Old 07-19-2013, 03:29 PM   #15
wparsons
wparsons's Avatar
On my car with stickier tires the OEM pads couldn't engage ABS at all in a straight line with warm tires, with the new pads it has no problem. I don't have any quantitative data, but I would bet mine stops at least a few feet shorter with the new pads.
On stock tires I could easily engage ABS so it wouldn't have made any difference at all.
flickr
Old 07-19-2013, 05:31 PM   #16
vignesh
Engineer
vignesh's Avatar
Drives: WRB 2022 Subaru Brz
I was hoping maybe the vented/slotted rotors would help cool the brakes better and resist fade. Its the fade i am more concerned with not so much the stopping power. Stopping power is more related to emergency stop in a straight line, while brake fade is a huge factor when braking mid cornering due to the weigh transfer.
vignesh is offline   Reply With Quote
Old 07-19-2013, 09:53 PM   #17
andrewFT86
andrewFT86's Avatar
Drives: dark grey metallic Toyota 86 MT
Pads with a higher heat range should be more than enough.
andrewFT86 is offline   Reply With Quote
Old 07-19-2013, 11:28 PM   #18
jflogerzi
jflogerzi's Avatar
Originally Posted by swift996 View Post
Pads + Fluid...stainless lines are cheap too
This what I am going to do. Even with basic FI, you don't need these fancy BBK or even new rotors.
Old 07-19-2013, 11:32 PM   #19
swift996
swift996's Avatar
But it does get better, just speaking bang for the buck. Pads get you 75-80% of the way there though. BBK with soft pads are a waste of time and money.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 07-20-2013, 03:24 AM   #20
stockysnail
Just the tip
stockysnail's Avatar
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
I recommend to keep in on the cheap to start with pads and fluid. After you wear out those pads and save up money, get the AP Racing sprint kit, or the Wilwood kit. If you aren't tracking more than once a year use your money on something else and stick with pads and fluid.
stockysnail is offline   Reply With Quote
Old 07-20-2013, 03:25 AM   #21
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
for track days just get some blank cheap rotors with some ferodo or carbo tech pads. SS brake lines if you feel like it but since it's 100$ why not. But most importantly, brake fluid. Motul, ATE blue, etc. Just a warning, ive boiled motul rbf600 in my old STi but in a light car like the FRS it should be no problem. For a DD though, stop tech street pads, again motul or ATE fluid, and you're good to go.
bkblitzed is offline   Reply With Quote
Old 07-20-2013, 09:47 AM   #22
wparsons
wparsons's Avatar
Stock rotors are vented all around, and slotting doesn't really aid cooling. It will increase pad wear though.
Off topic, but if you're concerned with brake fade mid corner you're probably not driving right. Ideally most of the braking is done before the corner entry, if you're trail braking hard enough to get fade you might want a different line?
flickr
Just Ordered the Complete StopTech Brake Package from FT86 SpeedFactory naikaidriver Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 02-28-2017 02:48 PM
WORKS Stage 1 Complete Brake Package Upgrade 86_ZN6 Brakes, Suspension, Chassis 1 05-28-2013 04:57 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
