the gods laugh.
Brzzee is offline   Reply With Quote
Old 08-16-2013, 03:55 PM   #17
mtimney
mtimney's Avatar
Drives: 2013 BRZ Limited
Robispec just came out with an oil cooler adapter plate that eliminates the need for a spacer, and it has a hole for a sensor. I can't give you a link for them, but he's on the forum all the time and you can see it on this thread:
http://www.ft86club.com/forums/showt...=26424&page=12
I would have gone with this had it come out before I did my setup.
mtimney is offline   Reply With Quote
The Following User Says Thank You to mtimney For This Useful Post:
SirBrass (05-01-2014)
Old 03-31-2014, 07:10 AM   #18
PineappleFriedRice
Truuu
PineappleFriedRice's Avatar
Drives: 2013 FRS, 88 EF Civic, 05 Matrix
Originally Posted by mtimney View Post
I bought a super cheap sandwich plate for adding sensors, then plugged the sensor holes and ground it down around the edges enough so it would fit into the oil-overflow well that's under the filter. (You could also buy a spacer, gaskets, and spacer bolt from Perrin about $80.)
Do you have a link to the sensor sandwich plate you used?
GARRET .60 TRIM-UEL HEADERS-1150cc INJECTORS-DW FUEL PUMP-RACESENG CAM PLATE-PERRIN 3" CATBACK-ULTIMATE RACING 2.75 OP/FP-FBM CATCHCAN-SINGER 275AMP ALTERNATOR-MEGAN TRACK COILS-MEGAN F/R STRUTBARS-AXLE EXCHANGE ALUMINUM DRIVESHAFT-ACT 6 PUCK-ANARCHY MOTIVE SHIFTKNOB-XXR 535-HANKOOK VENTUS EVO V2-CS LIP KIT
Build Thread - FA20FAIL Archive
PineappleFriedRice is offline   Reply With Quote
Old 03-31-2014, 03:16 PM   #19
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
I just saw this thread, and this looks interesting, especially in regards to not clogging up the front bumper with various coolers. How much is this oil/water laminova cooler kit costing?
^GT5 Replay Photo Mode^
Old 04-16-2014, 08:32 PM   #20
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
Why would you not want a thermostatic sandwich plate? Isn't a thermostatic one better at warming up cold oil and cooling hot oil?
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
Old 04-16-2014, 08:50 PM   #21
Model Citizen
Lacking brains
Drives: frz
Thermostatic cuts off flow when cold, opens when warm. When cooling with ambient air it's useful not when using the coolant system
Model Citizen is offline   Reply With Quote
Old 04-18-2014, 12:24 AM   #22
Brick
Drives: White 2013 FRS
So I have a laminova oil cooler on a FI car when I get back home I'll review the logs I have and check what temps stabilized at and post it up for y'all.
Brick is offline   Reply With Quote
Old 04-27-2014, 01:48 AM   #23
wootwoot
Drives: FRS
Any updates?
wootwoot is offline   Reply With Quote
Old 05-01-2014, 09:52 AM   #24
SirBrass
SirBrass's Avatar
Originally Posted by wootwoot View Post
Any updates?
Bump, and ditto.
On phone I am. Therefore, if mistakes I make, Frank Oz blame you should.
Old 07-08-2014, 08:34 PM   #25
sw20kosh
Drives: 2013 Black FR-S
This is awesome. Just bought mine.
The Following User Says Thank You to sw20kosh For This Useful Post:
mkivsoopra (07-09-2014)
Old 07-08-2014, 08:38 PM   #26
sissupr
sissupr's Avatar
Drives: 2014 BRZ Premium - SWP
Maybe I missed it... how much for everything?
Vortech SC V3 // 3.12 Pulley // Moto-East Tune (93oct,e40-50,e85)
sissupr is offline   Reply With Quote
Old 07-08-2014, 10:06 PM   #27
sw20kosh
Dunno, i just bought the laminova core for 350 since I have lines and a sandwich plate.
Old 07-09-2014, 12:07 AM   #28
mkivsoopra
About 450 for the core + lines + fittings, without sandwich plate.
mkivsoopra is offline   Reply With Quote
Intake and water encity5 Engine, Exhaust, Transmission 5 07-23-2013 01:49 PM
Water Spots norcal_brz Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 07-16-2013 02:06 AM
Water by the Bridge Panda Grahams Southeast 5 03-20-2013 09:50 AM
Water in trunk Spencer BRZ First-Gen (2012+) — General Topics 14 03-15-2013 11:17 PM
