Old 11-15-2013, 09:54 PM   #15
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the Wheel Directory:
http://tinyurl.com/86wheels
Old 01-02-2014, 08:20 PM   #16
Odd
Odd's Avatar
Drives: DGM BRZ
Adding mine to the list, not a popular combo from what I can tell by a search.
Odd is offline   Reply With Quote
Old 01-02-2014, 11:17 PM   #17
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Originally Posted by CyberCT View Post
How does the car feel with the reduced weight in the wheels? I would think 5 lbs per corner (if tire weighs are the same) would be noticable on a 2 liter engine.
On my RSX the weight difference was quite noticeable. About the same weight reduction.
It's a really noticeable improvement in ride quality with just over 4 lbs less unsprung weight a corner (which is what my track setup comes to)... the car is much more planted and stable (which is also probably due to the wider track from better offset). Stock size sticky performance tires on lighweight 17x8 wheels (I have +36mm offset Kosei K4R's [~15.6lbs] with 215/45-17 Kumho Ecsta XS mounted) also really bring out the precision and quickness of the FRS chassis.
Nice BRZ you have there Guillaume. A track day at Spa would be fun!
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline   Reply With Quote
The Following User Says Thank You to Vracer111 For This Useful Post:
Mr.Impreza (10-04-2015)
Old 01-09-2014, 08:06 AM   #18
Guillaume
Guillaume's Avatar
Drives: Exige S 240
Thanks! Spa is a terrific track indeed, well suited to our chassis but would be even more fun with some extra power
Old 06-29-2014, 11:30 PM   #19
Odd
Odd's Avatar
Drives: DGM BRZ
Sold mine to a WRX owner - I miss them.
17x7.5 +48 5x100 with Stock Michelin Tires
The Following User Says Thank You to Odd For This Useful Post:
Mr.Impreza (09-21-2015)
Old 04-06-2021, 12:13 PM   #20
Spocknasty
Spocknasty's Avatar
Drives: '13 BRZ Limited / 76' 914 1.8T
17x7.5 +48 5x100 with 215/45R17 Potenza RE-71R. I only got this size so that I could reuse tires I had. Suspension is Bilstein B6 and Hotchkis lowering springs.
Automotive photo and video
www.mikespock.com
Spocknasty is offline   Reply With Quote
The Following User Says Thank You to Spocknasty For This Useful Post:
EB86 (04-06-2021)
Old 04-06-2021, 03:46 PM   #21
EB86
Drives: GT86
I see you went with the 7.5 due to tyre size, were you not happy putting the 215 on an 8 inch wheel?
BTW always seems like the silver looks bigger than the black in the same size with the RPf1
Like the centre caps where did you get them?
EB86 is offline   Reply With Quote
Old 04-12-2021, 04:00 PM   #22
Spocknasty
Spocknasty's Avatar
I'm not doing anything too crazy with the car and went 7.5" with weight reduction in mind. I also have limited experience with stretched tires so I played it safe. I think visually they are on the small side but it is what it is.
I definitely notice the weight savings over the OEM wheels, the car is much smoother at speed and feels less crashy over bumps.
I got the caps here: https://flatoutgfx.com/products/enkei-rpf1-center-caps
-Mike
www.mikespock.com
Old 04-12-2021, 04:30 PM   #23
EB86
Drives: GT86
thanks for the link, will check out the caps.
I think 7.5 is a good choice for 215 tyres, I'm about to put 215 on my 8" RPF1 so will soon see how it looks.
The Following User Says Thank You to EB86 For This Useful Post:
Spocknasty (04-12-2021)
Wheel Directory: Enkei EV5 17x7.0 +38 rikdrt1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 30 12-17-2016 11:47 AM
Wheel Directory: Enkei RS-7 17x7.0 +35 m.box.design Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 01-06-2016 10:56 AM
Wheel Directory: Enkei RPF1 Type-II 17x7.0 +48 hankster Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 10-05-2013 02:23 AM
Wheel Directory: Enkei FLC-01 17x7.0 +40 Mr.Jay Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-09-2013 03:44 PM
Wheel Directory: Enkei WTE II 17x7.0 +41 stout90 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 01-06-2013 10:18 PM
