Old 07-16-2013, 09:22 PM   #15
Area86
Area86's Avatar
Drives: 2013 BRZ limited SWP
Originally Posted by Gixxersixxerman View Post
Thank you for doing the research and drawing this up..
Do you see anything that would make the "ethanol is the cause" plausible.. If not why do you think other countries do not report this problem? I love finding out this stuff, knowledge is power type stuff..
Or better yet, we have a guy that's on E85, no noise at all.. Switches to 91, immediately starts the crickets, do you have a theory as to why??
Yes I have been on e85 since November with no crickets and I switched back to 91 last week and they were back instantly. I will be going back to e85 after this tank and will see if they go away again.
Sent from my DROID RAZR using Tapatalk 2
Area86 is offline   Reply With Quote
The Following User Says Thank You to Area86 For This Useful Post:
SkullWorks (07-16-2013)
Old 07-16-2013, 09:56 PM   #16
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
Here i was hoping my pump would eat itself and id have a reason to open it up and see how it all works and what i can do to improve it.
My crickets died at 3500 miles, and returned around 3800 miles, i love my zombie crickets even more.
WHITE is offline   Reply With Quote
Old 07-16-2013, 10:06 PM   #17
SkullWorks
Drives: SSM LT MT BRZ
Yes, obviously I took a pump apart, There will be pictures of that soon enough but in a different thread with a different purpose.
The problem with addressing the E-85 / E-10 / Ethanol Free / 93 / calpis 91 /chicken McNugget smoothie debacle is that there are lots of conflicting statements. I haven't seen a RULE so to speak in specific usage of gas that allows all parties to not have crickets. I haven't done an exhaustive comparison of cases of cricket vs Fuel. I generally run Chevron (in lieu of Texaco) or Shell gas and have had the crickets come and go randomly, some times in the middle of a tank. I don't think there are many automotive manufacturing Giants running around making ethanol un-friendly BRAND NEW part numbers for fuel systems,,,maybe I have too much faith in humanity
SkullWorks is offline   Reply With Quote
The Following User Says Thank You to SkullWorks For This Useful Post:
JDM FRS (07-18-2013)
Old 07-16-2013, 10:21 PM   #18
SkullWorks
There are 3 "soft parts" in the pump the rubber-like seal (RED) the O-ring
I described and the valve-stem type seal that sits outside of this assembly. If there was an "incompatible" material in this assembly that is subjected to movement related to engine RPM I would have to say it would be one of those 3 items.
I didn't see any way any of those parts (even in complete failure) could cause a noise of such volume...being inherently soft as they are...even the seal and O-ring shown above don't do any actual restraining...at first they appear to perhaps but the piston to pump body clearance is in the realm of .0002 generally, if deflection occurred there would be a much more tragic sound, I saw no wear patterns on the DLC coating on the piston nor on the pump's cylinder walls to indicate any deflection was occurring.
Perhaps the pump shaft squeaks as it runs through the seal?
I'm open to logical discussion.
Old 07-17-2013, 01:57 PM   #19
empower-auto
Kouki-Monster
empower-auto's Avatar
bump for posterity.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 07-17-2013, 02:54 PM   #20
ft_sjo
Drives: GT86
Well they chirp here in the UK, on no more than 5% ethanol content fuel.
Old 07-17-2013, 03:08 PM   #21
HunterGreene
Hail Magnet
HunterGreene's Avatar
Well, this is the first mention I have seen of the chirp outside of North America.
Old 07-17-2013, 03:53 PM   #22
BadMoon
BadMoon's Avatar
Drives: 2014 GLI Autobahn/Nav
I find this whole ethanol thing interesting now. I'm on my third tank of ethanol free gas and its chirping away. Could be the OP is spot on.
BadMoon is offline   Reply With Quote
The Following User Says Thank You to BadMoon For This Useful Post:
SkullWorks (07-17-2013)
Old 07-17-2013, 04:59 PM   #23
markitect
Drives: Scion FRS
Is the pump made by Subaru/Toyota, or is it sourced from a supplier (Denso, Bosch)?
markitect is offline   Reply With Quote
Old 07-17-2013, 05:14 PM   #24
SkullWorks
Hard to say.
If I was more familiar with the part number designation of the major manufacturers it would be easier I assume. It is VERY similar in foot print to one of the audi pumps I have done R&D on and that specific pump had several manufacturers and revisions....but this is different from each of those.
It is definitely something that FHI could make if they so desired, hyundai also makes alot of these as do Denso, Bosch, and others i assume aswell.
CSG Mike (07-17-2013)
Old 07-17-2013, 06:26 PM   #25
SkullWorks
Originally Posted by Marchy View Post
is there any way to hook the pump on to a machine that can test it out to see if it makes the noise still? I know for the HPFP on the speed 3 and audi's there's a local company here in the seattle area that will test every pump he sells. he just won't test pump internals.
I haven't pulled apart a head and cam to check the installed position relative to the lobe that drives the pump...so I couldn't do an effective study.
Which Shop are you referring to in Seatte?
Old 07-18-2013, 03:05 AM   #26
ft_sjo
Drives: GT86
His shop is called torq motorsports but he sells his fuel pumps through another company called hpfpupgrade.
If he can do sustained testing in a temperature controlled environment then that'd be a decent test. I don't think putting a cold pump on test for 30 seconds would be adequate to prove or disprove anything to do with chirping.
Old 07-18-2013, 05:00 AM   #27
yahtzee
yahtzee's Avatar
Drives: GT86
Mine started a about 300 miles ago I'm at 3000 now coincided with warmer summer temps and only noticeable when car warmed up at idle not cold I'm in uk and only used shell vpower.
Will
yahtzee is offline   Reply With Quote
The Following User Says Thank You to yahtzee For This Useful Post:
strat61caster (07-19-2013)
Old 07-19-2013, 11:22 PM   #28
Tromatic
Could it be something other than the pump itself? Perhaps the mount, or even the fuel flow at idle (some sort of fluid dynamics thing) causing the noise? The pump itself resonating? Cavitation? Water in the fuel boiling? All SWAGS.
So far, I do not have the chirp running e-free fuel.
Anyway, THANKS for this.
Tromatic is offline   Reply With Quote
The Following User Says Thank You to Tromatic For This Useful Post:
DylanFRS (07-20-2013)
Max NA HP on pump gas as of now? jadewbj Engine, Exhaust, Transmission 128 02-17-2016 09:28 AM
Engine Internals from CP-Carrillo Now Available! Infamous Performance Engine, Exhaust, Bolt-Ons 108 02-13-2014 11:35 AM
Engine internals before FI? Rejor11 Forced Induction 14 06-04-2013 05:18 PM
stronger/forged internals Tyson Engine, Exhaust, Transmission 24 03-15-2013 04:38 AM
How about them internals nytfury Engine, Exhaust, Transmission 5 08-27-2012 07:23 AM
