| DIY (Do-It-Yourself) Guides For all DIYs. |
#15 |
Cool Stuff
Drives: Cool Car
Idk they are all cheap, the o-rings and spacers that is, but the sun isnt even near its highest point in the Twins Aftermarket life, so there isnt a science to it yet.
#16 |
I Love custom Turbo kits
Drives: Limited BRZ
@xjohnx has a part number from Napa for them, he'll chime in.
The available FP's are universal, so their height is different than OEM pump, thus the need to play around with O rings to make the pump seal inside the canister and not loose REALLY important fuel pressure and prevent the motor from BOOM.
#19 | |
Drives: 2013 SWP BRZ
#20 |
It looks like Deatschwerks has revised the bump, as you can see below the output shaft has these teeth like thingy now. The white washer does not fit on this new output shaft anymore. But the kit now comes with 3 of the black O-rings.
#21 |
Drives: Toyota 86
Thanks to the OP for the DIY! I'm about to install the DW65c fuel pump in my car, and this thread is extremely helpful. However, I have a couple of questions. It looks like DW has revised the pump nipple as posted by DrifEm. They now include 3 o-rings and their instructions tell you to install the three o-rings or alternatively, the white spacer (cut on one side so it will expand and slip into the revised nipple) and one o-ring. Whoch method is better?
The local tuner here who installed the same pump on their 450hp 86 shop car advised me not to cut the spacer and just use a file to enlarge the hole on the white spacer and use one o-ring. What do you guys think? |
#22 |
Yeah, I wouldn't cut the white spacer. Over time it may crack the spacer on the opposite side.
I'd just install the 3 o-rings, or you could file the spacer as well. Its more or less the same thing, just take the 3 o-rings and make sure they are the same height as the white spacer + 1 o ring. I mean any modification you make to that spacer you are losing some of the integrity of it, so I am not sure how comfortable I would feel having to drill that out or cut it. Why did DW do that?
#23 |
Thanks for the DIY; it helped a lot!
I have the revised pump as well and I cut the spacer personally; it appears to be made of delrin so it should stay solid. I used the white spacer and two o-rings as pictured; though... hope it doesn't cause an issue...
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
#24 |
Drives: Toyota 86 TRD Version AT
Just installed mine today. Installed it with four o-rings first per instructions. Car started and idled fine. After a street tune, we parked the car for a few hours, when we tried to start it again it would not fire. We took the pump out and put the spacer on with one o-ring, the car started up again.
#25 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
I hate to ask such a stupid question. I'm wanting to get the DW65c fuel pump, so that I won't starve my engine when driving hard. But, during regular DD, would having a larger fuel pump result in a decrease in MPG?
#26 | |
Drives: GT86 Cosworth
Have you had any issues with fuel staration? As I understand it, the stock pump is capable of supplying enough fuel to a Cossie stage 2? |
#27 |
I have not, but I was considering upgrading it eventually.
#28 |
DIY: Deastchwerks 265c Fuel Pump Install
@xxscaxx Thanks for this DIY. It made the fuel pump install fairly straightforward.
I do have a few questions about my install and if I did everything correctly. I ended up installing the Denso 260lph from Chris over at Speed by Design and purchasing a DW adapter kit from Summit Racing. The wiring harness worked perfectly and I used the OEM white collar with 2 o-rings. Everything seemed to be plug in play except for the fuel sock. The DW adapter kit from Summit Racing came with a short yellow sock that had a rigid plastic backbone inside of it that prevented me from bending/fitting it into the fuel canister assembly. However it did allow for the metal barbed ring and rubber black end cap to be used to secure the sock to the end of the fuel pump as per this DIY. On the other hand, the longer, white sock that came with the actual Denso fuel pump allowed me to fit the fuel pump assembly back into the canister assembly because the sock was much more flexible. But this longer, white Denso sock did not allow me to secure it to the new Denso fuel pump with the barbed metal ring and black rubber end cap. It is simply pressure fitted into the hole at the end of the fuel pump. It seems secure because I had to push fairly hard to get it pressure fitted but I'm concerned that it will eventually work itself loose. Also, since we've removed the clipping mechanism that held the OE fuel pump to the fuel pump assembly, how does our aftermarket pumps stay secured in the fuel pump assembly? I just sent Chris an email to ask him his thoughts but I thought I'd pick your collective brains as well. How did everyone else do theirs? ![]()
| Fuel pump upgrade install (Visconti 290lph) | jet86 | DIY (Do-It-Yourself) Guides | 44 | 01-04-2018 07:56 PM |
| PSA: Tips on what needs to be payed close attention on Fuel Pump install | Sportsguy83 | Engine, Exhaust, Transmission | 34 | 04-25-2014 11:24 PM |
| Fuel pump issue. | sevi21 | Issues | Warranty | Recalls / TSB | 13 | 02-01-2013 09:57 AM |
| Car fuel pump on... | Genomaxter | Engine, Exhaust, Transmission | 5 | 11-29-2012 10:06 AM |
| Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 3 | 08-21-2012 04:53 PM |
