Old 07-11-2013, 10:35 AM   #15
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
You're still accelerating faster, if you had a 0-60 time of 6.0 secs and then you added power and its at 5.0 secs then you have increased the power quite a lot in a small car, even a small increase of 50 WHP is a lot is a "light" weight car like this. Stock brakes won't be as adequate with increased power, even if your not going to track your car. Not saying anyone has to go with a full brake kit and etc, but upgrades pads and tires can go a long way.
Also if i'm doing the same sort of autocrossing and i'm getting to the corner faster then i did stock, the brakes will take more of a beating, so they should be upgraded.
To each their own, but I fail to see the argument too. It all depends on driving habits. LOTS of people just get a FI kit, bolt in on and go. No plans to ever hit a track the car, no plans to get into dangerous speeds, nothing at all.
You can stay off boost as long as you want modulating your pedal. You can go on spirited runs in a completely empty street and never need to even brake hard. Its not realistic that it is ABSOLUTELY necessary to upgrade brakes when getting a basic FI kit. Whomever spends their time at the road speed limits before and after turbo kit, will need the same brakes they had before.
As a disclaimer, I upgraded my tires and brakes along with a stage 2 + Turbo Kit because I do plan to race my car.
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
nalc (07-11-2013), SkAsphalt (07-11-2013)
Old 07-11-2013, 02:08 PM   #16
dem00n
Member of the year - 2016
dem00n's Avatar
Drives: Scion FRS
Its a simple concept if an object moves faster then it needs to stop faster as well. No matter if your tracking or not, you made that improvement in power for a reason, i assume most of you will be pushing the limits more and more then in stock.
Or are people just bolting turbos for show?
Old 07-11-2013, 02:13 PM   #17
Sportsguy83
Drives: Limited BRZ
Again see in red. Also, the stock brakes are OK to stop in the street on several spirited runs, stop and go stop and go. Its not like they are garbage. You are posting from a perspective of someone who drives aggressively and/or tracks the car.
You'd be amazed to find out the majority of people are not like us.
Hey, I am in your camp in the sense that it is a great upgrade and i highly recommend upgrading them. Where I disagree is in the notion that its absolutely necessary. It just really depends on each person and their driving style.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
dem00n (07-11-2013)
Old 07-11-2013, 02:19 PM   #18
Nightbringer
Nightbringer's Avatar
Drives: Scion FR-S
Nightbringer is offline   Reply With Quote
The Following 5 Users Say Thank You to Nightbringer For This Useful Post:
akuhei (07-12-2013), dem00n (07-11-2013), Laika (07-11-2013), Pete (07-13-2013), Sportsguy83 (07-11-2013)
Old 07-11-2013, 02:21 PM   #19
dem00n
dem00n's Avatar
Drives: Scion FRS
I see what you mean, but personally i always like to play it safe.
But we're pretty lucky the twins have such good brakes. Not so much on non sport/performance cars that receive increased power.
The Following User Says Thank You to dem00n For This Useful Post:
Old 07-11-2013, 02:21 PM   #20
xjohnx
Grip>Slip
xjohnx's Avatar
You realize that unless you're flooring the accelerator pedal while braking, that horsepower has absolutely nothing to do with the brakes, right?
The brakes aren't working against the force of your car's horsepower.
Old 07-11-2013, 02:24 PM   #21
dem00n
dem00n's Avatar
Drives: Scion FRS
What do you mean? Our cars don't have KERS?
Old 07-11-2013, 02:32 PM   #22
dem00n
dem00n's Avatar
Drives: Scion FRS
Let me rephrase it like this.
Lets say you're going full throttle down the same block everyday, you go with FI and are running some extra ponnies. When you reach the end of the block you'll clearly be going faster then stock, thus you'll need to apply more braking force to slow down and turn. People are repetitive, they forget they are running more power and use more braking force when they need to slow down, in a lot of cases brakes won't be as good and will just cause an accident.
Maybe you don't HAVE to upgrade brakes on every car but for MYSELF i always do so. Did so on the I30, and i'll do so on the FRS if i go down the FI route.
Old 07-12-2013, 04:52 AM   #23
cf6mech
Drives: FRS Silver LS1 swapped.
Stages determine more than anything else how much money some one spent on a build and is not determined by an owner but, assigned by tuners and speed shops to sell products IMHO.
cf6mech is offline   Reply With Quote
Old 07-12-2013, 08:25 AM   #24
xjohnx
Grip>Slip
xjohnx's Avatar
Old 07-12-2013, 02:40 PM   #25
BryanGT
Drives: WRD BRZ Limited
I've never run out of stock brakes, on any car, on the street or at an AutoX. "Big" brakes just improve modulation, heat storage, and dissipation. Big brakes don't even stop you any faster, your tires are the main ingredient for that.
In other words: they work the same as stock brakes 99% of the time, except they hold up under the pressure of minutes and hours of hard braking with sticky tires.
BryanGT is offline   Reply With Quote
The Following User Says Thank You to BryanGT For This Useful Post:
nalc (07-14-2013)
Old 07-12-2013, 03:14 PM   #26
infinite012
Drives: 13 DGM BRZ Ltd
I like the turbo Subaru world of stages of modifications. Stage 1 = tune, stage 2 = stage 1 + downpipe (req'd)/intake (opt)/exhaust (opt), stage 3 = upgraded turbo + all those other bits from stage 1 and 2.
Or the Supra Turbo world of non-BPU (aka stock) and BPU cars.
infinite012 is offline   Reply With Quote
Old 07-12-2013, 11:21 PM   #27
PMPB
Drives: BRZ Sport-tech
This x100000
Dem00n, I hope I never see you in person, because you must drive like a total reckless maniac. The stock brakes are more than good enough to handle anything you can do on the streets.
If we're talking about required upgrades, and upgrade precedence to remain safe at all speeds and driving styles,
1. Tires
2. Brakes
3. Suspension (Afterall, if you're going so fast that your brakes need to be upgraded, you might overwhelm the capability of stock suspension to handle the power and braking forces.
3. Power
P.S. I'm on stage 3. Removed dealer license plate frame, detailed car, and installed a sound tube plug.
PMPB is offline   Reply With Quote
The Following User Says Thank You to PMPB For This Useful Post:
xjohnx (07-13-2013)
Old 07-13-2013, 12:03 AM   #28
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
im on stage 863.6................ header oh yea
IG-Joey_Soul
Progress Thread Ported billet 20G
Grip Ronin is offline   Reply With Quote
Racecomp BRZ after 120 days. STAGE 1 complete. Racecomp Engineering BRZ Photos, Videos, Wallpapers, Gallery Forum 35 10-23-2015 06:45 PM
Anyone choose zeta stage 1 over stage 2? BlackyRose Engine, Exhaust, Transmission 2 07-06-2013 02:32 PM
WORKS Stage 1 Complete Brake Package Upgrade 86_ZN6 Brakes, Suspension, Chassis 1 05-28-2013 05:57 PM
>> EcuTek << STAGE 1 / STAGE 2 / E85 - Tunes Available FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 133 05-21-2013 02:39 AM
Complete Front Stage Upgrade for FR-S/BRZ JoeBoxer Audio/Visual, Electronics, Infotainment, NAV 0 03-22-2013 01:06 AM
