#15 | |
I Love custom Turbo kits
Drives: Limited BRZ
You can stay off boost as long as you want modulating your pedal. You can go on spirited runs in a completely empty street and never need to even brake hard. Its not realistic that it is ABSOLUTELY necessary to upgrade brakes when getting a basic FI kit. Whomever spends their time at the road speed limits before and after turbo kit, will need the same brakes they had before. As a disclaimer, I upgraded my tires and brakes along with a stage 2 + Turbo Kit because I do plan to race my car.
#16 | |
Member of the year - 2016
Drives: Scion FRS
Or are people just bolting turbos for show?
#17 | ||
Drives: Limited BRZ
You'd be amazed to find out the majority of people are not like us. Hey, I am in your camp in the sense that it is a great upgrade and i highly recommend upgrading them. Where I disagree is in the notion that its absolutely necessary. It just really depends on each person and their driving style.
| The Following User Says Thank You to Sportsguy83 For This Useful Post: | dem00n (07-11-2013) |
#18 |
Drives: Scion FR-S
| The Following 5 Users Say Thank You to Nightbringer For This Useful Post: | akuhei (07-12-2013), dem00n (07-11-2013), Laika (07-11-2013), Pete (07-13-2013), Sportsguy83 (07-11-2013) |
#19 | |
Drives: Scion FRS
But we're pretty lucky the twins have such good brakes. Not so much on non sport/performance cars that receive increased power.
| The Following User Says Thank You to dem00n For This Useful Post: | Sportsguy83 (07-11-2013) |
#20 | |
Grip>Slip
The brakes aren't working against the force of your car's horsepower. |
#21 |
Drives: Scion FRS
What do you mean? Our cars don't have KERS?
#22 |
Drives: Scion FRS
Let me rephrase it like this.
Lets say you're going full throttle down the same block everyday, you go with FI and are running some extra ponnies. When you reach the end of the block you'll clearly be going faster then stock, thus you'll need to apply more braking force to slow down and turn. People are repetitive, they forget they are running more power and use more braking force when they need to slow down, in a lot of cases brakes won't be as good and will just cause an accident. Maybe you don't HAVE to upgrade brakes on every car but for MYSELF i always do so. Did so on the I30, and i'll do so on the FRS if i go down the FI route.
#23 |
Drives: FRS Silver LS1 swapped.
Stages determine more than anything else how much money some one spent on a build and is not determined by an owner but, assigned by tuners and speed shops to sell products IMHO.
#24 |
Grip>Slip
#25 | |
Drives: WRD BRZ Limited
I've never run out of stock brakes, on any car, on the street or at an AutoX. "Big" brakes just improve modulation, heat storage, and dissipation. Big brakes don't even stop you any faster, your tires are the main ingredient for that. In other words: they work the same as stock brakes 99% of the time, except they hold up under the pressure of minutes and hours of hard braking with sticky tires. |
| The Following User Says Thank You to BryanGT For This Useful Post: | nalc (07-14-2013) |
#26 |
Drives: 13 DGM BRZ Ltd
I like the turbo Subaru world of stages of modifications. Stage 1 = tune, stage 2 = stage 1 + downpipe (req'd)/intake (opt)/exhaust (opt), stage 3 = upgraded turbo + all those other bits from stage 1 and 2.
Or the Supra Turbo world of non-BPU (aka stock) and BPU cars. |
#27 | |
Drives: BRZ Sport-tech
Dem00n, I hope I never see you in person, because you must drive like a total reckless maniac. The stock brakes are more than good enough to handle anything you can do on the streets. If we're talking about required upgrades, and upgrade precedence to remain safe at all speeds and driving styles, 1. Tires 2. Brakes 3. Suspension (Afterall, if you're going so fast that your brakes need to be upgraded, you might overwhelm the capability of stock suspension to handle the power and braking forces. 3. Power P.S. I'm on stage 3. Removed dealer license plate frame, detailed car, and installed a sound tube plug.
| The Following User Says Thank You to PMPB For This Useful Post: | xjohnx (07-13-2013) |
#28 |
The Mechanic
Drives: Civic Turbo,FR-S
im on stage 863.6................ header oh yea
| Racecomp BRZ after 120 days. STAGE 1 complete. | Racecomp Engineering | BRZ Photos, Videos, Wallpapers, Gallery Forum | 35 | 10-23-2015 06:45 PM |
| Anyone choose zeta stage 1 over stage 2? | BlackyRose | Engine, Exhaust, Transmission | 2 | 07-06-2013 02:32 PM |
| WORKS Stage 1 Complete Brake Package Upgrade | 86_ZN6 | Brakes, Suspension, Chassis | 1 | 05-28-2013 05:57 PM |
| >> EcuTek << STAGE 1 / STAGE 2 / E85 - Tunes Available | FT-86 SpeedFactory | Engine, Exhaust, Bolt-Ons | 133 | 05-21-2013 02:39 AM |
| Complete Front Stage Upgrade for FR-S/BRZ | JoeBoxer | Audio/Visual, Electronics, Infotainment, NAV | 0 | 03-22-2013 01:06 AM |
