Old 09-10-2013, 04:10 PM   #15
pgeist
pgeist's Avatar
Drives: 2013 Black BRZ Limited 6MT
Originally Posted by BC-Boy View Post
do you have issues when idling ?
I have the idle issue only with the A/C on with and without the Unichip.
Zeta Stage 2 Drop In + Red Silicone Tubing || Zeta SS Cat Back || DC Sports Cat-Delete Front Pipe || Torque Pro + MiniOBD Bluetooth || Fumoto F-108 Drain Valve || Konig Daylite Gold 17x7 +40 14.2lbs || Anarchy Motive Shift Knob
Future: Catted header, OEM Audio+
pgeist is offline   Reply With Quote
Old 09-10-2013, 11:14 PM   #16
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Originally Posted by Rombinhood@OpenFlash View Post
There is now an option that does not modify the stock tune file with license data. With the OpenFlash Tablet, you actually read and save your entire 1.3mb rom file when you first plug it it. That file is available to write back to your ecu at any time.
And that's why I have been researching openflash as an option. Also not having to have a pc laptop to use is a huge plus. (Mac guy)
The Racers Line is offline   Reply With Quote
Old 09-10-2013, 11:19 PM   #17
Drives: FRS
Originally Posted by DoomsdayJesus View Post
I just cancelled my unichip order, despite all the reading I'd done I didn't realize the limitations. It does seem like a really great bargain if you don't want to get into heavy tuning with a shop, but after talking to Bob at Drift Office he recommended using another method for tuning as well.
Unichip certainly still seems like a pretty good option, it's just depending on what you want to accomplish. For people wanting as easy/cheaper tune it seems like a solid way to go.
So Open Flash wouldn't leave any footprint? I know we can flash back our stock ROM but doesn't it still leave evidence that it's been re-flashed?
It's hard to gauranty if any tune will or will not leave any type of footprint. In the case of the OpenFlash Tablet, the stock map you can write back into your ECU (before dealership visits) is 100% stock. Byte for byte.
With other flashing solutions (Ecutek and BRZedit), the map isn't identical to the factory file. If the ROM is read at the dealership level, they can determine if the ECU has been modified. But I have never heard of a dealership reading the file off an ECU so I think this may be an unreasonable concern.
Rombinhood@OpenFlash is offline   Reply With Quote
Old 09-10-2013, 11:29 PM   #18
The Racers Line
I'm not sure why I never put this together, but you guys worked with Vishnu performance?! I come from the BMW world. I think I just found my tuning option...
HELP! After Unichip install, car won't start!!! husker741 Issues | Warranty | Recalls / TSB 21 01-10-2015 10:50 PM
Anyone know a good place to get the OEM + system and install? CamryDS Northern California 11 05-01-2013 06:35 PM
Has anyone done a good concealed Valentine One install? sikest Electronics | Audio | NAV | Infotainment 3 01-22-2013 06:37 PM
anyone know of any good shops to install my Tein Flex adj coilovers in El Paso?? FRS-HHH Southwest 12 10-13-2012 01:58 AM
Good places to Install HID in So Cal Zoomryder Cosmetic Modification (Interior/Exterior/Lighting) 12 08-20-2012 06:36 PM
